I have ran a 20mm conduit from the inside of my garden room to the outside, with the intention of running the 1.5mm T&E to an outdoor light somewhere nearby. I would like to seal the conduit but I'm not sure how to do that as the conduit won't be going into anything for this fixing. The conduit and cable will be between 38mm battens, and will be behind cladding. I have attached a picture of the conduit which I still need to trim back to behind the batten depth.
I will most likely have to run the cable to it's destination before putting on the external cladding (since the cable will be inaccessible as I build the cladding bottom up), so that means the seal of the conduit would need to be resistant to movement as I work with the cable at its destination. What would you recommend I do?
Thanks!
Edited by plockhart
OR maybe I'm thinking about it wrong. Do I seal the inside of the conduit with silicone around the cable as it enters the backbox, and keep the outside end open so any condensation can drain out? if I plug the outside then maybe that results in a build up of water that can't drain out?
Cut the conduit proud of the membrane by 5mm, Push the cable through with loads of spare, silicon the cable into the conduit and seal the conduit to the membrane, it’s that simple.
if you want to be more thorough you can buy a square of membrane that has a small stretchy area in the middle designed to be placed tightly over pipes and taped onto the membrane.
2 hours ago, Russell griffiths said:
[..] silicon the cable into the conduit [..]
Do you silicone the outside end, the interior end, or go wild and fill the entire conduit 😅
Also do you need to do anything to prevent condensation in the conduit not being able to escape outside?
Thanks in advance.
Thanks all for the additional replies. Some commentary from me:
  1. yes the conduit is on a slight fall
  2. the top and bottoms of the battens will have insect mesh but that won't stop the small stuff getting in I suppose
3 hours ago, saveasteading said:
And allow insects a nice winter hibernation spot. Up to you.
Check under your bed every night before you go to sleep.
Richard Attenborough will be waiting for you, and will pounce when you least expect it. 🥷
Are some folks advocating doing the full length in expanding foam? Presumably the amps is low enough that I don't worry about cable temperature (1.5mm2)?
Nah, a squirt in the end about 30mm or so each end and a very quick trigger, how far into the conduit the foam spreads I don't know.  once two cables are in, the nozzle will only go so far.
Done this on a zillion cables/ pipes in conduit. Squirt it in both ends as the man said last night.
Edited by Pocster
He would spout Shakespeare.
But David would praise you for providing an insect haven.
(expletive deleted) me how can sealing up a poxy bit of conduit turn into some shit show about if it should be sealed on the outside side or on the inside.
FFS  just stick some (expletive deleted)ing silicone in it.
  • Haha 5
Best to overthink everything and then do a 20 second job 🤣
Because it's an easy answer and takes ten seconds. Yours included.
One of Parkinson's laws applies.
There you are that's yet another one.
How do you feel about the 🐞 🐜 🦟 ?
Thanks all! What way up do I insert the silicone tube? Also does it matter if I hold the gun left handed or right handed? Is there a preferred holy day to do this?
  • Haha 3
We must take every question seriously, assuming the enquirer is a complete novice.
preferred holy day
Well,  a tube has one hole or two holes, depending how you look at it.
Smarties only have One hole. It used to have a nice plastic lid, with a letter of the alphabet on the rear, so you could collect them to spell your name. Those were the days.
I used to push the cardboard bottom in to get the flavours out . Not a euphemism
