Originaltwist Posted January 12 Share Posted January 12 I have a 20 square metre breeze block wall with a crack in it. I'm looking to mend the crack and render the wall outside to waterproof it. I think the job is too small for a contractor. Is there something I can put on myself? Link to comment Share on other sites More sharing options...
Conor Posted January 12 Share Posted January 12 Have you done any sort of rendering before? I'd be putting on a traditional sand and cement - scratch coat then finish, then paint. It'll keep the water out. Link to comment Share on other sites More sharing options...
Russell griffiths Posted January 12 Share Posted January 12 Use a pre mixed product in a bag, this will save problems trying to work out correct mix. Link to comment Share on other sites More sharing options...
saveasteading Posted January 12 Share Posted January 12 22 minutes ago, Originaltwist said: . Is there something I can put on myself I've done it but it is tricky. I think it looks passable at best but nobody else seems to notice. I deliberately left curves trowel strokes, in the Mediterranean style. 2 coats is best, the first disguising the undulations and pointing. If you get stuff with latex in the mix it helps. Then grow plants in front of it. Link to comment Share on other sites More sharing options...
Redbeard Posted January 12 Share Posted January 12 If you want smooth (-ISH!) use a bagged product with mesh and do the first coat with a toothed trowel. The 'tramlines' of the toothed coat act as a depth gauge. Do a small (1m2?) test 'panel' first and you can mess with it and refine it till you feel confident. Link to comment Share on other sites More sharing options...
twice round the block Posted January 12 Share Posted January 12 20 .sq m would be a nice small job for a plasterer. If your going to tackle it yourself make sure you get angle bead and render stops in place first. You may need to coat the wall first with uni bond. Don't try it if temp is below 5° Use sand and cement 4:1 for the whole job, and rule off in sections with a straight edge. Apply with trowel and hawk, rub up second coat with a float. You can use a damp sponge to rub it up providing the second coat has nearly gone off. Remember professionals make it look easy, because we've been doing it for year's. 1 Link to comment Share on other sites More sharing options...
Originaltwist Posted January 13 Author Share Posted January 13 Wow - thank you everyone for your kind responses. This is definitely above my pay grade so I'll call in the pro's. I was hoping to find some gloop that I could brush on but if a job's worth doing ......... Link to comment Share on other sites More sharing options...
joe90 Posted January 13 Share Posted January 13 Although I am not bad at plastering I never got on well with rendering 🤷♂️ GAMI (get a man in) Link to comment Share on other sites More sharing options...
Mr Punter Posted January 13 Share Posted January 13 On 12/01/2024 at 09:59, Russell griffiths said: Use a pre mixed product in a bag, this will save problems trying to work out correct mix. You can get Weber OCR in bags at Wickes. Link to comment Share on other sites More sharing options...
Brickie Posted January 14 Share Posted January 14 (edited) On 12/01/2024 at 19:10, twice round the block said: Use sand and cement 4:1 for the whole job I was taught that the mix should get weaker from first to second coat or it’ll pull- @nod? Edited January 14 by Brickie Link to comment Share on other sites More sharing options...
Mr Punter Posted January 14 Share Posted January 14 1 hour ago, Brickie said: I was taught that the mix should get weaker from first to second coat or it’ll pull- @nod? Yes on problem walls Weber suggest Rend Aid as a 1st coat. It has lots of cement and is sticky as a sticky thing. The mesh is also good minimising cracks. Link to comment Share on other sites More sharing options...
nod Posted January 14 Share Posted January 14 2 hours ago, Brickie said: I was taught that the mix should get weaker from first to second coat or it’ll pull- @nod? 100% 1 Link to comment Share on other sites More sharing options...
Square Feet Posted January 18 Share Posted January 18 I just got something in a tub from Wickes and slapped it on. It looked fine, at least till I had sold the place. Link to comment Share on other sites More sharing options...
