Novice Becky Posted May 8 Share Posted May 8 @craig or anyone. Can anyone suggest a supplier for Illbruck TP654 88mm/6-15 all-in-one tape? Sealants online are out of stock for 4-6 weeks (I need it in 5 weeks). Dortech don't stock 88mm (just 58 and 66mm). Nothing else comes up on a search. I need deep tape as the timber windows are 95mm thick. Thanks Link to comment Share on other sites More sharing options...
craig Posted May 8 Share Posted May 8 Hi Can you drop me a message with how many metres you require and I'll give you a price direct from Illbruck and a timescale. Thanks Craig 1 Link to comment Share on other sites More sharing options...
Tosh Posted May 8 Share Posted May 8 36 minutes ago, Novice Becky said: I need deep tape as the timber windows are 95mm thick. Couldn't you use a narrower compriband tape and make the difference up with air tight expanding foam? Both more readily available......and possibly cheaper. 1 Link to comment Share on other sites More sharing options...
Novice Becky Posted May 8 Author Share Posted May 8 Thanks @Tosh. You're right - TP654 does look pricey on the surface. I'm going to use TP600/FM330/ME508 on a door but because of the roll lengths it actually works out about the same price to use TP654 on 2 windows - and sounds like a much quicker job and less making good after (this is a retrofit). Good to try something new! If I can't get the TP654 then I'll use Compriband. Link to comment Share on other sites More sharing options...
Tosh Posted May 8 Share Posted May 8 55 minutes ago, Novice Becky said: Thanks @Tosh. You're right - TP654 does look pricey on the surface. I'm going to use TP600/FM330/ME508 on a door but because of the roll lengths it actually works out about the same price to use TP654 on 2 windows - and sounds like a much quicker job and less making good after (this is a retrofit). Good to try something new! If I can't get the TP654 then I'll use Compriband. The expanding tape is amazing stuff, often with a price to match! By the time we're finished I wouldn't be surprsied if we've spent £5-600 on compriband, foam, etc around our doors/windows. How will you apply this very wide tape into a small gap and press it onto the frame? We had mostly 10mm gaps and I found even a 20mm deep tape to be quite fiddly to install, but then the reveals on ours are very deep which didn't help. I found a scrap piece of thin, soft metal that I bent to shape to help press it home against the frame. Link to comment Share on other sites More sharing options...
Novice Becky Posted May 8 Author Share Posted May 8 You apply the TP654 to the window frame immediately before lifting the window into place. And you don't need the ME508 airtightness tape on the inside. https://www.illbruck.com/en-gb/products-systems/product-finder/tp654-illmod-trio-1050/ Installation video see 1m50s I thought I read somewhere that you could also apply the Compriband before installation? I've definitely read that it can be fiddly! But hopefully worth it for airtight windows. Link to comment Share on other sites More sharing options...
Chanmenie Posted May 8 Share Posted May 8 (edited) 9 hours ago, Novice Becky said: @craig or anyone. Can anyone suggest a supplier for Illbruck TP654 88mm/6-15 all-in-one tape? Sealants online are out of stock for 4-6 weeks (I need it in 5 weeks). Dortech don't stock 88mm (just 58 and 66mm). Nothing else comes up on a search. I need deep tape as the timber windows are 95mm thick. Thanks I used Pro Clima, much better value for money compared to Illbruck, I was advised to use 20mm tape even though my windows are 100mm deep. it’s fine to use narrower tape then use airtight foam on the inside. https://www.ecologicalbuildingsystems.com/product/contega-fiden-exo I attached the tape to the window, then fitted it, as I have Alu Clad the tape goes 10mm back from the face so would be a bugger to fit after putting the windows frames in Edited May 8 by Chanmenie Link to comment Share on other sites More sharing options...
MikeSharp01 Posted May 8 Share Posted May 8 30 minutes ago, Novice Becky said: You apply the TP654 to the window frame immediately before lifting the window into place. Have your installers agreed to doing this as it seriously limits the time they have to get the windows in and fixed. 1 Link to comment Share on other sites More sharing options...
Nickfromwales Posted May 8 Share Posted May 8 6 minutes ago, MikeSharp01 said: Have your installers agreed to doing this as it seriously limits the time they have to get the windows in and fixed. Yup, they will not thank you for this unless it has been agreed comprehensively before they arrive on site so they can adjust their time / labour fairly. Link to comment Share on other sites More sharing options...
