iMCaan Posted 22 hours ago Posted 22 hours ago We have water UFH on ground and first floor and both floors are screeded. In one of the ground floor rooms, the temperature rises to as high as 23 degrees with Salus thermostat set at 8 degrees (same as the other rooms) that's a huge 15 degree difference. In the other rooms the temperature is mostly around 10 degrees. I've taken the room temperature manually and it matches the temperature displayed on the Salus thermostat so it doesn't appear that thermostat is not faulty nor is the Salus auto actuator, which comes on and goes off. So what could be the reason? Why would there be such a high difference between the set temperature and the actual room temperature? Thanks
JohnMo Posted 21 hours ago Posted 21 hours ago I would check the thermostat settings and your controller. If rooms are 10 degs and you have the thermostat set at 8 degs, where is your boiler call for heat coming from. More details needed
iMCaan Posted 21 hours ago Author Posted 21 hours ago It's Salus Quantum 230v Programmable Thermostat and Salus CB500 5 Zone wiring centre. @JohnMo I need to think about this. How it works?
JohnMo Posted 20 hours ago Posted 20 hours ago Which quantum model? There is one for UFH and one for radiators. Do you have self learning stopping starting on or off?
SteamyTea Posted 20 hours ago Posted 20 hours ago 35 minutes ago, JohnMo said: quantum model The Copenhagen model allows for it to be both on and off, simultaneously. The room temperature will only be revealed when it is measured. 1
Nickfromwales Posted 20 hours ago Posted 20 hours ago Ffs. I googled ‘model’ and ended up back here….. 1
JohnMo Posted 19 hours ago Posted 19 hours ago 15 minutes ago, Nickfromwales said: Ffs. I googled ‘model’ and ended up back here….. Two basic models, WQ610 is for radiators and SQ610 for UFH. If you have a WQ on UFH and you have any self learning functions active, the thermostat loses all control as the algorithm is wrong for the application. A WQ will work with UFH, but only if you use in a simple on off mode. Been there, done it, got the tee shirt.
Nickfromwales Posted 19 hours ago Posted 19 hours ago 15 minutes ago, Nickfromwales said: Ffs. I googled ‘model’ and ended up back here….. 👆 2 minutes ago, JohnMo said: loses all control @SimonD gets what I was looking to achieve.
iMCaan Posted 4 hours ago Author Posted 4 hours ago (edited) Thanks all @JohnMo I have no idea how to setup self learning stopping starting or how to enable it. The thermostat model is SQ610 and the wiring centre is CB500 and auto balancing actuators are THB23031. We've not yet moved in. Since there's no broadband yet, I've not installed the Salus gateway therefore I'm not using the mobile app or have anything programmed. The scheduled timer on the thermostat is not set. I've not played with any other settings on any thermostat. Last night, I did some basic testing. Raised the temperature of every thermostat on the ground floor except for the affected room. All actuators came on except the three actuators for the room affected. The 3 flow pipes for the affected room were colder than the other room pipes to touch. After about an hour later I lowered the temperature on all thermostats to turn off the actuators. This morning, the room affected temperature was 11.5 degrees. I raised the temperature to 13 degrees and the three actuators for the room came on. Will check tonight what the room temperature is. Thanks Edited 4 hours ago by iMCaan
iMCaan Posted 4 hours ago Author Posted 4 hours ago Yes, I still do. I'm testing to figure out what is triggering the high temperature. Why it went as high as 23 degrees.
JohnMo Posted 2 hours ago Posted 2 hours ago You have self balanced actuators, maybe it was just going through a learning period, some can take quite awhile. With SQ610, you have a setting that optimises control to the Salus self balancing valves. Go on to Google and search for the full instructions for the SQ610, not the quick guide that comes with the thermostat.
