7 minutes ago, joe90 said:
I was charged £250 for the design SAP ( the architect was expensive in hindsight as I did all the designing, he just put it on CAD and printed copies for the building regs and builder).
Hopefully that was for an "official" SAP, that can then go forward to produce the as-built. If he's not an accredited energy assessor then he's likely to have contracted that out and you've been charged a management fee.
The most cost effective route may be to go back to him to produce the as-built. If the Design SAP was official, it should be a minor update to produce the as-built
Is there a chance that the former EPC assessor might send me a copy of their file?
I know they anyone else is not allowed to use it, so it is not as if it will take away work or anything :P.
My chalet-bungalow is currently an EPC 74, with 17% of light assessed as low energy fittings (previous owner iriots!) and no solar. It says that low energy bulbs take me up to 77 (*), and 2.5kWp solar would take that up to 83.
So if I have 100% of low-energy light fittings, and 10kWp solar - which I have now - what could my number be? We also have a brand new high efficiency boiler.
If the solar benefits are linear to EPC, then that makes it another 18, which gets me to 101. Likely?
[Update: Playing a bit with Stroma for the Little Brown Bungalow the PV impact is *huge*. Very tempted to get one done on my house to lock in the number before they nobble the algorithm again to promote the next big thing.]
Ferdinand
(*) We have *oodles* (=about 75-80) of GU10 recessed and mounted spotlights, curse their little cotton socks.
Edited by Ferdinand
I did both my design SAP and as-built SAP, but had to pay an assessor £100 to check my as-built file and lodge the EPC.  I used FSAP to do mine, not that hard to get to grips with.  I passed the design SAP details to BC and they were perfectly happy to accept my own work at that stage, it's only for the as-built SAP where you hit the monopolistic business that only a registered assessor is allowed to submit the chit.  A typical, over-regulated, government job creation scheme, in my view
I've just checked and the design EPC was A102, the as-built EPC was A107.
Edited by JSHarris
My request for the same was politely declined, but the assessor offered to run all the different scenarios I wanted.
12 minutes ago, IanR said:
But you still need an EPC for you BC completion Cert... don't you?
Only for a new build .... conversations that are done under Part L1B are exempt from all the stuff such as pressure testing and other shenanigans ... I'll still be doing a home brew pressure test though but it's not needed for any calcs for BCO.
Interesting, I've not been required to do the Air Test (so a figure of 15 ACH went forward to the SAP), but BC have requested a registered EPC for the completion cert.
-mine's a CoU Agri to Resi
I didn't look into this as I needed the EPC for RHI anyhow.
Edited by IanR
The default SAP air permeability isn't 15 ACH at 50 Pa, it's 15 m³/m²/h at 50Pa.  There's a big difference between the two methods of measurement.
SAP is, as far as I know, the only energy efficiency assessment method that uses these units for air permeability.  Pretty much everyone else in the world, including the PassivHaus Institut, use air changes per hour at 50 Pa pressure differential.
Quite right.
For conversion to dwelling work EPC still required. No air permeability test required under Regs so default of 15 is used. You can still get test done and use that value in the as built.
3 hours ago, PeterStarck said:
So, if 6Kw gets you to 101 and 8Kw gets you to 107, does it follow that 4Kw would reduce it to 95?
Yep that is what our energy assessor said. So 2Kw = 6 SAP points in our case.
Something has gone wrong there. Can't attribute that to me, it was NSS.
