Pete Posted October 9, 2017 Posted October 9, 2017 If anyone interested I have a 15% off code for airtightness tapes with Passive house systems. The code is 15%aocx, not sure how long this code lasts but I have only just ordered and it worked for me. I have the rep's contact details so if it does not work let me know and I will contact him. 1 1
PeterW Posted October 9, 2017 Posted October 9, 2017 Worked for me... http://www.passivehousesystems.co.uk/
PeterW Posted October 14, 2017 Posted October 14, 2017 Just to add mine turned up yesterday and god is it good stuff ...!!! Had to unstick it from my fingers on a number of occasions ..!!!
Triassic Posted March 14, 2018 Posted March 14, 2018 On 09/10/2017 at 19:27, Pete said: If anyone interested I have a 15% off code for airtightness tapes with Passive house systems. The code is 15%aocx, not sure how long this code lasts but I have only just ordered and it worked for me. I have the rep's contact details so if it does not work let me know and I will contact him. The discount code still works. Not impressed by a £24 delivery charge for 10 rolls of tape, so cancelled the order. Any suggestions when to buy air tightness tape without ridiculous delivery charges ?
PeterW Posted March 14, 2018 Posted March 14, 2018 What tape did you order..?? I had 10 rolls of tape at around 100mm or so and it was £12 delivery. Still the cheapest by a long way.
Alexphd1 Posted March 14, 2018 Posted March 14, 2018 is that good stuff (gerband 586)? does it stick to EPS?
PeterW Posted March 14, 2018 Posted March 14, 2018 Gerband sticks to anything ... brick, block, timber, uPVC, EPS, fingers, hair.... I really rated it - used the split stuff for the windows and tbh you can’t get it off now ..!
ProDave Posted March 14, 2018 Posted March 14, 2018 1 hour ago, Triassic said: The discount code still works. Not impressed by a £24 delivery charge for 10 rolls of tape, so cancelled the order. Any suggestions when to buy air tightness tape without ridiculous delivery charges ? Ebay. A German supplier on there regularly sells bundles of 20 rolls or Tescon Vana for way below what any UK outlet sells it for. e.g. this one works out about £15 per roll delivered https://www.ebay.co.uk/itm/pro-Clima-Tescon-Vana-Klebeband-Profi-VE-20-Stuck/261425541408?epid=1104754860&hash=item3cde2d3120:g:pI4AAOxy3HJTJhWC
Nestor Posted March 14, 2018 Posted March 14, 2018 1 hour ago, PeterW said: What tape did you order..?? I had 10 rolls of tape at around 100mm or so and it was £12 delivery. Still the cheapest by a long way. @TriassicI ordered 30 rolls in January and they charged £10 + vat for delivery. Works very well on OSB.
Triassic Posted March 15, 2018 Posted March 15, 2018 Maybe I’ll up the order and see if the delivery costs come down!
Triassic Posted March 15, 2018 Posted March 15, 2018 10 hours ago, ProDave said: Ebay. A German supplier on there regularly sells bundles of 20 rolls or Tescon Vana for way below what any UK outlet sells it for. e.g. this one works out about £15 per roll delivered https://www.ebay.co.uk/itm/pro-Clima-Tescon-Vana-Klebeband-Profi-VE-20-Stuck/261425541408?epid=1104754860&hash=item3cde2d3120:g:pI4AAOxy3HJTJhWC The http://www.passivehousesystems.co.uk/ charge £11 per roll for the 50mm by 25m roll.
ProDave Posted March 15, 2018 Posted March 15, 2018 50 minutes ago, Triassic said: The http://www.passivehousesystems.co.uk/ charge £11 per roll for the 50mm by 25m roll. Thanks. I wish someone had told me that a year ago when I was buying mine.
Nestor Posted March 15, 2018 Posted March 15, 2018 5 minutes ago, ProDave said: Thanks. I wish someone had told me that a year ago when I was buying mine. Tescon is 30m so only 6p a metre more, can you claim the vat back from the ebay purchase? I hope the 15% discount code is still working, need another 20 rolls.
vfrdave Posted March 15, 2018 Posted March 15, 2018 12 hours ago, PeterW said: Gerband sticks to anything ... brick, block, timber, uPVC, EPS, fingers, hair.... I really rated it - used the split stuff for the windows and tbh you can’t get it off now ..! Can you plaster over the split tape (the green stuff) or do you have to use a different tape? @Declan52 you probably can advise also
PeterW Posted March 15, 2018 Posted March 15, 2018 Plaster or board and plaster..? Plastering direct needs the "fluffy" tape that has the fibre backing. For boards we have just bonded the boards in the reveals to to the exposed inner block and screwed to the cavity closer with DryFix FR behind the boards and they are solid.
Declan52 Posted March 15, 2018 Posted March 15, 2018 (edited) 1 hour ago, vfrdave said: Can you plaster over the split tape (the green stuff) or do you have to use a different tape? @Declan52 you probably can advise also They do a pink hairy type split tape. It would be similar to what old type scrim cloth was. It has half the tape with an adhesive section that you can stick to windows, doors, flooring, plasterboard and the other side you use a flexible adhesive to stick this to the wall. http://passivehousesystems.ie/product/winflex-airtight-window-tape/ http://passivehousesystems.ie/product/gerband-fortax-6400-airtight-sealant/ The company use to be called clean energy Ireland when I bought from them but they have rebranded to the passive House systems. Very good to deal with. I sent an email with what I needed and then a cheque and the goods arrived within a week. Edited March 15, 2018 by Declan52
vfrdave Posted March 15, 2018 Posted March 15, 2018 Thanks @Declan52 as always 4 hours ago, Declan52 said: pink hairy type split This makes it sound much more interesting than the subject matter is.
Pete Posted March 15, 2018 Author Posted March 15, 2018 10 hours ago, Triassic said: Maybe I’ll up the order and see if the delivery costs come down! Delivery over £200 is £12 and free if the order is over £300
Nestor Posted March 15, 2018 Posted March 15, 2018 1 hour ago, Pete said: Delivery over £200 is £12 and free if the order is over £300 My order was £321 + vat and they charged me £10.00 + vat for carriage. Next time......
Nestor Posted April 19, 2018 Posted April 19, 2018 Just ordered another 20 rolls and the discount code still works. 15%aocx 1
MikeGrahamT21 Posted April 24, 2018 Posted April 24, 2018 On 14/03/2018 at 20:29, Triassic said: The discount code still works. Not impressed by a £24 delivery charge for 10 rolls of tape, so cancelled the order. Any suggestions when to buy air tightness tape without ridiculous delivery charges ? Yeah I was annoyed by that too, i even rung them about it and they claimed thats how much it costs them, needless to say I didn't order via them. I got it from these... http://munsterhrv.com/shop/index.php?main_page=product_info&products_id=123 The other brand i've used is airstop (https://www.airstop.co.uk/airstop-tapes-c1775), both products seems to do the job well, if anything the airstop stuff is even more sticky but doesn't seem quite as thick.
Alexphd1 Posted May 26, 2018 Posted May 26, 2018 Discount code still works. I was quoted £12 del (aberdeenshire) for a £70 order when i increased the order to £201 i got free shipping then the 15% discount!
vfrdave Posted September 11, 2018 Posted September 11, 2018 On 09/10/2017 at 19:27, Pete said: 15% off code for airtightness tapes with Passive house systems. The code is 15%aocx This appears to still work.
