GTM_88 Posted December 19 Share Posted December 19 (edited) A warm hello Alot of my searching and reverse engineering for answers often brings me here, I've noticed alot of ideas get debated here, many other sources of information only entertain doing things "the done way" I red a fantastic post on here recently about using an indirect coil on a cylinder to heat an UFH loop, and the answers provided were very constructive and interesting. There was very good insight not just "no, thats a terrible idea" which makes a very refreshing change. I have to admit, I am abit of an imposter, I am not in a bricks and mortar property, but a liveaboard 60ft narrow boat. Alot of the boat is being built with the same knowledge applied, at least towards insulation, heating and electrics. Very recently I have reverse engineered the basic principle of a thermal store, and installed one into the boat. I will try to help others aswel where I can, I have previous employment in Paint spraying and Plumbing, unfortunately the latter tends to only be common domestic and maintenance areas, rather than all out heating engineering (annoyingly) I've had to self teach myself that having left the occupation sometime ago. I have registered because I am abit stuck when it comes to choosing my wet underfloor heating method and hoping to find some answers or ideas, back when I did my plumbing apprenticeship, underfloor heating was extremely rare. It does exist on boats, but so far I've only found one mentioned, it was apparently very successful so it seems achievable, but I need to get my head around some basic principles first, and the knowledge is obviously fluently applied to houses. Thanks for reading and look forward to contributing Edited December 19 by GTM_88 1 Link to comment Share on other sites More sharing options...
jack Posted December 19 Share Posted December 19 Welcome to BuildHub. What a great intro! As you've seen, lots of our members enjoy getting back to first principles when it comes to working with things like UFH, MVHR, ASHPs and the like, especially where there's a novel angle (like UFH in a boat). 1 Link to comment Share on other sites More sharing options...
Iceverge Posted December 19 Share Posted December 19 Welcome welcome. UFH in a boat! I'm thinking downward heat losses might be an issue. How about warm to touch flooring instead like lino or carpet. Link to comment Share on other sites More sharing options...
GTM_88 Posted December 19 Author Share Posted December 19 (edited) 1 hour ago, Iceverge said: Welcome welcome. UFH in a boat! I'm thinking downward heat losses might be an issue. How about warm to touch flooring instead like lino or carpet. Fingers crossed, I'm hoping I've done enough it won't be a disaster. I've managed to seal the air gap by tucking a layer of 25mm insulation under the edge of the spray foam (where the wall meets the floor) and then a layer of radiant foil, which has a 20mm-ish air gap Infront, then the 18mm plywood subfloor with a layer of 60mm PIR insulation on top. I'm hoping the foil layer with the air gap Infront is going to help. There is ventilation through the bilge (the space under the 25mm) at a different part of the boat. So the second layer, that's 60mm sort of floats almost. Any downward heat loss that comes through the layer of 60mm then has to cross the air gap and make it through the radiant barrier. Edited Thursday at 14:07 by GTM_88 Link to comment Share on other sites More sharing options...
Jilly Posted Thursday at 14:10 Share Posted Thursday at 14:10 Silly question, but do you need a dehumidifier running most of the time in the damp/cold months? Is there some technology you could engineer (sorry side tracked from your ufh qu)? Link to comment Share on other sites More sharing options...
GTM_88 Posted Thursday at 16:01 Author Share Posted Thursday at 16:01 (edited) 2 hours ago, Jilly said: Silly question, but do you need a dehumidifier running most of the time in the damp/cold months? Is there some technology you could engineer (sorry side tracked from your ufh qu)? Very much so, the trouble is I've foiled the entire boat effectively sealing it, it's basically air tight, so Inturn moisture can't escape, I have a meaco 25L dehumidifier which runs from a 48v battery bank. I was looking at installing a MVHR but I decided I couldn't be bothered with the amount of work adding even more time. I'm hoping it's less of an issue in regards to condensation/mould though, because I don't have any surfaces inside that are cold enough for moisture to condense onto, every metal surface is insulated with spray foam insulation with foil insulation over it. in theory moisture in the air can't cool and create excessive moisture build up. Its taken ages to DIY apply three rounds of spray foam insulation messing around with a spray foam insulation kit and heated blankets to warm the bottles. The thinest being about 45mm and I think the walls have ended up being roughly 70mm and it has double glazed windows. It does make a huge difference though when inside is very very warm and you leave a window open, the rising warm air pulls alot of moisture with it. This was another thing that got me onto underfloor heating though was the hope it irons out the rises and falls in temperature and (fingers crossed) means the internal temperature doesn't drop like a brick at times. I've not got gas onboard either so I'm not putting moisture into the air using a gas hob. Edited Thursday at 16:17 by GTM_88 1 Link to comment Share on other sites More sharing options...
