Hello, I am loooking to purchase a 3 bed detached bungalow on 1.5 acres. We would look to start straight away with the extensions under PD to allow for extra bedrooms. Minimum of 4, but ideally 5. I’ve had a few ideas but wondered if anyone else has anything better.
would it be worth going down full planning so that I’ll be able to do a wraparound
Thank you
If you’re considering any flat roof extension, they may well require Full Planning as the majority do not meet the PD requirements.
Don’t be limited on what can be done via PD. Your decision should be made on what you want, what can be achieved and the build costs.
Hi @FreddieW
I would want a planning exemption certificate
Long way from kitchen to lounge...
Old bed 2 would have no windows??
5 bedrooms and 1 bathroom?  Lets hope hot curry is not on the menu..
Good luck
Marvin
Bit of of a strange layout would be better having the bedrooms together and living/day spaces together. Also lots of bedrooms for very limited living space.
Massive hall space being used for nothing much.
Lots of bedrooms (people) for one bathroom.
Just looks like the wrong house, trying to be used, for way too many people.
You maybe better doing a wrap around instead of two extensions, then rejigging the whole space to be a better layout.
Or buy a different house
Hi guys. Yes I understand it’s a bit of a strange layout.
there is me parter and 2 children
possibly have a third
the want for extra bedrooms is for her family to stay as we would be a bit out of the way.
yes the wide hall way is a bit annoying. It’s just over 2000 wide and the front door wouldn’t be used at all as the parking is in the courtyard at the back
there is also a  2 bedroom annexe that my parents will be living in
finding another property wouldn’t really be an option due to the land and the workshop units that are on the site.
perhaps if it all goes through I will need to see what an architect could do with my budget. Thank you
Edited by FreddieW
Get an architect / technologist involved to help with the optimal layout. We did an extension and went ~600mm beyond PD under recommendation of architect... Slightly longer wait to get started but was worth it as the space was perfect.
11KV overhead lines right over the building.  I am not sure you are allowed to build under them now so that might scupper the extension plans.
