CharlotteJ Posted July 16, 2025 Posted July 16, 2025 Hi, having read through loads of posts about sound insulation, I am still confused! Our builders merchants have recommended Isover APR1200 75mm for our 100mm studs. Density is 12kg/m3. Cost approx £4.09 per m2 From this forum, Rockwool RWA45 75mm is recommended often, Density 45kg/m3. Cost approx £6.19 per m2. Ive read conflicting views on higher density being better. We are thinking of boarding each side with blue plasterboard - does this make much difference, or would two standard plasterboard with staggered joints be as good - less heavy to deal with! Any other product recommendations or advice/experiences please?
JohnMo Posted July 16, 2025 Posted July 16, 2025 We used Rockwool Flexi, but most products are similar except PIR which is rubbish for sound. Your insulation material needs to be thinner than the stud so neither side touches the plasterboard. Denser insulation stay in place well, but needs more careful sizing. Gaps are bad and will circumvent the insulation. We used standard 12.5mm and dry lined no issues. 1
Thorfun Posted July 16, 2025 Posted July 16, 2025 4 hours ago, CharlotteJ said: Hi, having read through loads of posts about sound insulation, I am still confused! Our builders merchants have recommended Isover APR1200 75mm for our 100mm studs. Density is 12kg/m3. Cost approx £4.09 per m2 From this forum, Rockwool RWA45 75mm is recommended often, Density 45kg/m3. Cost approx £6.19 per m2. Ive read conflicting views on higher density being better. We are thinking of boarding each side with blue plasterboard - does this make much difference, or would two standard plasterboard with staggered joints be as good - less heavy to deal with! Any other product recommendations or advice/experiences please? ultimately it depends on how much dampening you want and how much money you want to throw at it! we used Rockwool throughout and standard 12.5mm plasterboard on both sides of internal walls. we do get sound transfer but then again, it's a house and not a museum so we don't mind a bit of transfer. besides, more often than not doors are left open so no amount of sound insulation is going to fix that! 🤣 i'd suggest RWA45 personally. nicer to work with than the Isover stuff afaik and it stays in place between the studs well. we put 50mm in the walls and 100mm in the ceilings 1
Nick Laslett Posted July 16, 2025 Posted July 16, 2025 (edited) You need to look at the performance tables from British Gypsum or Siniat GTEC, etc. This picture shows the acoustic performance of a simple 12.5mm timber stud wall, 35 is the key number. Next picture shows more variables, double boarding or insulation 16km/m3. Number now is higher than 35, this is better. You can find these performance tables from most plasterboard manufacturers, sometimes in a document called the White Book. Sound insulation is a complicated topic. There are three types of sound transmission that you are trying to control. I have a post about it here already. Edited July 16, 2025 by Nick Laslett 1
CharlotteJ Posted July 18, 2025 Author Posted July 18, 2025 Thanks so much for all the info, particularly the picture, very interesting and informative. We're going to try and insulate as best as possible as have two elderly relatives living with us who have their TV very loud!