JohnMo Posted Thursday at 16:21 Share Posted Thursday at 16:21 14 minutes ago, GTM_88 said: basically air tight, so Inturn moisture can't escape, I have a meaco 25L dehumidifier That fixes humidity, but not the CO2 issue you will have. You NEED ventilation. Your living environment will be bad for your health. Sorry I am going to very blunt - Airtight without ventilation is not a good or smart move. Add a couple of dMEV fans one in kitchen and one in bathroom(s). You then need to allow air in somewhere. 3 Link to comment Share on other sites More sharing options...
joe90 Posted Thursday at 16:33 Share Posted Thursday at 16:33 (edited) Since CO2 is heavier than air, fatalities from asphyxiation have occurred when, at high concentrations, it has entered confined spaces such as tanks, sumps or cellars and displaced Oxygen. (Thinking outside the box…) is it worth a trickle fan extracting air (co2) from floor level where excessive co2 will be highest and incoming (trickle vents) at ceiling/window level 🤷♂️ Edited Thursday at 16:38 by joe90 1 Link to comment Share on other sites More sharing options...
GTM_88 Posted Thursday at 16:37 Author Share Posted Thursday at 16:37 11 minutes ago, JohnMo said: That fixes humidity, but not the CO2 issue you will have. You NEED ventilation. Your living environment will be bad for your health. Sorry I am going to very blunt - Airtight without ventilation is not a good or smart move. Add a couple of dMEV fans one in kitchen and one in bathroom(s). You then need to allow air in somewhere. Noted, good advice. There is mushroom vents in the roof (well, the holes are there) but their sealed at the moment because whoever fitted them made a terrible job of drilling the holes for them. I was on the fence about refitting them but I'll reinstall them, I hadn't thought of C02 build up. Don't have to apologise for sounding blunt John, cracking advice. I think part of BSS (boat safety) stipulates their has to be ventilation but I'm nowhere near the stage yet of thinking about it. It's very much a semi building site at the moment. Link to comment Share on other sites More sharing options...
JohnMo Posted Thursday at 16:49 Share Posted Thursday at 16:49 I have a Greenwood CV2 dMEV fan in a summer house, I had to pull the cover off to see if it was running they make so little noise. Would pull about a 100th of you humidifier electric. 2 Link to comment Share on other sites More sharing options...
SteamyTea Posted Thursday at 17:01 Share Posted Thursday at 17:01 Welcome. I have a bit of experience with boats, my first paying job was at a boat builders, my sister ran a narrow boat scenic trip business for a few years. I have often thought that UFH on a narrow boat is a good idea, but as already mentioned, the temperature difference between the canal water and the floor temperature can be a problem. In reality, there is not much free floor area in a narrow boat, the name is a giveaway. They are really corridors. You could fit an air to air heat pump as that could be easily incorporated with some forced ventilation. The volume is not great. Around 50m3, or 62 kg of air to heat and change every hour or so. A couple of years ago, I made up some internal secondary glazing to cover my double glazing. This has made a huge difference, mainly because I have a lot of glazing compared to wall area (a problem with small buildings). If you can retrofit something, it will help. Acrylic fitted on the outside also stops fishermen breaking your windows. You say you have fitted a thermal store. What sort, size, temperatures and why. Do you use a log burner? What do you do for electrical power? There was a project boat at Birmingham University that was all electric, cheaper BW licences as well. Could have a 'secret' generator on board for when the boat is moored under trees. Where in the country are you based? The canal network is large, even Cornwall has 1.5 miles of canal. 1 Link to comment Share on other sites More sharing options...
