Right boffins
having looked at the price of residue pumps both buying and hiring does anyone have an ideas on how to pump out about 3in of water currently sitting on our suspended slab floor.
We have been using a wet hoover, but it takes ages as we have to keep emptying it.
This issue is likely to carry on due to the slow speed of our build, we are unlikely to have a roof this year.
TIA
Dirty water submirsible pump.  If there are ANY stones, get one with a stainless steel impellor, not plastic/
I did this most days on our build, had loads of rain. I found the quickest and easiest was actually a dust pan, scoop and throw over the stub wall. Or into a big bucket.
3 minutes ago, JohnMo said:
into a big bucket
First the pump, then this for the rest.
Or brush it out of a door or gap?
There are specialist pump suppliers who can advise, because many sump pumps need more than 3" to work.
The water is about 1 -2 inches deep and the room is 6m * 4m approx.
Submersible pump no good as water needs to be over the top hence puddle (residue) pump, but they are very expensive.
Too big an area for the dust pan and brush approach.
We have been sucking it out with the water vacumn, but that only takes a bucket load and then needs to be moved manually to empty.
We spoke to pump suppliers and they advised puddle pump, but new are £100's and to hire is £60 per day.
Just wondered if anyone had any ideas.
Thanks for all the above.
If you formed a hole in the floor slab where would it go?
What is preventing the water running out at the walls?
Edited by saveasteading
it's 200mm thick with mesh and then heave protector then oversite so not really feasible.
as it's under the DPM no doors or gaps.
Possibly leave it? No roof then it's just going to keep coming back, let it fill up and use a submersible as and when (just looking at it from an alternative angle)
Couldn't you drill a hole, or several,  for now? put a pipe in it for tidyness and to cast the water away?
Good idea, core a 40mm hole in the wall, dig outside adjacent to hole and stick in a submersible. Pick the lowest spot on the slab edge😁
So the 90 quid one in the link I posted up is no good then?
it probably is, I commented again before looking at the link.
Hubby is going to look at link later to possibly buy one.
