Dee J Posted November 11, 2017 Posted November 11, 2017 Accessing the hive brain again ;-) I need a large scale map to mark on new land boundaries for land registry and purchase contract purposes (mainly to plot a new fence line). The gold solution is to hire someone to survey the site and produce a scaleable data map which will work with online systems. The basic solution is to use existing bad photocopies and sketch in the reference points and measurements by hand. A good midway solution is what I'm looking for. Purchase a map online and use some common software to mark it up. What format should I get the map in, and what software to use? Thanks Dee
ToughButterCup Posted November 11, 2017 Posted November 11, 2017 3 minutes ago, Dee J said: [...] I need a large scale map to mark on new land boundaries for land registry and purchase contract purposes (mainly to plot a new fence line [...] Its really easy. Big-ish photocopy of a map showing the relevant features , mark your plot and anything else needed. Send to the Land Registry. Software? Pen and paper will do fine.
Russell griffiths Posted November 11, 2017 Posted November 11, 2017 I personally would go for the full topography survey, you may be surprised that there not that dear. Why. Because you will use it a load more than you think you can send it electronically to anybody who needs it you will need one if you need a flood risk assessment you can give it to the surveyor to mark out the location for the new house you can give it to the Groundworks guys to set out drains etc etc ours cost £600 but our site mapped was aprox 400m by 100m and consisted of aprox 1200plotted points it would be the first thing I would do if buying another piece of land.
Jeremy Harris Posted November 11, 2017 Posted November 11, 2017 (edited) I'd also go for a topo survey, plus buy the map section from the OS as a base map (your topo surveyor may do this for you - I supplied mine with the OS base map). The big advantage is that both the OS base map and the topo survey will be in digital format (ideally choose something universal, like .dxf) and so can be read into any CAD software and used to accurately put a whole stack of drawings together. You can print a .dxf file as a .pdf if you need to. You can do your own flood risk assessment, it's not hard and the data is available free from the EA if you ask. I used one master base map, from the OS (not expensive) and then very accurately (to the mm) overlaid things like the topo survey, the ground works layout of drains, walls etc, boundary locations, master reference points for laying out, the house and garage outline plan drawings for planning permission, the site drawings for planning permission, the site location drawing for planning permission, the detailed drainage and services drawing for build regs approval, and even now I'm still using that master plan for positioning the planting of screening and ornamental trees along one boundary and doing the detailed garden design. I also used it to produce CCTV sight line drawings, to show that our CCTV was (at least originally) only looking at areas within out own boundary. It's incredibly useful to have one, super accurate (within a few mm) base plan, far more useful than I would have thought initially. Our topo and boundary survey cost £450, but I provided the surveyor with my licensed copy of the OS base map that I purchased on line from the OS. Edited November 11, 2017 by JSHarris
SteamyTea Posted November 11, 2017 Posted November 11, 2017 There are a number of software packages, GIMP is one, as is Inkscape. (both free and available as portable versions). If you like CAD you can use LibreCad, again a free download and portable. But I like Ian's suggestion. Pen and Paper.
Ferdinand Posted November 11, 2017 Posted November 11, 2017 3 hours ago, Dee J said: Accessing the hive brain again ;-) I need a large scale map to mark on new land boundaries for land registry and purchase contract purposes (mainly to plot a new fence line). The gold solution is to hire someone to survey the site and produce a scaleable data map which will work with online systems. The basic solution is to use existing bad photocopies and sketch in the reference points and measurements by hand. A good midway solution is what I'm looking for. Purchase a map online and use some common software to mark it up. What format should I get the map in, and what software to use? Thanks Dee Normal Land Registry boundaries are subject to a General Boundary Rule , which means "-ish", which is why they rely on boundary features. ish is plus or minus a couple of feet. So carefully drawn identifiable-if-someone-visits boundaries on paper are OK.
le-cerveau Posted November 11, 2017 Posted November 11, 2017 Go for the full topo, mine cost £475, including the existing house (demo-rebuild) and the relevant details of the neighbours houses (extremely sefull when we had to prove we wernt overbearing and overshadowing). This formed the base for all the designs there on.
Ferdinand Posted November 11, 2017 Posted November 11, 2017 (edited) You need to be clear whether this is for Land Reg or Planning. The latter needs a full topi of your site to know where to build it. The former just to be able to identify your Land. Planning will believe your statements about the location of your boundaries, and leave it up to you and your neighbour if you are building in their garden. Edited November 11, 2017 by Ferdinand
Dee J Posted November 11, 2017 Author Posted November 11, 2017 Thanks all. The primary purpose is a mix of land registry and land purchase contract. Boundary is agreed on the ground with the seller. Just needs someone to put it on paper... and if I want to get things moving the someone=me. The main plot is defined by existing boundaries, this is for the access driveway only. Anyway, bought an online pdf map, converted to jpeg and filling in using MS paint. Slow and old-school, but no learning curve.
Stones Posted November 11, 2017 Posted November 11, 2017 +1 for a topographical survey. Very useful thing to have for planning purposes, setting out and further down the line when considering landscaping.
