Hi All
I need to install a temporary (at least a year) fence around 1.2m high and no longer than 8m in length just to keep a small down in my garden
I have been scouring the internet but i wanted to avoid concreting any posts in as this will be moved this time next year when we landscape the garden etc..
I was thinking just some knock in posts and wire mesh pinning on...would this be suitable?
Could anyone recommend any other ideas at all? Even knock in fences as a whole but the there is a slight fall on the ground
Apologies for  the random question but hopefully one of you guys would of been in the same position and have some insight
I had to create a temp fence on my build about the same size for root protection, I used farmers fence posts and sheep fencing, council tried to get me to get an arborist survey done (more money) but i rang the councils own arborists, told him what I did and he agreed it was fine then told the council their own chap agreed. Job done.
Round posts or splits rammed in to the ground with PVC coated stock fencing. We did this to protect some steep falls / slopes and did the job well.
Just for clarity and best advice, what do you need to keep in your garden?
a small what?
will plastic mesh do the job? It may need replacing after 6 months as not all of it can stand sunshine. It can be in green or blue. You can pin it down with tent pegs.
Vigil Products Orange Barrier Fencing - 50 metres VP-BF4-50
3 minutes ago, Pendicle said:
+1 for chestnut paling fencing
Yes but I found it expensive (if it’s temporary)
I just knocked posts in to ground, ran three lengths of wire top, middle and bottom and infilled with orange dayglow mesh cable tied to the wires.