SteamyTea Posted Thursday at 17:04 Share Posted Thursday at 17:04 26 minutes ago, GTM_88 said: think part of BSS (boat safety) I think I have a copy of that somewhere, may be a decade old. Link to comment Share on other sites More sharing options...
ToughButterCup Posted Thursday at 17:14 Share Posted Thursday at 17:14 Hello GTM_88 I've lived aboard boats - usually ex-MFVs - in the 1970s. The only way I (we) found to keep things 'straight' was to throw masses of heat at the problem, and have a similarly massive through-put of air. That way books didn't go mouldy, and shoe leather retained a passably polished sheen. Hence the several tonnes of coal in the bilges, and two iron stoves. A Webasto diesel heater in the Dog House helped too. Wimmin : all - each and every one - who came aboard for any length of time always complained about the draught. One way of dealing with CO and CO2. Nowt to be done about the ducks hammering the weed off the waterline though. 1 Link to comment Share on other sites More sharing options...
MikeSharp01 Posted Thursday at 17:46 Share Posted Thursday at 17:46 6 hours ago, GTM_88 said: underfloor heating was extremely rare Welcome to THE forum for people like us - although, to be fair, I don't live on a boat! The thing about underfloor heating is that it is one of the oldest heating technologies, other than an open fire, being developed by the Romans - now if I know my Romans you can bet that some mad Caesar asked for a heated floor in their 'barge'! 2 Link to comment Share on other sites More sharing options...
GTM_88 Posted Thursday at 20:37 Author Share Posted Thursday at 20:37 3 hours ago, SteamyTea said: Welcome. I have a bit of experience with boats, my first paying job was at a boat builders, my sister ran a narrow boat scenic trip business for a few years. I have often thought that UFH on a narrow boat is a good idea, but as already mentioned, the temperature difference between the canal water and the floor temperature can be a problem. In reality, there is not much free floor area in a narrow boat, the name is a giveaway. They are really corridors. You could fit an air to air heat pump as that could be easily incorporated with some forced ventilation. The volume is not great. Around 50m3, or 62 kg of air to heat and change every hour or so. A couple of years ago, I made up some internal secondary glazing to cover my double glazing. This has made a huge difference, mainly because I have a lot of glazing compared to wall area (a problem with small buildings). If you can retrofit something, it will help. Acrylic fitted on the outside also stops fishermen breaking your windows. You say you have fitted a thermal store. What sort, size, temperatures and why. Do you use a log burner? What do you do for electrical power? There was a project boat at Birmingham University that was all electric, cheaper BW licences as well. Could have a 'secret' generator on board for when the boat is moored under trees. Where in the country are you based? The canal network is large, even Cornwall has 1.5 miles of canal. We literally call it "the mobile corridor" 😆 the thermal store started as a 180 litre copper vented cylinder with twin indirect coils, it was brand new but sold very cheap so I snapped it up. I've brazed in three direct tappings, two 3/4" for the woodburner, one at the bottom and the other roughly two thirds up, and the other is a 1" that sits more or less in the middle. The woodburner will plumb direct, the 1" connection takes a DC water heating element (for solar load diversion) the first indirect coil will be a Eberspacher D5WSC, second coil will be linked to the boat engine and there's a mains immersion element in the top. I've had a stainless header tank fabricated for it thats sealed from the inside of the boat but has a 1.5" vent to outside on the roof, also an overflow. The secondary hot water comes from a plate heat exchanger and the heating will also be sealed from another plate heat exchanger. The main reason for the thermal store was the woodburner needed to be open vented but I wanted a sealed pressurised heating loop and also it gets around crap hot water pressure like with a header tank setup. I have seen alot of boats with copper cylinders with a PRV banged on top instead of the open vent 😂 slightly amusing, like an poor attempt at an unvented cylinder 😂 by heck you'd not be popular if you did that in a house.... I did wonder about having polycarbonate circles cut for the portholes to increase security, the boat is all portholes. Power wise I've got two 48v 280ah lithium batteries, 2250watts of solar, victron mppt and victron Multiplus2 48/8000/110 inverter charger, and I've fiddled with the beta marine 175amp alternator, it works in AC to start with and is wired to external rectifiers with a cap which then goes through another MPPT solar controller to charge the 48v batteries from the engine. There's also a 6KVA diesel generator fitted to the right of the boat engine that I've been running on veg oil with a separate tank. What I really want to do is automate the generator through the Multiplus2, I have managed to build an Arduino that starts the diesel generator but it needs way more fiddling. I very briefly looked at electric drive but I really wanted to own a mechanical beta marine engine because I love mechanical diesels. I have since seen hybrid setups where it's both diesel and electric, it would be fun to try and pull that off. I'm based in Leicestershire. Link to comment Share on other sites More sharing options...
