markharro Posted August 30 Posted August 30 We will shortly be needing to drill holes for some screws through our tiled shower enclosure. Mainly to instal two of these hinges - https://www.wholesaleglasscompany.co.uk/shop/colcom-8501n-glass-to-wall-shower-door-hinge.html - for a glass door. Behind the tiles is 12mm cement board and behind that an 18mm ply pattress. Couple of questions - 1 What is the best type of drill bit for the terrazzo and any tips to ensure that a clean hole is drilled? 2 I have 32mm of depth before the screws will hit the ply. The idea is to use long enough screws to penetrate the full extent of the 18mm ply. I was planning to use a drill bit of the same diameter as the screw I use. If it wasn't for the ply I would have to use rawlplugs but given I have ply I dont think I need these?
nod Posted August 31 Posted August 31 A 20 mil diamond hole bit and plenty of water will go through like butter
markharro Posted August 31 Author Posted August 31 Sorry I meant a 20mm thick tile, not the diameter of the whole which will probably be 6-8mm or the likes.
nod Posted August 31 Posted August 31 22 minutes ago, markharro said: Sorry I meant a 20mm thick tile, not the diameter of the whole which will probably be 6-8mm or the likes. Same answer The diamond hole saws go down to 4 mil Drill slowwwwly Lots of water Most of the tile shops will sell drilling reservoirs That simply stick to the tile and cool the bit 1
Nickfromwales Posted August 31 Posted August 31 1 hour ago, nod said: Same answer The diamond hole saws go down to 4 mil Drill slowwwwly Lots of water Most of the tile shops will sell drilling reservoirs That simply stick to the tile and cool the bit +1 https://www.amazon.co.uk/RUBI-4927-Easygres-Accessories-Metallic/dp/B00A3SDNK8/ref=asc_df_B00A3SDNK8?mcid=974bd86e521831afbdb57ac519b0afc3&th=1&psc=1&hvocijid=14815439965987008970-B00A3SDNK8-&hvexpln=74&tag=googshopuk-21&linkCode=df0&hvadid=696285193871&hvpos=&hvnetw=g&hvrand=14815439965987008970&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9046619&hvtargid=pla-2281435176618&psc=1&gad_source=1
Nickfromwales Posted August 31 Posted August 31 When you get through the tile you need to poke back through the drill bit to get the pellet of tile out, before drilling the next hole. When you get through the tile, stop. You can screw through the backer board and the ply for additional purchase. Also you must put a short bead of clear CT1 across the junction of the tray / wall, where the profile for the glass will be; just literally the width of it. You then run a line of same up the back of the profile, from that bead, and bring it all together whilst all wet. You also want to fill the screw holes with it too. Then fix with the screws, and simply remove any excess CT1 with cheap baby wipes, lots and lots of them changed after one or two ‘wipes’. You wipe the first short bead away almost completely after installing the profile, leaving the tile / tray junction to then take the cosmetic silicone work. If you miss the 1st step above it will leak.
markharro Posted August 31 Author Posted August 31 Thanks both - when you say a diamond hole saw do you mean something like this with a flat head - https://www.screwfix.com/p/erbauer-hex-shank-diamond-tile-drill-bit-6mm-x-67mm/51908 If so would I not need something like this to stop it skating all over the tile - https://www.screwfix.com/p/erbauer-diamond-tile-drill-guide/84524 ? I was thinking of this sort of thing - https://www.screwfix.com/p/bosch-expert-hex-9-hard-ceramic-tile-drill-bit-set-5-pieces/974rr And @Nickfromwales thats useful waterproofing tips but I think you are imagining we are using some sort of frame or metal profile- we are not. The idea is a single pane of glass pivoting on the 2 hinges and totally frameless. The room is a semi-wet room. So I guess the CT1 in the screwholes may be all we need? 1
Nickfromwales Posted August 31 Posted August 31 6 minutes ago, markharro said: Thanks both - when you say a diamond hole saw do you mean something like this with a flat head - https://www.screwfix.com/p/erbauer-hex-shank-diamond-tile-drill-bit-6mm-x-67mm/51908 If so would I not need something like this to stop it skating all over the tile - https://www.screwfix.com/p/erbauer-diamond-tile-drill-guide/84524 ? I was thinking of this sort of thing - https://www.screwfix.com/p/bosch-expert-hex-9-hard-ceramic-tile-drill-bit-set-5-pieces/974rr And @Nickfromwales thats useful waterproofing tips but I think you are imagining we are using some sort of frame or metal profile- we are not. The idea is a single pane of glass pivoting on the 2 hinges and totally frameless. The room is a semi-wet room. So I guess the CT1 in the screwholes may be all we need? Use the Rubi one I linked to? It is a guide and waters the bit as you’re drilling? If you buy the one from SFx you’ll need a hand held water bottle to keep spraying it with. Yes to screw holes only, 👌
Nickfromwales Posted August 31 Posted August 31 10 minutes ago, markharro said: Thanks both - when you say a diamond hole saw do you mean something like this with a flat head - https://www.screwfix.com/p/erbauer-hex-shank-diamond-tile-drill-bit-6mm-x-67mm/51908 These skate about and take the whole section of tile out, with the kits you have hollow drills which remove next to nothing and leave the ‘core’ to be removed.
