ab12 Posted November 18 Posted November 18 Dear All Can you please advise on the following scenario. Old property with partly vaulted ceiling has rafter depth of about 3 inches. Can this depth be somehow supplemented by adding extra timbers to the underside of existing rafters to make allowance for maximum of insulation that can be fitted between the rafters. Early next year the currently worn bitumen felt will be lifted and replaced with breathable membrane by replacing all the rafters is going to be a major headache and expense as its a very complicated roof structure. Ideally I want to add extra timbers to the exposed vaulted parts of the ceiling so can pack insulating between the rafters?
Crofter Posted November 18 Posted November 18 If the goal is to add extra insulation, could you use rigid insulation boards that go across the rafters? This would also reduce thermal bridging.
Redbeard Posted November 19 Posted November 19 Look up 'Larsen Trusses'. Lightweight 'separating rafters' attached by plywood or softwood 'separators' to the rafters. They are most often used on the outside walls of timber framed buildings to add lots of space for lots of insulation without adding lots of weight. My refurb of my room-in-roof space will use them (effectively a new, thinner, rafter 'dangling' below the existing). I have already drawn it and had it appraised by a structural eng'r to make sure the exg structure will not be overloaded, and it has proved OK. It allows me to use 'friendly' materials (weight included in the submission to SE, of course) rather than PIR. Note that unless you can get solid mountings for your 'under-rafter' in masonry elements all the weight will be on the rafters and any purlins they sit on, so the appraisal is essential. Even if you can get a mounting on masonry it is still a structural alteration so still needs SE 'blessing'.
gravelld Posted November 19 Posted November 19 @Redbeard I'm interested in how these work when used internally - I've only seen them hung on outside walls. Can you upload your drawings?
JohnMo Posted November 19 Posted November 19 Pretty easy, add counter battens. These will jive you a thermal repeat break as well. On mine I did 50mm packers then 50mm counter battens on that to give an additional 100mm. 2
Redbeard Posted November 19 Posted November 19 Just now, gravelld said: I'm interested in how these work when used internally - I've only seen them hung on outside walls. Can you upload your drawings Too late! @JohnMo has pipped me to it. They could also have been in line with the rafters but the principle is exactly the same. Thanks @JohnMo!
Oz07 Posted November 19 Posted November 19 21 minutes ago, JohnMo said: Pretty easy, add counter battens. These will jive you a thermal repeat break as well. On mine I did 50mm packers then 50mm counter battens on that to give an additional 100mm. Some big screws used there i assume? What are the packers just an offcut of same section timber?
JohnMo Posted November 19 Posted November 19 Ring groove nails, put in at different angles so they can't pull out. Packets are same material as battens. 1
Roundtuit Posted November 19 Posted November 19 Is the 3 inches the full depth of the rafter? If so, I'd be cautious of hanging any additional weight off 75mm rafters, and be looking for a solution that added strength not just extra load I think.
ab12 Posted November 19 Author Posted November 19 (edited) Thank you all for the replies I've attached pictures of the proposed rafter depth for extension. Essentially extension will comprise two lengths of 1 metre timber attachments to the rafters and will be separated by purlin (photo shows proposed location for the timber attachments as white ellipses) a) 1st segment will run from the brick wall/wall plate to the 1st purlin b) 2nd segment will run from 1st purlin to 2nd purlin Old rafters have been sistererd/doubled with adjacently placed new rafters as shown in the photo (old dark brown, new light brown). Now I'm unsure where to attach the extra timber for depth extensions to the old rafters or the the new sister rafters. I want to extend the timber depth as much as practicably possibly but would be happy with even say an extra 10cm depth, current old rafters are about 7 cm in depth giving me space of 17 cm which will be insulated minus 2.5 cm allowance of gap between the insulation and breathable membrane. Currently there are about 10 sistered rafters and the widht of cavity space for insulation is going to be about 45cm and there will be about 9 cavity spaces to fill up Rest of room has essentialy horizontal ceiling and this section of the room will be insulated between and above joists quite easily. However of the opposite side of the room there is a similar sloped section of ceiling. Sorry for the extra details but I thought it will provide a more clearer picture of the ambitious target. Thanks Edited November 19 by ab12
crispy_wafer Posted November 19 Posted November 19 I'm looking at this and thinking if it would it be too simple to just forget the rafter extensions, insulate with PIR Board under the rafters then screw 3*1 or 4*1 timber through to the rafters above to accept plasterboard? 1
Crofter Posted November 19 Posted November 19 53 minutes ago, crispy_wafer said: I'm looking at this and thinking if it would it be too simple to just forget the rafter extensions, insulate with PIR Board under the rafters then screw 3*1 or 4*1 timber through to the rafters above to accept plasterboard? That's basically what I was suggesting, and how I built my own house. Except I used 2x1 battens on top of the PIR. Make sure you mark the line of the rafters before you cover them up. 2
Temp Posted November 19 Posted November 19 If you are replacing the membrane with vapour permeable one I don't think you need a ventilated air gap but you should still allow the membrane to drape unless external counter battens are used to lift the main tile battens off the membrane. Otherwise I would fit one layer of insulation between the existing rafters and another layer at 90 degrees below them as @Crofter suggested. 1
ab12 Posted November 19 Author Posted November 19 1 hour ago, Crofter said: That's basically what I was suggesting, and how I built my own house. Except I used 2x1 battens on top of the PIR. Make sure you mark the line of the rafters before you cover them up. Thank you for the suggestion. So the impression that I'm forming is that there will be a small void gap between the PIR attached to the underside of of rafters and the plasterboard. Is this void susceptible to condensation forming or am I overthinking?
