apricotandpearjam Posted Sunday at 15:48 Share Posted Sunday at 15:48 hi. i buying a flat and we want to do some structural changes and remove some walls to open it up. im in the process of trying to find a structural engineer. in the meantime is there any way of finding out which walls are load bearing from the plans? here are some photos which might help. thankyou! Link to comment Share on other sites More sharing options...
ETC Posted Sunday at 16:48 Share Posted Sunday at 16:48 (edited) Is this a top floor or intermediate floor flat? However I’d say that you’re flogging a dead horse unless you can find out exactly where the floor slabs or roof supports are located. Another thing you need to consider is the creation of a bedroom accessed from a kitchen and opening everything up - the rooms become inner rooms and will need an alternative means of escape and I suspect the existing corridor is a protected corridor - are the existing doors to the bedrooms and existing living room fire doors? However, Building Control should have the original structural floor plans. Edited Sunday at 16:54 by ETC Link to comment Share on other sites More sharing options...
Conor Posted Sunday at 17:02 Share Posted Sunday at 17:02 The beam and piers highlighted pink will undoubtedly be holding ceiling joists and any partition walls above. But, anything is possible, with enough money. Link to comment Share on other sites More sharing options...
Alan Ambrose Posted Sunday at 17:42 Share Posted Sunday at 17:42 (edited) I think those plans you posted are estate agent’s plans no? Take them as ‘artist’s impressions’ rather than anything serious. Call in a good quality builder or an engineer? You can do the tapping thing with your knuckles or drill a tiny hole. An empty ‘cavity’ and a hollow sound almost certainly mean non- load bearing stud wall. Red or grey brick or block dust might mean either. Ask your neighbours if they know? - a structural support will usually run from the bottom of the whole structure to the top. p.s. you often need the freeholder’s permission to monkey with walls, so you might like to sound them out, and it’s possible they have useful info also. Edited Sunday at 17:45 by Alan Ambrose Link to comment Share on other sites More sharing options...
Gordo Posted Monday at 00:58 Share Posted Monday at 00:58 You will need a structural engineer to work out the load paths, but i would imagine they are indeed load bearing. walls and piers supporting substantial beams and possibly concrete floors. If the walls support fire resistant elements they should also be considered structural. Building control will need to be notified regardless as you are changing the means of escape and possibly fire/sound resistant elements. I would imagine you will have difficulties with regards to the means of escape also under BS9991 for flats due to inner rooms situation. I assume the flat is accessed off a common protected corridor. Quite a few things will need consideration and likely too much for a simple forum question/answer. Link to comment Share on other sites More sharing options...
kandgmitchell Posted Monday at 10:28 Share Posted Monday at 10:28 9 hours ago, Gordo said: I would imagine you will have difficulties with regards to the means of escape also under BS9991 for flats due to inner rooms situation. Absolutely - that new bedroom would be cut off from the flat exit by the room with the highest fire risk; the kitchen. The flat was deliberately designed to have it's bedrooms nearer the exit door than the kitchen. I'd also expect that there was a door on the opening from the kitchen onto the inner hallway originally. As to the structural bit, you can just see the arrangement of piers holding up that large ceiling beam. Doing all those changes within a flat is going to be a very big ask. Link to comment Share on other sites More sharing options...
ProDave Posted Monday at 10:53 Share Posted Monday at 10:53 If you really want to add a bedroom, then move the kitchen into the living room, and add a new partition wall to divide what was the kitchen from the now smaller kitchen / diner, with the third bedroom accessed from the hall (reinstating the missing door) Moving the plumbing, particularly waste pipes to do that might be a challenge. 1 Link to comment Share on other sites More sharing options...
torre Posted Monday at 11:04 Share Posted Monday at 11:04 From the beams and piers it looks like someone's already had a go at opening up the layout, I think it would be a challenge to achieve the sort of layout you want, and as others said, you need to avoid an inner room - you could have a long corridor all the way to that bedroom but it's a huge waste of space. I'd try and work within the existing layout as much as you can - how about converting the kitchen area into a bedroom and relocating the kitchen along the fireplace wall or into the area you'd like to place a bedroom? It avoids a lot of structural costs and fire safety headaches as you'd connect to the existing protected corridor Link to comment Share on other sites More sharing options...
