Adsibob Posted October 26, 2024 Posted October 26, 2024 I have a boiling hot water tap which has broken. Upon consulting the manufacturer, they identified that I need to change a valve, which they have sent me. It requires a 17mm socket. So out I went to screwfix and bought this: https://www.screwfix.com/p/forge-steel-3-8-drive-socket-set-18-pieces/917pg But the problem is the socket is only about 12mm deep and that’s doesn’t reach deep enough to make contact with the hexagonal valve. This is incredibly frustrating. i can return this socket wrench, but need an alternative please.
ProDave Posted October 26, 2024 Posted October 26, 2024 https://www.ebay.co.uk/sch/i.html?_nkw=17mm+deep+socket+3%2F8&_sop=15 If you have a motorists shop near you they should have one to save you the wait for one to be delivered.
Alan Ambrose Posted October 26, 2024 Posted October 26, 2024 You should be able roughly measure what length you need. Something like this https://www.amazon.co.uk/Siegen-S0595-Drive-WallDrive®-Socket/dp/B000ROB1AM/ref=asc_df_B000ROB1AM/
Adsibob Posted October 26, 2024 Author Posted October 26, 2024 5 hours ago, Onoff said: 3D print a long 17mm socket. Brilliant idea. All I need is a 3D printer and some print medium. And a design.
Alan Ambrose Posted October 27, 2024 Posted October 27, 2024 Go old school and use a 17mm box spanner. 1
SteamyTea Posted October 27, 2024 Posted October 27, 2024 1 hour ago, Alan Ambrose said: Go old school and use a 17mm box spanner. Stillsons
marshian Posted October 27, 2024 Posted October 27, 2024 2 hours ago, Alan Ambrose said: Go old school and use a 17mm box spanner. Some spark plugs are 17mm so it shouldn’t be hard to find a box spanner or a spark plug socket - they are extended length
Conor Posted October 27, 2024 Posted October 27, 2024 I think you can still buy individual sockets in Halfords, and they do deep ones as I've a 80mm deep 17mm socket from there. And great quality.
Onoff Posted October 27, 2024 Posted October 27, 2024 9 hours ago, Adsibob said: Brilliant idea. All I need is a 3D printer and some print medium. And a design. Quite happy to print you one and post it to try. How long would you like it? How do you want to turn it, via a ratchet or bigger spanner / adjustable etc? Any restriction on the overall "socket" diameter? A thicker wall makes it stronger. For example: https://www.printables.com/model/529829-17-mm-steckschlussel-mit-antrieb-fur-eine-14-ratsc https://makerworld.com/en/models/45841#profileId-47643 1
dpmiller Posted October 27, 2024 Posted October 27, 2024 before going down any 3d printing rabbitholes, how tight in the bleedin thing? How about a nice photo for us to help...
Onoff Posted October 27, 2024 Posted October 27, 2024 19 minutes ago, dpmiller said: before going down any 3d printing rabbitholes, how tight in the bleedin thing? How about a nice photo for us to help... A squirt of penetrating oil I'm sure would help whatever, a few days before unscrewing.
SteamyTea Posted October 27, 2024 Posted October 27, 2024 3 hours ago, Onoff said: A squirt of penetrating oil I'm sure would help whatever, a few days before unscrewing. Unlike a pregnant woman, you can unscrew a tap (or a light bulb).
Adsibob Posted October 28, 2024 Author Posted October 28, 2024 On 27/10/2024 at 07:58, Onoff said: Quite happy to print you one and post it to try. How long would you like it? How do you want to turn it, via a ratchet or bigger spanner / adjustable etc? Any restriction on the overall "socket" diameter? A thicker wall makes it stronger. For example: https://www.printables.com/model/529829-17-mm-steckschlussel-mit-antrieb-fur-eine-14-ratsc https://makerworld.com/en/models/45841#profileId-47643 Wow that is very kind. I’ve managed to sort it now, but thank you.
Onoff Posted October 28, 2024 Posted October 28, 2024 8 minutes ago, Adsibob said: Wow that is very kind. I’ve managed to sort it now, but thank you. 3D printed tools are very real and practical now. Clutch alignment tool: Subframe alignment pins: Helical milling jig: https://flic.kr/p/2onf1Lz 2
Pocster Posted October 28, 2024 Posted October 28, 2024 1 hour ago, Onoff said: 3D printed tools And you’ve printed plenty of those !
Onoff Posted October 28, 2024 Posted October 28, 2024 18 minutes ago, Pocster said: And you’ve printed plenty of those ! One was the dead spit of you funnily enough... 1
SteamyTea Posted October 30, 2024 Posted October 30, 2024 On 28/10/2024 at 17:49, Onoff said: Clutch alignment tool: AKA a butplug.