ab12 Posted November 19 Author Posted November 19 Is natural insulation- woodfibre batts between the rafters and woodfibre board attached to the underside of rafter be more advantageous and run a lower risk for condensaation forming in case compared to PIR as it is breathable and can regulate humidity? PIR great materal but I'm thinking it's goubg to be impossible to get it 100% flush between the rafters so runs the risk of condensation when warm air from room meets the cold space beneath breathable membrane. Please share your thoughts.
ab12 Posted November 19 Author Posted November 19 1 hour ago, Temp said: If you are replacing the membrane with vapour permeable one I don't think you need a ventilated air gap but you should still allow the membrane to drape unless external counter battens are used to lift the main tile battens off the membrane. Otherwise I would fit one layer of insulation between the existing rafters and another layer at 90 degrees below them as @Crofter suggested. Counter battening sounds a good idea to create air gap above insulation if insulation is fitted flush between and upto full depth of rafters. Would counter batteining have the net effect to lif the roof line slightly and woud the eaves, guttering, offits, fascia etc have to be adjusted? The property is a semi- would abutments to neighnouring property be affected and can it be easily rectified? Thanks
Temp Posted November 21 Posted November 21 On 19/11/2025 at 16:09, ab12 said: Counter battening sounds a good idea to create air gap above insulation if insulation is fitted flush between and upto full depth of rafters. Would counter batteining have the net effect to lif the roof line slightly and woud the eaves, guttering, offits, fascia etc have to be adjusted? The property is a semi- would abutments to neighnouring property be affected and can it be easily rectified? Thanks Yes it would raise the roof line by about 30mm. As it's a semi I probably wouldnt add counter battens. 1
ab12 Posted November 23 Author Posted November 23 On 19/11/2025 at 14:41, Crofter said: That's basically what I was suggesting, and how I built my own house. Except I used 2x1 battens on top of the PIR. Make sure you mark the line of the rafters before you cover them up. Just re-reading though the thread again and I think I know understand what you mean but just want to clarify couple of things: 1) were the PIR boards directly attached to rafters or held in place through screws from the battens above them which were fixed to the rafters? 2) given that there are battens above PIR board to accept the PB will this cause an air gap of 30mm between the PB and the PIR Thanks
Crofter Posted November 24 Posted November 24 9 hours ago, ab12 said: Just re-reading though the thread again and I think I know understand what you mean but just want to clarify couple of things: 1) were the PIR boards directly attached to rafters or held in place through screws from the battens above them which were fixed to the rafters? 2) given that there are battens above PIR board to accept the PB will this cause an air gap of 30mm between the PB and the PIR Thanks I used very long screws to hold the PIR to the rafters directly. No battens attached to the rafters. I used insulation washers, which are big plastic things, to spread the load and stop the heads pulling through. I then installed a polythene vapour barrier, with battens following the line of the rafters, and even longer screws. The PB then went on top of those battens. 1
ab12 Posted Tuesday at 13:15 Author Posted Tuesday at 13:15 On 24/11/2025 at 08:03, Crofter said: I used very long screws to hold the PIR to the rafters directly. No battens attached to the rafters. I used insulation washers, which are big plastic things, to spread the load and stop the heads pulling through. I then installed a polythene vapour barrier, with battens following the line of the rafters, and even longer screws. The PB then went on top of those battens. Thank you Crofter. Great makeup to bulk up the insulation. Can I ask what thickness of PIR did you go for? I suppose the limiting factor is going to be the length of screws that need to go throught the PIR to affix to the rafters. Thinking aloud the some carefully planning will be needed to mark up location of screws through PIR which in turn would allow location of the longer screws throught the battens infront of VCL to be set at a different location so the 2 screws dont collide. With the batten makeup a service cavity is introduced making it a good location for any wiring etc.
Crofter Posted Tuesday at 22:35 Posted Tuesday at 22:35 9 hours ago, ab12 said: Thank you Crofter. Great makeup to bulk up the insulation. Can I ask what thickness of PIR did you go for? I suppose the limiting factor is going to be the length of screws that need to go throught the PIR to affix to the rafters. Thinking aloud the some carefully planning will be needed to mark up location of screws through PIR which in turn would allow location of the longer screws throught the battens infront of VCL to be set at a different location so the 2 screws dont collide. With the batten makeup a service cavity is introduced making it a good location for any wiring etc. On the ceiling, I used 100mm PIR. I marked the rafter line in places that wouldn't be covered by the PIR, then ran a straight edge down to draw that line on to the PIR. It helped that I was using paper faced, not foil. I can't remember quite how I managed to drive the screws in square, possibly I used a block of wood or something to act as a set square. You only need to be super accurate in one plane, you can be pointing a bit too far up or down the line and still hit the rafter. The insulation washers are essential. I think I was using Pz3 screws, at these lengths that what you'll find. I was fortunate and got most of mine on clearance from Screwfix. If you do mess up and miss the rafter, just try again. And if you end up leaving a hole, you can foam it up. My battens went directly over the same line. Really, the first set of screws just need to hold the weight of the PIR for a short while until the battens go on. I used 25mm battens which is minimal really in terms of creating a service void. It worked, but it made the wiring pretty fiddly. The back boxes I was using were designed for a deeper cavity and I had to trim the lugs on them to make them fit. That got a bit tedious after a while! 1
ab12 Posted Wednesday at 15:53 Author Posted Wednesday at 15:53 Brilliant. Thank you loads ,Crofter, for the detailed response. Much appreciated.
