Rubber grommets for knockouts
jpadie
I'm using some Screwfix surface mounted pattress boxes to add some sockets to a ring main in the garage.  These are they.
The manufacturer data that came with them says to use rubber grommets for the knockouts. But LAP don't make any such grommets and I've not idea how they would fit to the knockouts for flat cable.
Any thoughts on these?  Are they a regs requirement?  Could I just fill the 1mm gaps around the cable with silicon or another filler?  I think the plastic is far weaker than outer insulation on 2.5 t&e so I can't see abrasion being a big
issue.
1 hour ago, FuerteStu said:
If they are round knockouts, you could use a stuffing gland for cable entry.
Far cleaner looking, and at least helps the ip rating
They're these:
Hilarious that the LAP instructions say to use rubber grommets. LAP btw are a Kingfisher (they own Screwfix), own brand.
19 hours ago, Onoff said:
They're these:
Absolutely despise these patresses.
Crumbly sharp cable entry points, the slightest knock and they crack.. Even mounting on an uneven surface and tightening the screws can cause them to implode!
+1
With a passion.
  • 4 weeks later...
The PVC ones usually sold as "conduit back boxes"  They are a softer plastic that won't break they will just bend a bit.  Usually have a knock out for 20mm round conduit or small mini trunking, and in any case can be drilled, sawn or filed for any other cut out you want.
superb.  will look out for them and maybe even swap them out the next time I have a free Sunday.  I didn't like the jaggedy edges of the last lot either!
Personally and in my garage I use metal back boxes and plastic conduit to at least head height, some might say it’s OTT but it looks so much neater… 🤷‍♂️
very neat @joe90.
in my garage the sockets are on the roof joists as the walls are all taken up with racking.  wiring is stapled to the joists or through the air (above head height) when traversing.
