We are just getting our plans drawn up for an icf extension and question came up around window sizes.
Planning to have a 1.5mx1.5m window for a window seat and a 3 meter sliding door. The rest I would say normal window sizes, meeting any regs that required.
Are there any restrictions in terms of size when you use icf? Or can you go crazy ?
Anything to look out for when designing and installing windows in to icf?
If you have large windows could you post dimensions please.
Edited by Markuz
Restrictions ? Yes
Crazy? Within reason - almost
The most difficult windows for us were those that are about 300mm wide : the issue was manufacture of the windows, not how to insert them in ICF.
(In our case Durisol).
4 minutes ago, ToughButterCup said:
Restrictions ? Yes
Thanks very much.
is that a sliding door you have there? Looks great.
19 minutes ago, Russell griffiths said:
how big do you want to go.
thanks very much.
In my view 3 meters sliding door is not too much :D Just have been asked the question why icf and a comment was made on window sizes.
On 18/05/2025 at 10:41, Markuz said:
... Is that a sliding door you have there?
Yes. It's been open all day for the last month.
The other unexpected but massive advantage is that it stops teenage door-slams dead.
This is a question for your structural engineer. We have several large openings, 2x2m corner window, and 4.5m wide bi-folds. The 2x2m was constructed with the ICF and extra rebar in that area, plus a corner post. The 4.5m opening needed a custom made steel box beam with welded plates and a thicker column to support.
No restrictions really but at a certain stage and under specific conditions, an engineer might move towards steel lintels rather than cast in place.
Thanks, we will be talking to SE.
house is not wide enough for 4.5m opening and everything else. 😂
Sadly, we can’t have corner window as on the side there is only a fence to look at. Maybe next time in another house.
  • 3 months later...
We have an 8400 opening. The SE has specified a 457x152x52 beam and we are confirming with window suppliers on their abiltiy to have a sliding door with two sliding panels.
This is interesting from a design perspective. I clocked this as it's a good span in ICF.. and then we have a steel beam.
My thought process is roughly as follows:
ICF is basically an insulated reinforced concrete wall with insulation. Reinforced concrete, if you have a decent height of concrete over an opening can be really efficient structurally. The wall can't be too thin but say it's "normal" 150mm. We don't know what the loads are from above but the 457 deep  beam is likely designed for deflection (critical design condition)  rather than strength.
So the SE has introduced steel. But I then think as designer.. what about fire protection, insulation detailing, cold bridging, insulation fixing to the steels, differential movement between the materials and impact on the external and internal finishes and buildability. All that is going to add to the cost.
This is where you really need to think things through.
Scenario.. often the  SE, (after Grenfell) will pass the fire protection to the Architectural Designer and then they will put some random note on the drawing for the ICF folk to make it work and they will pass it on to you as the Client.. you see the problem?
My gut feeling is to understand why you need steels. If you have a two story building then sometimes we can hang the beam over the door from the ICF wall above, even if there is a modest window above. If only single story then is ICF the right solution?
And 8.4 m door is going to be big bucks so head deflections are critical.
To finish. Your design team need to get together and say.. this is a big area of moving glass so let's start to talk to each other and produce a well thought out design.
For the technical minded:
On concrete buildings we can use a principle called a Vierendeel girder where we look at the whole wall say on a two story building. This is where ICF has advantages over say a timber frame. If it all looks good SE wise you then need to make sure someone can built it and ideally save money.
Again the SE stuff for the steel is probably straight forward but the detailing is where is could all fall to bits. ICF is simple in this respect.
Edited by Gus Potter
8 minutes ago, Gus Potter said:
why you need steels
That was my thoughts also, one of the key selling points is you don't need steel, other than rebar.
8400 opening
Other thought was why do you need an 8.4m wide opening.
two sliding panels
Other was this, for an 8.4m opening?
Agree John.
There a loads of folk that use ICF as self builders and sometimes I look at ICF designs and think.. that does not stack up cost wise. It's forgivable as often folk convince themselves that it's right for them, but with my hard nosed hat on I know that's not the way I
design as I can see it more expensive.
But other times ICF is absolutely the right way to go. As a designer I often look at projects and think, how can I get this built at the budget? It takes experience, it's not that hard though.
One of my key principles is to understand the Architectural design intent, identify what is important in terms the Client requirement, what matters to them, and then check to see if that fits with the planning requirement. That's the way I design as an SE and general designer. The big problem is that folk just don't want to pay for this skill.
One skill a good SE should have is to be able "knock heads together" , bring discipline to the design process. Architects are not good at this in general.
Because that is a Client requirement, what is wrong with realising your dream to have something that is different and a wow factor. Now fair enough, it might turn out that the detailing and buildability is going to be prohibitive cost wise but you have to explore all the design options.
In summary folks if you are thinking ICF also look as how much extra performance you get out of it for a bit of extra rebar. It's almost free money!