Mike Posted Thursday at 21:31 Share Posted Thursday at 21:31 5 hours ago, JohnMo said: That fixes humidity, but not the CO2 issue you will have. You NEED ventilation. Your living environment will be bad for your health. Sorry I am going to very blunt - Airtight without ventilation is not a good or smart move. 51 minutes ago, GTM_88 said: I've brazed in three direct tappings, two 3/4" for the woodburner And if you have a woodburner you're at a high risk of carbon monoxide poisoning too, unless it has its own separate air supply. Don't use it until you have adequate ventilation. Link to comment Share on other sites More sharing options...
GTM_88 Posted Thursday at 22:02 Author Share Posted Thursday at 22:02 (edited) 4 hours ago, ToughButterCup said: Hello GTM_88 I've lived aboard boats - usually ex-MFVs - in the 1970s. The only way I (we) found to keep things 'straight' was to throw masses of heat at the problem, and have a similarly massive through-put of air. That way books didn't go mouldy, and shoe leather retained a passably polished sheen. Hence the several tonnes of coal in the bilges, and two iron stoves. A Webasto diesel heater in the Dog House helped too. Wimmin : all - each and every one - who came aboard for any length of time always complained about the draught. One way of dealing with CO and CO2. Nowt to be done about the ducks hammering the weed off the waterline though. Get it so hot in there your sat with the door wide open when there's snow on the ground? 😂 Was that in an older boat with sheet insulation spaced from the hull or was it more recent and insulated differently? Ah man the bloody ducks scared the living crap out of me doing that at 2am! not long after I first got the boat 😐😆 I had no idea what it was 😐 😂😂😂 my mooring is very out the way in fields, pitch black and noone around. I sat there petrified for 10mins before working up the guts to stick my head outside and look what it was tapping on the side of the boat! 🤦 And there's this duck looking back at me 😂 Edited Thursday at 22:06 by GTM_88 Link to comment Share on other sites More sharing options...
twice round the block Posted Thursday at 22:04 Share Posted Thursday at 22:04 (edited) Slightly concerned about the amount of insulation you've put into every void inside the cabin space to lift the temperature when your diesel tanks are below or just on the waterline getting chilled with the outside temperature. This will cause excess condensation to your tank's and even more water in your fuel. I know or hope you've got a water separator in-line, but it won't help with the rapid increase in contamination of your fuel in your tank's. So by curing one issue you could be creating another for your self. Please don't install a hybrid unit over the top of your gearbox / final drive as it causes a major strip down just to change a control cable.!!! Back ground. Factory marine technician and a few year's working for river canal rescue when I got bored after taking early retirement. Edited Thursday at 22:09 by twice round the block 1 Link to comment Share on other sites More sharing options...
