felix wentworth Posted June 26 Posted June 26 (edited) hi, we recently moved into a victorian house on quite a busy road. the upvc windows are old and not very effective at noise reduction. i fitted a upvc sash with acoustic glass in one of the rooms but turns out it’s not very effective either, it seems as trickle vents don’t help but with further research upvc being hollow isn’t great for sound travelling through it. so now looking at other options. hardwood sash, triple glazed/ acoustic glass or faux sash casement windows, there are so many options out there. want to keep the building traditional, so sash windows ideally. and best for “sound proofing” although nothing is sound proof. Edited June 26 by felix wentworth
JohnMo Posted June 26 Posted June 26 I would concentrate on windows with very good airtightness. Then triple glazed will be better than double for less noise transfer. I would assume wooden windows better than uPVC also. Trickle vents will be needed if you have them now (but only in dry rooms not bathrooms etc), but the normal window people fit stuff that costs 50p and are rubbish. You need to get acoustically damped, but also one that responds to humidity. Something like these - not cheap, but... https://www.bpdstore.co.uk/glidevale-acoustic-energy-saver-humidity-sensitive-trickle-ventilator/p/183 1
Mike Posted June 26 Posted June 26 (edited) After playing with glazing simulators, this spec provides the best sound resistance within a standard frame: 4mm standard laminated / 16mm cavity / 6mm acoustic laminated. See my post at https://forum.buildhub.org.uk/topic/32665-further-sound-insulation-through-bookcases/#findComment-480975 for more. In my case they're fitted in oak frames & perform very well. If I had trickle vents, they would be a key weak point; see @JohnMo's suggestion above (though I'd want more information backing up the sound reduction they're claiming). Getting airtight seals on a vertical sliding sash would be another priority and maybe a challenge (I've not tried). Edited June 26 by Mike 1
nod Posted June 27 Posted June 27 We fitted award winning UPVC sash windows to our previous build Rubbish for sound installation The nature of the mechanism makes this so Stay away from sash My mother-in-law is on a busy road and have basic UPVC and secondary sliding aluminum on the inside Everest I think You can let a firework off under the window and barely hear it 1
JohnMo Posted June 27 Posted June 27 16 minutes ago, nod said: basic UPVC and secondary sliding aluminum on the inside Everest I think You can let a firework off under the window and barely hear it That is a similar spec to additional sound proofing for houses near RAF based.
nod Posted June 27 Posted June 27 1 hour ago, JohnMo said: That is a similar spec to additional sound proofing for houses near RAF based. To be fair I didn’t think a single glazed pain would make that much difference
JohnMo Posted June 27 Posted June 27 3 hours ago, nod said: To be fair I didn’t think a single glazed pain would make that much difference Some reading may be needed Here is the first test results I found. Circa 50dB reduction depending on gap between primary and secondary glazing. Acoustic-Performance-Data-Sheet.pdf 1
ProDave Posted June 27 Posted June 27 I worked on a new build looking directly onto the runway ar RAF Kinloss. ALL the windows facing the runway were triple glazed non opening with no vents whatsoever. All ventilation was achieved by vents and other opening windows on elevations not directly facing he runway. Kinloss closed just a few months after this build was complete.
JohnMo Posted June 27 Posted June 27 3 hours ago, ProDave said: Kinloss closed Kinloss changed from RAF to Army barracks, it didn't close.
felix wentworth Posted June 27 Author Posted June 27 thank you everyone. that’s really helpful, there’s mixed opinions on trickle vents, some saying if it’s a new window then you need to add trickle vents to meet regs, others say, if the window doesn’t have T.Vs then you don’t need to put them in if windows are replaced. it’s well ventilated victorian house if you know what i mean 😂 gappy floors/ doors. i will change that over time but its by no means not going to be well ventilated… and we windows are opened. its tricky regarding sash, the house it traditional so don't really want to go down the route of “modern” windows, but also dont want to pay a fortune for something that isn’t effective at noise reduction. hence faux sash casement …
JohnMo Posted June 27 Posted June 27 14 minutes ago, felix wentworth said: noise reduction Times a good way to reduce noise. We lived in the centre of town, in an 1830s house, well ventilated as well. Single glazed sash traditional windows on the ground floor etc. Bedrooms had to have windows replaced, so we had wooden windows made but with decent seals on the sash and had them double glazed. First six months the house seemed noisy, but you then become noise blind, the background noise just gets blanked out. I would keep the house traditional, no way would I install uPVC windows. Find a local manufacturer of wooden windows get them to make what you want. If you don't have trickle vents now you don't need them. 1
SteamyTea Posted June 28 Posted June 28 I made up my own secondary glazing to cover up my old double glazed windows. The noise reduction was quite amazing. Very rarely does it go above 20 dB now, and I am not far from a busy road. This is what I am hearing at the moment and it is quite breezy outside. 1 1
felix wentworth Posted June 28 Author Posted June 28 thank you @JohnMo you are right definitely true, my gut is well fitted timber DG sash are my best bet, it won’t be silent but as good as it will be without going down a non traditional route. whatever sound is left we will get used to. thanks again
Temp Posted June 29 Posted June 29 When they built the M3 past our house in the 1970s my dad fitted double glazing before they eventually offered to pay for it. We were then told they wouldn't pay for what he had installed because the best gap for noise reduction was 6 inches. So they came and installed Secondary glazing with this big gap so we ended up with triple glazing. My son is away on holiday or I would check with him as he's an acoustics engineer. ChatGPT says... Quote What's the optimum gap between panes of glass to minimise transmission of road noise? Optimal Air Gap for Noise Reduction: 100mm to 150mm (10–15 cm) This range provides the best sound insulation performance for most road noise (especially low-frequency traffic noise). --- Why? Sound insulation improves with wider air gaps, especially for low frequencies (like truck engines or tire noise). Gaps <20mm (common in standard double glazing) are designed more for thermal insulation, not sound. Very large gaps (~>200mm) can become less effective due to resonance effects unless specially designed. --- 🛠️ Better Options Than Standard Double Glazing: Secondary Glazing (adds an internal second pane with 100–150mm gap) is often superior for soundproofing than standard double glazing. Use different glass thicknesses (e.g., 6mm + 4mm) to avoid resonance and improve acoustic damping. --- Summary: Option Air Gap Effectiveness Standard double glazing 6–20 mm 🟡 Moderate (mainly thermal) Secondary glazing 100–150 mm 🟢 Excellent for road noise Triple glazing Varies ⚠️ Often not better unless specially designed for acoustic use
ProDave Posted June 29 Posted June 29 On 27/06/2025 at 22:46, JohnMo said: Kinloss changed from RAF to Army barracks, it didn't close. But there is not much flying there any more. That was my point.
Iceverge Posted June 30 Posted June 30 On 27/06/2025 at 07:51, nod said: Stay away from sash Yup they're rubbish, specifically sliding sash with brush seals. You can get fake ones with the horns that look ok but I'd be looking at compression seals on the windows whatever I did. Have you considered that noise may be coming through the ceiling or from under a suspended floor too?
craig Posted July 5 Posted July 5 Sound protection glazing is a good thing but and this a very important point. What type of noise are you experiencing and trying to block? Through ground sound can be just as noisy as sound through windows or around the window. Changing just the window and not properly specifying the right products around the window, connecting to the structure is paramount to noise reduction (i.e compriband) as well as the correct dB rated window.
