BotusBuild Posted December 8, 2024 Posted December 8, 2024 Good idea or just plain stoopid? Â I like the idea, SWMBO is persuaded. Â Am I missing something apart from dropping my mug of tea with the predicted outcome?
nod Posted December 8, 2024 Posted December 8, 2024 I don’t get asked for quarry tiles anymore But they are bombproof  1
joe90 Posted December 8, 2024 Posted December 8, 2024 I did my porch in quarry tiles and they looked fab and bomb proof 3 hours ago, BotusBuild said: dropping my mug of tea with the predicted outcome? Frankly any tile will do the same. 1
joe90 Posted December 8, 2024 Posted December 8, 2024 1 minute ago, BotusBuild said: Other option is resin. Thoughts? Depends on what “look” you are after, I did “cottage” and quarry tile was perfect, however inside a plant room should be “fit for purpose” not “design statement”. 🤷‍♂️
BotusBuild Posted December 8, 2024 Author Posted December 8, 2024 3 minutes ago, joe90 said: however inside a plant room should be “fit for purpose” not “design statement”. Agree with that. So, either would do?
joe90 Posted December 8, 2024 Posted December 8, 2024 2 minutes ago, BotusBuild said: Agree with that. So, either would do? I guess so but I know ziltch about resin (is it hard wearing fir a plant room floor 🤷‍♂️)
Russell griffiths Posted December 8, 2024 Posted December 8, 2024 I used a 20mm screed to bring the room up to the height of the other rooms and painted it with garage floor paint. the time all the cylinders are in there and water softener and all the other junk, there’s hardly any floor visable. 1
BotusBuild Posted December 8, 2024 Author Posted December 8, 2024 58 minutes ago, joe90 said: is it hard wearing fir a plant room floor Used on garage floors, so I think so🙂 1
Conor Posted December 8, 2024 Posted December 8, 2024 Our plant room is still bare screed nearly three years in. Can't see it changing.
JohnMo Posted December 8, 2024 Posted December 8, 2024 33 minutes ago, Conor said: Our plant room is still bare screed nearly three years in. Can't see it changing. Our is caberboard with carpet off cuts. If you have any plumbing in there, anything not damaged by some water being split is fine.  4 hours ago, BotusBuild said: Other option is resin. Thoughts? If your plant room is off the utility, just do it in the same as the utility  It's a plant room
scottishjohn Posted December 8, 2024 Posted December 8, 2024 (edited) maybe i,m stingy but did my plant + boot room room in industrial vynl simple to keep clean Edited December 8, 2024 by scottishjohn
BotusBuild Posted December 11, 2024 Author Posted December 11, 2024 Right, resin is a no-goer according to the Epodex website. Minimum temp for use - 150. Recommended temp 200. As the floor standing stuff is due for install next month, those temperatures are not going to happen Quarry tiles it is 🙂 1
BadgerBodger Posted December 11, 2024 Posted December 11, 2024 I think I’m going to be using an epoxy paint. Either a one part like crown epimac or maybe a two part like watco plant room coating. We’ve been using the resbuild SF with texturising additive for some industrial applications with plant usage that seem to hold up. Much cheaper than a “resin” floor finish with a couple of mm build-up.