GTM_88 Posted Thursday at 22:24 Author Share Posted Thursday at 22:24 (edited) 35 minutes ago, twice round the block said: Slightly concerned about the amount of insulation you've put into every void inside the cabin space to lift the temperature when your diesel tanks are below or just on the waterline getting chilled with the outside temperature. This will cause excess condensation to your tank's and even more water in your fuel. I know or hope you've got a water separator in-line, but it won't help with the rapid increase in contamination of your fuel in your tank's. So by curing one issue you could be creating another for your self. Please don't install a hybrid unit over the top of your gearbox / final drive as it causes a major strip down just to change a control cable.!!! Back ground. Factory marine technician and a few year's working for river canal rescue when I got bored after taking early retirement. I've read that afew times man and I'm trying to picture the logic but struggling abit, does warm air from the cabin have to reach the side of the fuel tank for that to happen? does it make any difference the boat is trad stern and my fuel tank is right at the back integral to the hull/stern. There's a bulkhead between the engine bay and cabin with the door shut basically all the time, the stern area is bloody freezing compared to the rest of the boat and all still bare metal, but very dry I've never seen any condensation on the end where the fuel tank is... does that make any difference? I haven't ran the engine for a hell of along time, basically just to move it once and mess about with the electrics afew times during the summer. It hasn't moved off it's mooring since I've been fitting it out. Now you mention this however... I did get diesel bug in my generator fuel tank and I drained the tank, refilled and put some treatment in. There is a water separator on the engine yes. Edited Thursday at 22:42 by GTM_88 Link to comment Share on other sites More sharing options...
twice round the block Posted Friday at 12:22 Share Posted Friday at 12:22 If your boat is of steel construction and not traditional build the extra heat you generate within your nearly air tight pod will feed through to the hull and head immediately to the coldest area's ie. the uninsulated area of the boat. The stern where your engine bay and fuel tanks are. You will always get moisture inside metal fuel tanks, hence why new builds use polymer tanks. If the boat is of traditional timber construction this allows your hull to breath, and the build up of heat dissipates differently. 1 Link to comment Share on other sites More sharing options...
CaptainDram Posted Friday at 17:27 Share Posted Friday at 17:27 On 19/12/2024 at 16:33, joe90 said: Since CO2 is heavier than air, fatalities from asphyxiation have occurred when, at high concentrations, it has entered confined spaces such as tanks, sumps or cellars and displaced Oxygen. (Thinking outside the box…) is it worth a trickle fan extracting air (co2) from floor level where excessive co2 will be highest and incoming (trickle vents) at ceiling/window level 🤷♂️ If CO2 sinks to the bilge you can use the bilge pump to clear it out but a bit of a pain to have to manually trigger it all the time. Link to comment Share on other sites More sharing options...
joe90 Posted Friday at 17:42 Share Posted Friday at 17:42 10 minutes ago, CaptainDram said: If CO2 sinks to the bilge you can use the bilge pump to clear it out but a bit of a pain to have to manually trigger it all the time. However the bilge pump is a water pump not an air pump, better IMO to use an air pump (above bilge water level) to clear any co2 which will in effect drag air from outside at ceiling level or wherever to replace it and give ventilation rather than a fan pushing air into the living space which will not get rid of any co2 or other nasties. Link to comment Share on other sites More sharing options...
SteamyTea Posted Friday at 18:34 Share Posted Friday at 18:34 CO2 has a density of 1.98 kg.m3, nitrogen 1.25 kg.m3, oxygen 1.33 kg.m3, so while it is more dense, normal air movement will stop it settling. This is not the same as changing the concentration from 420 ppm to say 30,000 ppm, which will cause problems after 10 minutes. Assuming no fault with the wood burner, the diesel motor and any combusted gas from cooking, CO2 in a narrow boat should not be an issue, they don't have bilges like an ocean liner or a sail boat. They are more like a floating cake tin. But all wood burners are killers, so some precaution needs to be added in. Link to comment Share on other sites More sharing options...
jack Posted Monday at 18:54 Share Posted Monday at 18:54 @GTM_88, I've moved your original post to the underfloor heating subforum, as it's turned into a heating discussion rather than an intro. You're likely to get more input here, as a lot of members don't monitor the Introductions subforum. There's a link to the new thread location in the Introductions subforum, so people who've already replied can find the thread easily. Link to comment Share on other sites More sharing options...