ProDave Posted August 31 Posted August 31 3 minutes ago, dpmiller said: what's wrong wth a normal spear bit for this? I was about to say that. Cheap, they seem to work, and the pointed arrow head bit does not skate around. Usually sold as a set of 3, 4mm, 6mm and 8mm No coolant needed.
Nickfromwales Posted August 31 Posted August 31 17 minutes ago, dpmiller said: what's wrong wth a normal spear bit for this? Pretty hopeless in porcelain imo. They get red hot and have cracked tiles previously when drilling near the edge. I use them for ceramics, but only ever use diamond for porcelain.
Onoff Posted August 31 Posted August 31 Use a guide. Lidl sometimes stock a set of drills including a vacuum type guide like the one below that you stick to the tiles. Did all my bathroom with a set of drills like this and just drilled bits of timber to make a guide
Alan Ambrose Posted September 1 Posted September 1 I’ve found those suction guides are fairly hopeless as they’re too pliable - or maybe I’m too stupid. I use a few layers of duck tape to give a tiny amount of support and hold the bit at an angle and run it slowly to create a little lip in the tile. As soon as you have a little arc in the right place you can gently straighten the bit out. Once there’s a little circle there it isn’t going anywhere.
markharro Posted October 2 Author Posted October 2 Thanks all...we are about to get our glass delivered so this is going to become reality soon. Once thing I meant to check with you @Nickfromwales your advice to CT1 the screwholes. I can see why for waterproofing but will this not make it next to impossible to ever remove the screws?
crispy_wafer Posted October 2 Posted October 2 33 minutes ago, Onoff said: I've made jig boxes before to hold tiles: Oh yes, I like this, genius.
Nickfromwales Posted October 2 Posted October 2 1 hour ago, markharro said: Thanks all...we are about to get our glass delivered so this is going to become reality soon. Once thing I meant to check with you @Nickfromwales your advice to CT1 the screwholes. I can see why for waterproofing but will this not make it next to impossible to ever remove the screws? Not at all.
markharro Posted October 2 Author Posted October 2 Ok thanks I'm sure you'll know its just that it makes me a bit nervous and was wondering if silicone might not be the better option for this?
Nickfromwales Posted October 2 Posted October 2 15 minutes ago, markharro said: Ok thanks I'm sure you'll know its just that it makes me a bit nervous and was wondering if silicone might not be the better option for this? Nope! Proceed to the CT1 shop this exact minute and deviate-ye-not from'th the plan. Don't worry about taking it apart again afterwards, because if you're at that point then the CT1 behind a few things will be the very least of your worries
markharro Posted October 6 Author Posted October 6 Ok thanks @Nickfromwales is it simply the case that the torque from eg an impact driver will easily dislodge the screw if needed even if embedded in the CT1? I have another question......I figure I could use 6mm diameter SS screws for these hinges and ordered some which have arrived today and also ordered a drill bit to match at 6mm. Now I have the screws they do fit the holes in the hinge but the top of the screw sits slightly proud so the chrome cover plate will not slide over. So I need to go now and order some 5mm screws but my question is can I still use a 6mm drill bit or should I get another drill bit so I can drill a 5mm hole through the 20mm thick tile? My thinking is that maybe a 1mm excess in the hole isnt an issue? thanks
Nickfromwales Posted October 6 Posted October 6 Firstly, you’ll be putting these screws in by hand! If you use an impact youll very likely snap the heads off the screws. If you go to stainless then the issue, re snapping, becomes even worse as they’re brittle. Also check which dissimilar metals live together and don’t promote galvanic / electrolytic reactions, before straying away from the supplied ones. CT1 isn’t resin, it’s just a bit tougher than silicone. You’ll be able to remove the screws with a hand held driver. Chill out
Nickfromwales Posted October 6 Posted October 6 2 hours ago, markharro said: So I need to go now and order some 5mm screws but my question is can I still use a 6mm drill bit or should I get another drill bit so I can drill a 5mm hole through the 20mm thick tile? My thinking is that maybe a 1mm excess in the hole isnt an issue? I’d drill the 6mm hole and leave some wiggle room, as these drills can sometimes drill slightly off centre. Just squirt the CT1 into the hole, keeping an untrimmed CT1 nozzle handy, and let it displace as you screw in.
