Block and beam for timber frame aiming for passivhaus
Hi. Has anyone done a passivhaus (aiming for) timberframe using block and beam foundations but not using Tetris?
Our foundation design currently uses Tetris to keep the thermal bridging down but it is coming out 50% more than a raft (which we can’t have due to site conditions) and 100% more than traditional block and beam with 200mm of PIR.
Just wondering if anyone else has achieved near passivhaus using block and beam and can share foundation designs?
thanks
ps. have a read of this thread as the OP was also told couldn't have an insulated raft due to ground conditions but their SE made it possible.
17 minutes ago, Thorfun said:
can't you just use normal block and beam and put loads of insulation on top? 🤷‍♂️
I think there will be thermal bridging issues between the block and frame. Has anyone got a design that works around this?
@ProDave did a suspended I joist floor with a screed on top.
Search his recent posts. Added to his external woodfiber layer it should have excellent thermal bridging characteristics.
Or like @Thorfun says just shove lots of insulation on top of block and beam. Perimeter thermal bridges are pretty straightforward to deal with for timber frame anyway. What's your planned wall build up.
Have you looked at all options of raft? Ie. Rafts with piling support.
Marmox blocks.  I looked at them for ours, but in the end decided the benefit was neglible as we had continuous 40mm pir layer around the inside of the frame.
This is a construction detail for block and beam from the Durisol build manual it may be some you could use or modify.
I also looked at Marmox, and once I had been through the calculations, couldn't see the benefits. I constructed as per the below, but with the additional 70mm upstand not shown on the screed perimeter.
My slab isn't block and beam, but similar in many respects, but ground bearing, see image above for an idea - 160mm reinforced slab on numerous stub walls, cast in place. Then insulation, then a further cast concrete floor.
  • 1 month later...
thanks
Keen to know the answer to this too - there must be a way to mitigate thermal bridging using a standard block and beam? I saw on another thread on here, which I'll try and dig out, that someone used some insulation in the outer cavity but wasn't sure how keen building control would be on that idea.
See my post above, block and beam drawing thermal bridge free -  by durisol (carbonplan drawing) giving all the details.
It doesn't work for timber frame construction though, I don't think?
Problem seems to be the junctions; where frame meets blocks etc.
Could quite easily work. The Durisol block takes all the structural loads on the inside of the block. A timber frame with a structural wall inside and Larson strut on outside to carry insulation. So this type of construction above for the block and beam as detailed above and timber frame as below.
EM20TimberFrameLarsenTruss.jpg.13dc63adede9318317c786773b4a385f2.jpg.7e22db26392587827823e25c48094df8.jpg
There are various options, structural insulation, lightweight blocks, insulation upstands etc. Should be something your architect / PH designer can specify and update drawings accordingly.
I don't think this build-up would meet the approval of warranty companies would it? The problem is I would have to find a company that manufactures this type of timber frame that is accredited, and of all the shows I have been to I've never seen this arrangement, so that strikes me as tricky! Out of interest, the load bearing frame element of the image would also be the service cavity in this scenario I guess - which seems great! Also, where would the racking board go as it's not shown on the drawing?
Not sure why it wouldn't, pretty standard arrangement. Do a stick build? Have a read up on Larson strut!
Behind the load bearing frame and the airtight membrane would be stuck to it.
Stick build is a nightmare for structural warranties, and even if I could get past that lenders really don't like it either. I've done a few for extensions over the years, but warranty not required.
It's not a standard arrangement at all - but if you can point me to a manufacturer and installer that works with it and can give me the accreditation standards I need for a warranty and mortgage I guess I could look into it!
It is here is one supplier and installer, plenty of people on here seem to have used them.
There are are others also, but I will leave you to investigate.
You wanted to know how to use block and beam with passivhaus, have provided your starter for ten. Foundation details and wall system.
Screenshot_2024-06-05-13-53-04-76_40deb401b9ffe8e1df2f1cc5ba480b12.thumb.jpg.b9073a0d642700c1925cd0867fe88c5c.jpg
Yes - I'm familiar with twin-frame (and MBC - I'll be asking them to price for me), but I don't really want a twin-frame as it's expensive.
FYI a twin frame, is a Larson truss. A structural element and non structural to hold the additional insulation.
Kind of; typically a Larsen truss is a complete truss (joist) fixed to the structural element, which is a bit wasteful and isn't quite as effective in terms of thermal bridging as a twin frame, but agree that in principle they're similar.
My apologies for what is likely to be a silly question .
but if you are looking at a block and beam ground floor and aiming  for passive , with passive timber frame . Can you still have a flush patio to finished floor ( so the level outside is the same for wheelchairs etc ? )
if so can some show me a drawing of how this might work please 🙏
I don't see how you can have any timber frame where the flush patio doors are, as the frame needs to be 150mm above ground.  All you need under the doors is something rot proof with good insulation that is strong enough to support them.
  • 8 months later...
thanks
good afternoon, would be very interested if resolved and what the conclusion was please? I see things went off topic a bit!  We are using a larsen truss system (ie all the load on inner 140mm stud) and have to have suspended floor due to heavy clay, trees, hedges. We are at passivhaus high performance (won't quite meet certified due to form factor - not huge and single storey). Current plan is preinsulated planks (avoiding screeds etc) with timber frame sitting directly onto edge - so almost replicating a raft, but suspended.  But getting very nervous due to long delays with design for coordinated drawings and building control, therefore now urgently exploring other options. Seems to be a few beam & EPS products out there - but how to detail edges with no traditional masonry/brick, where to sit timber frame, and prevent/minimise thermal bridging.  Plus dpc/dpm/ventilation detailing..................  kr.........ma
This was answered by @Roundtuit back in April - sit the sole plate on a course of Marmox blocks.  And/or increase the size of the PIR upstands.
I note you say no screed but what are you going to put UFH in (presume you are having UFH)?
