You’ll need to ask the suppliers/installers of whatever blind you go for. Imagine it will need power inside the window recess, probably at one end or the other.
I’m thinking of using the below when we do our extension, but not got round to looking into it properly, so please update the thread if you do the legwork for me!!!
https://www.poweredblinds.co.uk/electric-roller-blinds/serene-electric-roller-blinds/
I'm thinking about this now that the blinds are up!
A lot of the electric blind kits Ive seen are actually battery powered with a charge needed every 3-6months (allegedly)
Whilst I’ve no experience of fitting e blinds I’ve built plenty of housing for the Theres normally just one three core wire that’s took up out of site once fitted Super cool I wouldn’t like to guess at the cost We recently did a barn conversation with eight three metre sections on the south facing side
Is there any logic in just dropping cat6 if it is a reasonably sized window where you can get away with a 24v blind?
It gives you maximum flexibility (except if you need a bigger motor and therefore AC power). It also gives you control wires.
You can terminate cat6 yourself and it is easy to deal with (e.g. replacing the blinds could just be as simple as unplugging a network cable and crimping a new RJ45 on the new blind to the correct length). No need for any electricians.
Edit: Some more info here: https://umbrashading.co.uk/24v-vs-230v-roller-blinds-which-motor-is-right-for-you/
Powering via POE might solve some of the downsides they are saying about, it also means the control device only has to be turned on when the blinds are moving (the POE switch could turn the port on, send the command, wait for confirmation its completed and then turn the port off).
Edit 2: More info here: https://www.reddit.com/r/homeautomation/comments/ubp7su/poe_roller_blinds/
Seems that powershades are one of the few providers of POE blinds at the moment:
https://powershades.com/truepoe
Edited by NailBiter
In my research notes, I have electric (wired) blinds mostly favouring left-hand side cabling, and for pre-cabling to cover most bases, to run 1.5mm2 Twin and Earth and a CAT6 cable.
13 hours ago, Mattg4321 said:
I can’t be doing with changing batteries all the time personally
Most of the battery ones are rechargeable by plugging in a USB charger rather than changing the batteries...
Yes thats what I was getting at, if you had a socket nearby you could just leave it charging all the time if you were so inclined
I don’t want to do that either!!
  • 1 year later...
@CalvinHobbes @NailBiter @Mattg4321
Any update or news on this topic since a year ago ? Anyone installed any electric blinds ?
I am just trying to define details for installing electric blinds myself. The electrician has run 1.5mm twin and earth to the window reveals, but am still unsure whether anything else is required.
I see some blind motors are smart home capable (with zigbee for example), so that seems the best control option. So presumably you don't need any additional cable to a wall switch because you can just turn the motor on/off/reverse wirelessly.
Anyone done electric blinds over bifold doors ?
Jeepers, Somfy seem to absolutely take the piss with their 'we saw you coming pricing'.
Hundreds for a blind motor FFS, and £180 quid for yet another bloody zigbee hub.
Yep, we hardwired all our blinds... No regrets! Just need to tidy it up a bit.... 2 core all that was required. Even if rechargeable is easier having several blinds would quickly be annoying!
Ive got some Smartblind Eve motion powered blinds. They are battery powered but no hub needed and interface well with Apple Home. As for the price of any sort of motorised blind - its ridiculous.
We have Somfy blinds and 6 are rechargeable. A recharge every 3 to 6 months is needed. But charger isn't very long, so doesn't reach the ground, so need steps to support extension lead. Takes a couple of days to charge all 6 blinds.
Control is via a simple remote control. Nothing hub wise, sort of double the price of the blinds, so wasn't really fussed about it. Remote is easy, anyone can do it.
Hard wire next time.
Edited by JohnMo
