Marvin Posted July 12 Posted July 12 On 05/07/2025 at 09:26, ReedRichards said: Would it be such a sacrifice to trade-in your existing car for an EV? I'm on the EON NextDrive tariff and it meshes very well with my other electrical items, ASHP, solar PV with battery. Hi @ReedRichards Yes we have similar. We don't do many miles but we must have spent a total of about £100 over the last 2 years buying electricity for the EV. We use the 13amp charger and leave the vehicle plugged in when home and it only charges when the PV produces over 3.5kW. Of course this wouldn't work if the car was parked at work all day...
joth Posted July 12 Posted July 12 3 hours ago, sharpener said: I have a similarly complex charging regime but have been considering just charging battery to 100% every cheap period. The thinking is that every unit bought off the grid at 12.65p liberates a unit of PV which can be exported for 15p. Is there a flaw in this? This is exactly what I've been doing for a couple years. I hear the argument that charging it to full every day is worse for longevity, but if I get drawn into that argument the only winner is never charging the battery at all. I'm buying at 7p overnight and selling PV at 15p so even stronger argument. I do still redirect some PV to ashp (setpoint boost) and the battery. Financially I shouldn't do any those but they're more a nod to sustainability (and improving my home assistant self-sufficiency score) really
JohnMo Posted July 12 Author Posted July 12 10 minutes ago, joth said: ashp (setpoint boost) I do that as well, found in the shoulder months on a sunny day, all the heating was done via PV at a warmer day temperature. It would be zero at night and heat pump stayed off. Not sure how you square that with potential export. If I get export accepted, I will import at 12.65p, and export at 15p. So it may be more beneficial to run ASHP in the day, better CoP and no defrosting.
MikeSharp01 Posted July 12 Posted July 12 28 minutes ago, JohnMo said: I will import at 12.65p, Where do you get a tariff like that we are on 25.97p import!
JohnMo Posted July 13 Author Posted July 13 8 hours ago, MikeSharp01 said: Where do you get a tariff like that we are on 25.97p import! Octopus Cosy, 3x periods at 12.65p, 1 at about 33p and the rest at normal rate
Thorfun Posted July 13 Posted July 13 22 hours ago, joth said: For me I'd pay the £250 regardless anyway as it feels rewarding to be getting something back for the export but I know others that don't care. Getting paid for export on Octopus also means you don’t have to care what the forecast is for the day as you get paid more for export than on the cheap rate. So we just charge the batteries every cheap period on Cosy and if we export during that time then we’re still getting paid.
Thorfun Posted July 13 Posted July 13 13 hours ago, sharpener said: I have a similarly complex charging regime but have been considering just charging battery to 100% every cheap period. The thinking is that every unit bought off the grid at 12.65p liberates a unit of PV which can be exported for 15p. Is there a flaw in this? Exactly what we do. I also tried to find a flaw in it but couldn’t but my maths is not great! 😂
Dave Jones Posted July 13 Posted July 13 On 30/06/2025 at 19:26, JohnMo said: Currently have no smart meter that works due to a poor signal, after talking with a smart meter installer I now know how to get a working meter. Will explain for any one in a similar position. Electric supplier has to have 3 unsuccessful smart meter installs. You then request the case is raised with the DCC. 6 weeks later they allow a 4G meter to be installed. Problem fixed. So to my dilemma Have ASHP, GivEnergy 13kWh battery, PV but don't get paid for export. What is the best tariff to be on Standard tariff make no sense with a battery. E7 currently on that, easy to manage, but may not be most cost effective? Cosy, seems easy to manage? Agile, GivEnergy has controls built in, but expects export from what I can tell. Any suggestions or users doing anything different? Should I just pay octopus the £250 to allow export and be paid? could you not get the octopus smart meter wifi bridge ? We have one as mobile signal is non existent. Works great.
JohnMo Posted July 13 Author Posted July 13 On 12/07/2025 at 08:50, JohnMo said: Firstly now have a 4G smart meter, commissioning time was about 10 mins. 11 minutes ago, Dave Jones said: could you not get the octopus smart meter wifi bridge ? You must have missed above. We now have a 4G smart meter, all working. Now on Octopus Cosy. We are have an octopus mini instead of home display. 1
JohnMo Posted Monday at 13:50 Author Posted Monday at 13:50 On 12/07/2025 at 08:50, JohnMo said: schedule times. First cheap slot is setup as a smart schedule so it charges based on forecast generation of PV, second slot set to 90% SoC fixed target. 90% Final charge is set for a fixed 100% SoC Well that wasn't very effective. First charge was ok, second charge and third charge didn't work well. At this time of year even with cooling running, I just don't need that much charge in the battery. Second charge was changed to a smart charge, based on solar prediction, so it now charges to a minimum of 70%. If first charge period was ok battery is past that point anyway from PV. Also during that cheap slot system set to consume from battery if battery charge is above 75%, not from the default which is from grid. Third charge at 100%, meant I still had 80% charge remaining at time of first charge the next day and no room to accommodate much PV. So I exported - not being paid at this point. So that was changed to charge to at least 50% based on predicted PV generation and to self consume from battery if SoC is above 75%. Hope the changes give a good balance between, import cost, limited or no export and battery not running out, if predicted PV is out.
S2D2 Posted Tuesday at 07:35 Posted Tuesday at 07:35 If you're not getting paid for export you'll probably have to reign back charges heavily at this time of year (depending on generation and usage of course). I only use the Cosy three charges during the winter, perhaps try just a single overnight charge? I use three different prediction APIs and take the mean, it still needs a healthy buffer for day to day variance and forecasts change throughout the day. So it can't really be relied on without some ability to course correct, like forced export or spare battery capacity.
Dave Jones Posted Tuesday at 07:39 Posted Tuesday at 07:39 On 01/07/2025 at 13:49, JohnMo said: Unfortunately I don't have an EV, go and drive type tariffs won't work, unless they don't really ask you to prove EV. I am thinking Cosy maybe a good choice, easy to programme times for charging etc. But an EV tariff is way cheaper octopus didnt ask me to prove i have an EV just that we had a car charger they could talk to, which we have as every new build has to have one.
Dave Jones Posted Tuesday at 07:41 Posted Tuesday at 07:41 On 13/07/2025 at 08:16, JohnMo said: Octopus Cosy, 3x periods at 12.65p, 1 at about 33p and the rest at normal rate 7p from 11:30pm to 5:30am only time our heat pump is on during the winter, the eddi fires up the immersion as well taking the tank to 80c so heat pump isnt wasting time on DHW.
JohnMo Posted Tuesday at 08:02 Author Posted Tuesday at 08:02 I use heat pump all year, if it's not heating it's cooling. Yesterday I paid £1.17 including standing charge, so 67p for all electric. Can live with that.
Dave Jones Posted Tuesday at 08:13 Posted Tuesday at 08:13 point being summer heat pump use is free anyway with excess solar. so its only winter where planning/arbitrage is needed.
sharpener Posted Tuesday at 09:38 Posted Tuesday at 09:38 35 minutes ago, Dave Jones said: point being summer heat pump use is free anyway with excess solar. so its only winter where planning/arbitrage is needed. Not if you are also on Octopus Outgoing at 15p/unit. Then the marginal cost of anything and everything is 12.65 (if in a Cosy cheap period at night) or 15p otherwise as any consumption means you are foregoing the same amount of export. 1
