I used 75/80mm concrete screws to fix battens straight to block wall. Can’t comment how it works through insulation, suggest you test on a sample area.
11 hours ago, Firsttimer said:
We are struggling to get an answer as to what screws we can use to fix the batons for our cladding.
We have 100mm of external insulation.
Does anyone have any advice / view ?
I was planning on using these.
 https://www.orbitalfasteners.co.uk/products/7-5-x-180mm-timco-multi-fix-concrete-s
crew-zinc-and-yellow-00180tcon
I’m doing same but through 180mm of insulation so am using these  in 280mm
https://timberfixings.com/7-4-x-280mm-TX40-Blue-Power-Timber-to-Masonry-Screws-Box-of-100-p141878564
they are expensive but specially designed for the job
They do shorter lengths
10 hours ago, Conor said:
Is this an ICF build? Why aren't you screwing in to the plastic webs?
Yes, it's ICF. With our blocks there's no way to visibly tell from the exterior where the webs might be and I'm not sure the web spacing inside is uniform enough to be able to measure out where they might be.
I'm now wondering if we could find them with a stud finder 🤔
What are you blocks and what is your wall build up?
40 minutes ago, Firsttimer said:
, it's ICF.
Surely there is a standard detail from the icf manufacturer?
A 100mm screw through eps will be susceptible to bending under cladding weight.
Fix one of these as a test, then hook on a claw hammer and hang off it. I think it will bend. The whole cladding skin could droop.
180mm mentioned above too. ! It is just a bit of wire through eps.
I was once keen to try eps structures but never did, and am out of touch now. Please post the manufacturer's detail if you find it.
Look at the manufacture details, you only need to find one plastic Webb, the others will be spaced the exact distance apart that the factory made them.
they haven’t moved, some icf have vertical webbs and some have horizontal.
find one and it’s just a bit of measuring to find the rest.
Not with screws in the post I linked, they are designed for the job
I’ve screwed through 180mm of insulation and believe me once the batten is tight to the EPS it won’t droop. I checked with the ICF manufacturer and the screws manufacturer,
Theres someone else on here who’s done it with heavier cladding than mine
The James Hardie VL plank is about 11kg a square meter so with battens and screws at 500mm centres plenty strong enough
OK that is interesting. Tempered steel, close fixings?   I'd still like to see someone testing  a 150mm projecting one.
Here’s the data sheet
https://app.nextpim.de/Cloud/6118eacef55a4834b44c3623/a3ba70a2-990d-432c-fb8c-08d79e6bb09c/Product_data_sheet_Blue-Power_Systemschraube_EN_06_2023.pdf
like I said mine are 280mm through 180mm insulation and I’m happy with them.
The tech team at eurotec said I could use 600mm spacing for the screws but it was easier for me to use 500mm so even stronger
Edited by Chanmenie
If you think about it each screw only has about 2-3 kg hanging from it.
Always a good idea. Lighter cladding and closer centred fixings than I imagined perhaps.
He said cladding was 11 kg a metre, add in 3m of roof batten.
call it 15-18kg all in, divide by 9 fixings.
under 2kg per fixing.
1 hour ago, saveasteading said:
9 fixings /m2. OK that's a lot of fixings.
Yeah I’ll know about when I’ve finished it all, drilling through 180mm EPS and 25mm batten then 75mm into c35 concrete is a chore, it’s difficult to clear the spoil so when you push the screw in it pushes the spoil back in the hole and binds the screw.
Gonna try a length of brake pipe attached to a blow gun with a compressor and blow the holes out
We are using Izodom - 100mm EPS on the exterior, 25mm vertical batons, 25mm horizontal batons and 20mm cladding.
Yes. But the tricky bit is that the blocks haven't always been put in the same way up and when a new block starts this throws off the pattern
Edited by Firsttimer
So would I after say 3 months once the insulation has compressed / suffered from creep.. then you lose the friction that intialally makes it seem solid. Also if using timber battens the timber shrinks and that too further reduces the friction resistance.
After that you are relying on the bending capacity of the fixing alone..
Edited by Gus Potter
What type of cladding are you fixing.. can you do us a wee sketch of what you are thinking about doing?
What a nightmare. I've looked at that systems photos and see what you mean.
How are going to plasterboard the inside if you can't find webs easily?
@Chanmenie
That sounds like a complete pain.
I've been picking through my brain for ideas to save work. Cladding over thick external forum has been a debate on US forums for years.
1. You could build an independent metal or timber frame external to the ICF.
2. Maybe even a block wall.
3.Perhaps locate some kind of powder driven fixings that would penetrate all that EPS and concrete.
4. You could independently support the vertical battens at the top and/or at the base to take the vertical load reducing the need for so many fixings.
Unfortunately the best answer I can think of is to install the vertical battens pre pour with long screws and let the concrete take care of the rest.
8 hours ago, Iceverge said:
@Chanmenie
Yeah that might have worked, but at the time I built and concreted the gable ends I was going to have them rendered.
Still if my compressor and pipe works it won’t be so bad.
Because of the big windows in the gable ends there’s actually not that much cladding to fit
