JohnBishop Posted July 23, 2025 Posted July 23, 2025 Hi Everyone, I hope you are well. Are you allowed to installed back doors to open to the outside rather than to the inside like the front doors?
andyscotland Posted July 23, 2025 Posted July 23, 2025 As far as I know there's no actual requirement for front doors to open in (unless you are directly onto the pavement/highway), it's just a tradition. So I don't see any reason why a back door can't open out (and lots do, almost all patio doors for example). 1
Mike Posted July 23, 2025 Posted July 23, 2025 (edited) 1 hour ago, JohnBishop said: Are you allowed to installed back doors to open to the outside Absolutely. Any door can open outward - front, rear, side, whatever. Edited July 23, 2025 by Mike 1
Kelvin Posted July 24, 2025 Posted July 24, 2025 We don’t have a back door as such but the French Doors open out. Like the discussion on the other thread about this you need to think about supporting door in some way as the wind can rip outward opening doors out of your hand. 1
JohnMo Posted July 24, 2025 Posted July 24, 2025 We are the same @Kelvin, French doors. Wind is an issue. We have restrictions built in to doors to stop it going past 90 degs open, but is utter rubbish. Now have a hook and eye to keep door open at 90 degs. 1
ProDave Posted July 24, 2025 Posted July 24, 2025 Most of our external doors are inward opening, except the one to the balcony which opens out. I can't recall the logic of why we chose that. As others have said, outward opening needs care in wind but we are unlikely to use the balcony when it is windy. But outward is way better in terms of keeping the weather out. Our balcony door is very exposed and not a drop of wind driven rain has got in. The other "normal" back door downstairs opens in and is exposed to wind driven rain from the west. It does not leak when shut, the seals do a pretty good job of keeping the rain out. But it is inevitable with the geometry of an outward opening door that it relies 100% on the seals to keep wind driven rain out. The weakness is the small amount of wind driven rain that gets past the drip bead and then sits between the door and the frame, held back by the seal, and when you open the door that small amount comes in. 1
JohnBishop Posted August 25, 2025 Author Posted August 25, 2025 The other day I have removed the silicone in the corners and looked at the door frame (took some pictures) and it looks like the exterior insulation but also the interior plaster came after the doors so it looks like the frame goes deeper than I thought. I think I have to hack away the plaster to get a better idea and take realistic measurements. From what I know you need to give like 5mm gap on either side of the frame.
JohnBishop Posted September 2, 2025 Author Posted September 2, 2025 (edited) Removed most of the plaster on the inside and taken some measurements: Frame H 203cm W 88cm Thickness 9cm Door H 192.5cm W 79.5cm Thickness 4.5cm Threshold H 9.5cm W 92.5cm Thickness 4.5cm I think the missing is the measurements of the opening itself. On the top I can see the frame is like 2cm deep into the plaster/plasterboard (second picture). On the sides it is about 0.5cm on each side. I think I need to hack off more plaster if I want to fit a similar size frame in there. Edited September 2, 2025 by JohnBishop
JohnBishop Posted Tuesday at 16:45 Author Posted Tuesday at 16:45 Finally got around replacing the back door. Do I need to put more foam in there or just plaster it now?
craig Posted Tuesday at 22:45 Posted Tuesday at 22:45 (edited) Foam just needs tidied up and then plaster, also aluplast, well done. 4000, 8000 or Energeto? Did you purchase from a UK supplier? Edited Tuesday at 22:45 by craig 1
JohnBishop Posted yesterday at 00:48 Author Posted yesterday at 00:48 Do you mean to cut the foam so its flush with the frame? I actually don't know the full spec. It's a bit difficult to find this info at JustValueDoors. It does have a Thermal upgrade included whatever that means.
craig Posted yesterday at 10:09 Posted yesterday at 10:09 (edited) Yes, just trim it back, will make your life easier. Without knowing the product supplied, I can't really say what the values are as I would be guessing but in principle, if triple and insulated frame (foam injected into the frame), you're probably looking at the Energeto 8000. Edited yesterday at 10:10 by craig 1
JohnBishop Posted yesterday at 12:08 Author Posted yesterday at 12:08 1 hour ago, craig said: Yes, just trim it back, will make your life easier. Without knowing the product supplied, I can't really say what the values are as I would be guessing but in principle, if triple and insulated frame (foam injected into the frame), you're probably looking at the Energeto 8000. when drilling I have not seen any foam inside the frame Thermal upgrade is only to the glass 1) Argon Gas Filled Panes 2) Warm Edge Spacer Bars 3) Low E (emissivity) film JustValueDoors don't state anywhere what maker of the doors they supply or give any options of Aluplast doors. Perhaps I could inject the foam myself.
craig Posted yesterday at 12:13 Posted yesterday at 12:13 (edited) This is an upgrade? It should be🤬 standard, that's why I assumed it was foam injection for the Energeto 8000 Edited yesterday at 12:13 by craig