Novice Becky Posted May 9 Author Share Posted May 9 Thanks @Chanmenie. The Pro Clima system is equivalent to Illbruck i3. The Illbruck TP654 is different - it's an all in one system. So instead of using foam tape then expanding foam then airtightness tape you just apply the TP654 tape to the full depth of the window frame. You don't use foam or airtightness tape. A benefit I see for retrofitting is that I won't need to remove as much plaster on the reveals. Link to comment Share on other sites More sharing options...
Novice Becky Posted May 9 Author Share Posted May 9 12 hours ago, MikeSharp01 said: Have your installers agreed to doing this as it seriously limits the time they have to get the windows in and fixed. Yes, you're right, you do have to be quick to put the window in place once the tape is on! They were happy to use either the i3 Compriband system or the TP654. Link to comment Share on other sites More sharing options...
Novice Becky Posted May 9 Author Share Posted May 9 12 hours ago, Nickfromwales said: Yup, they will not thank you for this unless it has been agreed comprehensively before they arrive on site so they can adjust their time / labour fairly. Good point. Yes, I've talked it all through with the installer. Unlike others they were happy to fit my windows airtight. They were happy to use either system. The TP654 should save them time compared to using Compriband/foam/airtightness tape! 1 Link to comment Share on other sites More sharing options...
MikeSharp01 Posted May 9 Share Posted May 9 36 minutes ago, Novice Becky said: I've talked it all through with the installer. Unlike others they were happy to fit my windows airtight. They were happy to use either system. The TP654 should save them time compared to using Compriband/foam/airtightness tape! Which window system are you using - I expect others would like to know as it simplifies so much to get them fitted air tight? Link to comment Share on other sites More sharing options...
Sparrowhawk Posted May 9 Share Posted May 9 3 minutes ago, MikeSharp01 said: Which window system are you using - I expect others would like to know as it simplifies so much to get them fitted air tight? And where did you find installers that know and care about such things? Link to comment Share on other sites More sharing options...
Nickfromwales Posted May 9 Share Posted May 9 5 hours ago, Sparrowhawk said: And where did you find installers that know and care about such things? That's the best question of the day! 1 Link to comment Share on other sites More sharing options...
Novice Becky Posted Monday at 19:57 Author Share Posted Monday at 19:57 On 09/05/2024 at 11:18, Sparrowhawk said: And where did you find installers that know and care about such things? @Sparrowhawk and @Nickfromwales, guess what? You were right!! Install was really shoddy. See my post today in 'Measuring up for replacement windows'. The new TP654 system is not available in the UK in the width I needed so I used Illbruck i3 (Compriband - FM330 - ME508) Sorry, I don't know how to put a link to that post here. Link to comment Share on other sites More sharing options...
Sparrowhawk Posted Tuesday at 09:47 Share Posted Tuesday at 09:47 13 hours ago, Novice Becky said: Sorry, I don't know how to put a link to that post here. Here's the link (right click on "Posted X hours ago" and copy the link) All I can say is your experience fits with what I've heard, and why I still haven't got these damned windows replaced! 1 Link to comment Share on other sites More sharing options...
Nick Laslett Posted Tuesday at 18:12 Share Posted Tuesday at 18:12 (edited) My wife and I did our window installations ourselves using some Illbruck products. We used TP651 Trio expanding tape, which is 35mm depth on 47mm depth window frames. We used the FM330 Pro Foam Air Seal expanding foam to fill the gap left behind the tape. I really rate the FM330 expanding foam. We then used Siga Fentrim IS20 airtightness tape, 10mm on the window frame, connecting across the foam to the ICF EPS reveal. Siga are one of the few airtightness brands that explicitly state their tape will bond with EPS. This was probably overkill, but we wanted to be sure that the windows were airtight. The Thermohouse ICF window blocks have a “Check Reveal”, which means the edge of the window frame is protected by 100mm of EPS. This is another layer of insulation and weather protection. Our renderer then fitted on the outside of the frame a window reveal bead, with a rubber seal. https://ewistore.co.uk/shop/external-wall-insulation/anthracite-window-reveal-bead-with-mesh/ I doubt any of this additional work will be reflected in our SAP score, but I am pretty confident that we have detailed the junction between the window frame and the rough opening in a way to provide us with a lot of long term benefits. Edited Tuesday at 18:14 by Nick Laslett 2 Link to comment Share on other sites More sharing options...
Novice Becky Posted Wednesday at 13:41 Author Share Posted Wednesday at 13:41 On 24/09/2024 at 10:47, Sparrowhawk said: why I still haven't got these damned windows replaced! I'd def recommend finding a couple of friends and DIY - or a builder who can remove and dispose of old windows and secure new windows in place. Doing the foam and tape is easy (illbruck even have some videos) Link to comment Share on other sites More sharing options...
