Big Jimbo Posted September 4 Posted September 4 Dont know about Bristol, but sunny Hertfordshire has had plenty of rain. What's the update fella ?
Pocster Posted September 4 Author Posted September 4 1 hour ago, Big Jimbo said: Dont know about Bristol, but sunny Hertfordshire has had plenty of rain. What's the update fella ? Plenty of rain last night for sure . Didn’t witness it . But bone dry 😀 4 1
MikeGrahamT21 Posted September 4 Posted September 4 4 hours ago, Pocster said: Plenty of rain last night for sure . Didn’t witness it . But bone dry 😀 But how dry was the bone? 🤔
Pocster Posted Sunday at 08:35 Author Posted Sunday at 08:35 Storm just now . Pissed down biblical style . Gods final test for me . We have good news and bad …. Water running over the slab I.e the pig leak - seems good ; no leak. Both front upstands leak . This are really low to the roof - not 30cm as recommended but like 3cm worst case . But it’s over the upstands so the seal between roof and window frame . Best to take windows up and refit I think ; tons of structural silicone then smack ‘em down . Clearly this job needs to wait until next summer 😊. SWMBO wanted this room beneath when all the leaks finished , but obviously that can’t happen . What’s another year of stalling !? 1
Pocster Posted Sunday at 09:36 Author Posted Sunday at 09:36 (edited) Strange isn’t it . Had a tiny leak here about 2 yrs ago over the upstand . Bit of expanding foam all golden . Suddenly today …. Still could be worse ! That corner is lowest of them all . So I guess if any are going to leak from the tiniest of holes it would be this one . Rains probably right up to the glass externally ( I can’t see it as decking masks it ) . Edited Sunday at 09:38 by Pocster
Pocster Posted Sunday at 09:47 Author Posted Sunday at 09:47 This thread continues; though if admin could change the title to “ not THAT leak , this leak “ 😂 1
SteamyTea Posted Sunday at 16:00 Posted Sunday at 16:00 6 hours ago, Pocster said: “ not THAT leak , this leek “ Not funny anymore, just like this one.
Onoff Posted Sunday at 16:52 Posted Sunday at 16:52 Why not apply damp proof stuff to the inside faces? 1
Pocster Posted Monday at 05:35 Author Posted Monday at 05:35 12 hours ago, Onoff said: Why not apply damp proof stuff to the inside faces? Because that’s bodging 🥹 1
Pocster Posted Monday at 11:04 Author Posted Monday at 11:04 18 hours ago, Onoff said: Why not apply damp proof stuff to the inside faces? Actually I like this idea more ! I.e less work ! So the upstands are a mix of timber and structural silicon at the top where the frame sits on . So I need something pretty thick and sticky to coat that with . Needs to get in all the gaps . What should I use ?
Onoff Posted Monday at 15:48 Posted Monday at 15:48 4 hours ago, Pocster said: Actually I like this idea more ! I.e less work ! So the upstands are a mix of timber and structural silicon at the top where the frame sits on . So I need something pretty thick and sticky to coat that with . Needs to get in all the gaps . What should I use ? All joking aside, how about a wet room tanking kit? Tape the corners & between the different substrates then paint on the flexible tanking slurry.
Pocster Posted Monday at 16:00 Author Posted Monday at 16:00 12 minutes ago, Onoff said: All joking aside, how about a wet room tanking kit? Tape the corners & between the different substrates then paint on the flexible tanking slurry. Yeah could work 👍
SteamyTea Posted Monday at 16:12 Posted Monday at 16:12 5 hours ago, Pocster said: structural silicon What do you mean by that?
Pocster Posted Monday at 16:15 Author Posted Monday at 16:15 (edited) 4 minutes ago, SteamyTea said: What do you mean by that? Is silicon recommended by the glazing firm to bond glass to frame and frame to upstand . Think it was called ssg4000 ultra glaze or something Edited Monday at 16:16 by Pocster
SteamyTea Posted Monday at 16:23 Posted Monday at 16:23 4 minutes ago, Pocster said: ssg4000 ultra glaze That is just an ordinary silicone sealant, it is the frame and glazing that are structural. I suspect it is a high modulus sealant (don't move much in service), similar to what I used to stick the steam rooms together with.
Pocster Posted Monday at 17:58 Author Posted Monday at 17:58 1 hour ago, SteamyTea said: That is just an ordinary silicone sealant, it is the frame and glazing that are structural. I suspect it is a high modulus sealant (don't move much in service), similar to what I used to stick the steam rooms together with. Just what the company suggested to use
Pocster Posted Monday at 18:34 Author Posted Monday at 18:34 Decision made . Will take them out next summer . Bitumen paint asphalt joints around them . Structural silicone them back in . Delays the job by a year so that’s a win 👍
Onoff Posted Monday at 18:53 Posted Monday at 18:53 Got a pic from above that roof light? Meanwhile throw some more money at it: https://www.maxam.co.uk/maintain-your-property/seek-n-seal/
Big Jimbo Posted Monday at 19:00 Posted Monday at 19:00 Ive heard that works well, @Onoff The glass at the top must have an overhang ? A liberal coat or two of aquaseal or similar on the upstand right up and lapping the glass underside of the overhang.
Big Jimbo Posted Monday at 19:03 Posted Monday at 19:03 That water is coming down the inside of the wood, so right from under the glass. Your posh, fixing the glass down, silicon is letting water by buddy.
Onoff Posted Monday at 19:24 Posted Monday at 19:24 Where's it coming from again? Under the glass, top of the brick or top of the slab? 1
Big Jimbo Posted Monday at 20:13 Posted Monday at 20:13 @Onoff From an earlier photo, i would say from the top, under the glass.
Onoff Posted Monday at 23:38 Posted Monday at 23:38 (edited) Before you rip up the glazing buy some of this and go around the glass to silicone joint. https://www.grime-x.co.uk/product/grime-x-seek-n-seal-windscreen-sealer-sealant-liquid-rubber-silicone-repair/178 Or this: https://www.amazon.co.uk/Captain-Tolleys-Creeping-Crack-sealer/dp/B003T6EJ9A If only for the name! Edited Monday at 23:39 by Onoff
Pocster Posted yesterday at 05:40 Author Posted yesterday at 05:40 10 hours ago, Onoff said: Where's it coming from again? Under the glass, top of the brick or top of the slab? Not 1 or 2 - that was the original problem !! So 3 directly where glazing frame sits on asphalt roof .
