ab12 Posted Tuesday at 23:09 Posted Tuesday at 23:09 Dear All Can you please advise on the following scenario. Old property with partly vaulted ceiling has rafter depth of about 3 inches. Can this depth be somehow supplemented by adding extra timbers to the underside of existing rafters to make allowance for maximum of insulation that can be fitted between the rafters. Early next year the currently worn bitumen felt will be lifted and replaced with breathable membrane by replacing all the rafters is going to be a major headache and expense as its a very complicated roof structure. Ideally I want to add extra timbers to the exposed vaulted parts of the ceiling so can pack insulating between the rafters?
Crofter Posted Tuesday at 23:17 Posted Tuesday at 23:17 If the goal is to add extra insulation, could you use rigid insulation boards that go across the rafters? This would also reduce thermal bridging.
Redbeard Posted 16 hours ago Posted 16 hours ago Look up 'Larsen Trusses'. Lightweight 'separating rafters' attached by plywood or softwood 'separators' to the rafters. They are most often used on the outside walls of timber framed buildings to add lots of space for lots of insulation without adding lots of weight. My refurb of my room-in-roof space will use them (effectively a new, thinner, rafter 'dangling' below the existing). I have already drawn it and had it appraised by a structural eng'r to make sure the exg structure will not be overloaded, and it has proved OK. It allows me to use 'friendly' materials (weight included in the submission to SE, of course) rather than PIR. Note that unless you can get solid mountings for your 'under-rafter' in masonry elements all the weight will be on the rafters and any purlins they sit on, so the appraisal is essential. Even if you can get a mounting on masonry it is still a structural alteration so still needs SE 'blessing'.
gravelld Posted 15 hours ago Posted 15 hours ago @Redbeard I'm interested in how these work when used internally - I've only seen them hung on outside walls. Can you upload your drawings?
JohnMo Posted 15 hours ago Posted 15 hours ago Pretty easy, add counter battens. These will jive you a thermal repeat break as well. On mine I did 50mm packers then 50mm counter battens on that to give an additional 100mm. 2
Redbeard Posted 15 hours ago Posted 15 hours ago Just now, gravelld said: I'm interested in how these work when used internally - I've only seen them hung on outside walls. Can you upload your drawings Too late! @JohnMo has pipped me to it. They could also have been in line with the rafters but the principle is exactly the same. Thanks @JohnMo!
Oz07 Posted 15 hours ago Posted 15 hours ago 21 minutes ago, JohnMo said: Pretty easy, add counter battens. These will jive you a thermal repeat break as well. On mine I did 50mm packers then 50mm counter battens on that to give an additional 100mm. Some big screws used there i assume? What are the packers just an offcut of same section timber?
JohnMo Posted 15 hours ago Posted 15 hours ago Ring groove nails, put in at different angles so they can't pull out. Packets are same material as battens. 1
Roundtuit Posted 14 hours ago Posted 14 hours ago Is the 3 inches the full depth of the rafter? If so, I'd be cautious of hanging any additional weight off 75mm rafters, and be looking for a solution that added strength not just extra load I think.
ab12 Posted 12 hours ago Author Posted 12 hours ago (edited) Thank you all for the replies I've attached pictures of the proposed rafter depth for extension. Essentially extension will comprise two lengths of 1 metre timber attachments to the rafters and will be separated by purlin (photo shows proposed location for the timber attachments as white ellipses) a) 1st segment will run from the brick wall/wall plate to the 1st purlin b) 2nd segment will run from 1st purlin to 2nd purlin Old rafters have been sistererd/doubled with adjacently placed new rafters as shown in the photo (old dark brown, new light brown). Now I'm unsure where to attach the extra timber for depth extensions to the old rafters or the the new sister rafters. I want to extend the timber depth as much as practicably possibly but would be happy with even say an extra 10cm depth, current old rafters are about 7 cm in depth giving me space of 17 cm which will be insulated minus 2.5 cm allowance of gap between the insulation and breathable membrane. Currently there are about 10 sistered rafters and the widht of cavity space for insulation is going to be about 45cm and there will be about 9 cavity spaces to fill up Rest of room has essentialy horizontal ceiling and this section of the room will be insulated between and above joists quite easily. However of the opposite side of the room there is a similar sloped section of ceiling. Sorry for the extra details but I thought it will provide a more clearer picture of the ambitious target. Thanks Edited 12 hours ago by ab12
crispy_wafer Posted 12 hours ago Posted 12 hours ago I'm looking at this and thinking if it would it be too simple to just forget the rafter extensions, insulate with PIR Board under the rafters then screw 3*1 or 4*1 timber through to the rafters above to accept plasterboard? 1
Crofter Posted 11 hours ago Posted 11 hours ago 53 minutes ago, crispy_wafer said: I'm looking at this and thinking if it would it be too simple to just forget the rafter extensions, insulate with PIR Board under the rafters then screw 3*1 or 4*1 timber through to the rafters above to accept plasterboard? That's basically what I was suggesting, and how I built my own house. Except I used 2x1 battens on top of the PIR. Make sure you mark the line of the rafters before you cover them up. 2
Temp Posted 11 hours ago Posted 11 hours ago If you are replacing the membrane with vapour permeable one I don't think you need a ventilated air gap but you should still allow the membrane to drape unless external counter battens are used to lift the main tile battens off the membrane. Otherwise I would fit one layer of insulation between the existing rafters and another layer at 90 degrees below them as @Crofter suggested. 1
ab12 Posted 10 hours ago Author Posted 10 hours ago 1 hour ago, Crofter said: That's basically what I was suggesting, and how I built my own house. Except I used 2x1 battens on top of the PIR. Make sure you mark the line of the rafters before you cover them up. Thank you for the suggestion. So the impression that I'm forming is that there will be a small void gap between the PIR attached to the underside of of rafters and the plasterboard. Is this void susceptible to condensation forming or am I overthinking?
ab12 Posted 9 hours ago Author Posted 9 hours ago Is natural insulation- woodfibre batts between the rafters and woodfibre board attached to the underside of rafter be more advantageous and run a lower risk for condensaation forming in case compared to PIR as it is breathable and can regulate humidity? PIR great materal but I'm thinking it's goubg to be impossible to get it 100% flush between the rafters so runs the risk of condensation when warm air from room meets the cold space beneath breathable membrane. Please share your thoughts.
ab12 Posted 9 hours ago Author Posted 9 hours ago 1 hour ago, Temp said: If you are replacing the membrane with vapour permeable one I don't think you need a ventilated air gap but you should still allow the membrane to drape unless external counter battens are used to lift the main tile battens off the membrane. Otherwise I would fit one layer of insulation between the existing rafters and another layer at 90 degrees below them as @Crofter suggested. Counter battening sounds a good idea to create air gap above insulation if insulation is fitted flush between and upto full depth of rafters. Would counter batteining have the net effect to lif the roof line slightly and woud the eaves, guttering, offits, fascia etc have to be adjusted? The property is a semi- would abutments to neighnouring property be affected and can it be easily rectified? Thanks