Nickfromwales Posted July 18, 2025 Posted July 18, 2025 20 minutes ago, CharlotteJ said: Thanks so much for all the info, particularly the picture, very interesting and informative. We're going to try and insulate as best as possible as have two elderly relatives living with us who have their TV very loud! Have you investigated resilient bars? Pay particular attention to ceiling voids; in a previous clients build we doubled up the acoustic insulation in the ceiling voids, and made a 200mm wide acoustic wall to prevent sound going ‘up and over’ as this was a music/piano room. So fully filled the stud walls, doubles up in the ceiling, and we could have gone with acoustic PB but the builder had already ordered regular boards without consulting me as the clients consultant (before he ran off, and we adopted the completion of the build!), and no complaints so far. Resilient bars on walls can also help with acoustics, but I’d defo use 15mm sound block/acoustic plasterboard induce the TV room, on the ceiling there, and also on the other sides of those stud walls. 2
Nick Laslett Posted July 18, 2025 Posted July 18, 2025 @CharlotteJ, here is the text of a post I made recently about the sound insulation topic. Quote Good sound proofing, is a bit like airtightness. The devil is in the detail. Types of transmission : 1.Airborne noise Sound that uses the medium of air to travel through. Common example include talking, music and TV. 2.Impact noise Sound generated by two materials coming into contact, sound vibrations travel through the materials. Common examples are footsteps and washing machines. 3.Flanking Transmission When sound vibrations travel over, under or around a barrier. This could be using holes in walls made by light fixings, shelves or picture hooks. Another common example is pipe work which can vibrate with sound waves and travel between various rooms. You need to cover how each one of these types of transmission will be reduced, with Decoupling, Insulation and Absorption. The plasterboard absorbs the sound. Resilient bars create the Decoupling. Glass Fibre or Rockwall gives the insulation. More, thicker plasterboard the greater the absorption. Other simple wins: Standard doors will undo a lot of the benefit from a solid wall. Sound transmission through down lights. The wrong type of MVHR configuration can also carry sound between rooms. Don’t have plug sockets and light switches back to back in a wall between two rooms. I quite like this YouTube channel. They have a website too. http://www.youtube.com/@iKousticSoundproofing This website has lots of guides. https://soundstop.co.uk/pages/soundproofing-guides Here is a really good YouTube video from Ali Dymock that covers a lot of the concepts for sound proofing a wall. 1 1
saveasteading Posted July 19, 2025 Posted July 19, 2025 Resilient bars are very effective. You also need some soft insulation ( rockwool), and some density ( 2 layers plasterboard. Sound will still creep in at the edges so sort them too. The standard details in the plasterboard spec sheets are very useful and have been lab tested.....without edge ingress though. Do not, as I once did, assume that nursing home standards are appropriate...they assume hearing loss in residents... you need semi-detached sound blocking. 1
Thorfun Posted July 19, 2025 Posted July 19, 2025 and don't forget acoustic sealant to fill all the small gaps! 1
SteamyTea Posted July 20, 2025 Posted July 20, 2025 15 hours ago, saveasteading said: Do not, as I once did, assume that nursing home standards are appropriate. The home my Mother is in seems very noisy. It is an old vicarage (ironic as we sold her The Old Vicarage to pay for her to stay in an older one. Sound is a strange thing, but I can recommend secondary glazing over the existing double glazing, it really cut the outside noise down in my place, and saved loads of energy. That makes me think that maybe internal walls should be three layers of something dense, probably not hard to do at construction stage.
saveasteading Posted July 20, 2025 Posted July 20, 2025 1 hour ago, SteamyTea said: The home my Mother is in seems very noisy It is assumed that residents have diminished hearing, and that hearing general activity is a positive. And staff want to hear any noise, for quick reaction to any issues.
CharlotteJ Posted July 21, 2025 Author Posted July 21, 2025 On 18/07/2025 at 09:25, Nickfromwales said: Have you investigated resilient bars? Pay particular attention to ceiling voids; in a previous clients build we doubled up the acoustic insulation in the ceiling voids, and made a 200mm wide acoustic wall to prevent sound going ‘up and over’ as this was a music/piano room. So fully filled the stud walls, doubles up in the ceiling, and we could have gone with acoustic PB but the builder had already ordered regular boards without consulting me as the clients consultant (before he ran off, and we adopted the completion of the build!), and no complaints so far. Resilient bars on walls can also help with acoustics, but I’d defo use 15mm sound block/acoustic plasterboard induce the TV room, on the ceiling there, and also on the other sides of those stud walls. Thanks, thats a good idea re carrying it up into the ceiling voids....it is a single storey conversion and the roof space is too low for anything - it will have 300mm insulation for good U values but it is probably worth us carrying on the stud wall between the two rooms, into the roof and blue boarding and insulation it. 1
saveasteading Posted July 21, 2025 Posted July 21, 2025 18 minutes ago, CharlotteJ said: blue boarding It's density you need from the board. The blue board is a quarter heavier than the grey, for twice the price. 2 layers of normal board is better sound proofing and you can lap the joints. You will lose 12.5mm more room and have more work. 1
ClairedM Posted September 1, 2025 Posted September 1, 2025 On 18/07/2025 at 22:51, Nick Laslett said: @CharlotteJ, here is the text of a post I made recently about the sound insulation topic. Here is a really good YouTube video from Ali Dymock that covers a lot of the concepts for sound proofing a wall. Thanks for this video
