Passivhaus - safe with power outages?
I know, clearly you can open windows, but in an "airtight" (not 100% of course) house, is it safe to have a non-working/broken MVHR? Will enough air still come in if you aren't aware the MVHR died? Presumably we have some CO2 meters that might warn us but.. you know?
We have a couple of portable CO2 monitors that include an alarm feature. Not mandatory down this neck of the woods yet but a damn good idea. In a power cut all is well for a short while unless you start lighting candles etc then the air quality falls off a cliff (according to the monitor, not so easy to detect yourself).
I’m sure it would take a good many hours in an airtight house with a non functioning MVHR to become a serious health issue. In our case we’ve bought 11-12 hours of extra MVHR if we lose power with an Ecoflow battery that kicks in to power the MVHR in the event of a power cut - mainly so we don’t have to open any windows and throw the heat away.
Our MVHR trips to battery supplied power when the mains goes off.....
What is your plan (if any) for backup power and maintaining power to MVHR and/or home automation?   You could have Loxone alert you to open a window if CO2>threshold or after X number of hours (or if you have a motorized skylight or something open this), but if Loxone also has no power then that limits you to simpler solutions.
We don't have a dedicated UPS for Loxone/Network, and are relying on Victron battery system for this.  This has got me thinking though, that it would be wise to implement load-shedding in some way so that in a period of extended power-outage the battery isn't dead in 8hrs, but instead allows for mutliple days of usage with keeping minimal lighting, MVHR network and home automation running.   Not really thought about this much as not really as power hardly goes out and I'm not a 'prepper", but interesting..
I wonder though, how many days would you need to be without MVHR for CO2 levels to reach 5,000 ppm?  Anyone know how to calculate this?
If a person expels 0.7 kg of CO2 a day, and a house, 10m by 6 m by 5 m, has 300 m3 of air in it, that is 375 kg of air.
After a day, one person would have increased by CO2 by 0.18%.
So about 5 days to start noticing anything.
Or a day for 5 people.
Apollo 13 got back OK, and they had greater problems than just CO2.
Edited by SteamyTea
Honestly I'm probably better prepared than most, my smart home + network is on a UPS that should last about 2 hours, but next to that I have full off-grid capable solar, so if it's just grid power that's gone I'll certainly notice.
Also, I have a bunch of lonxone'd CO2 sensors, so theoretically my home will know things are awry. Not 100% sure if I have standalone CO2 monitors but I wouldn't be surprised, I'd have to look it up.
Dedicated UPS for loxone/network + batteries with Solar PV, or just UPS?   I skipped loxone/network UPS given Victron has <20ms switchover which appears to be sufficient for everything I have.  What I haven't though about is if/how I could have house running off-grid for 8hrs, but loxone/network running for 24hrs+.    I'd need to turn off some circuits in CU when battery reaches a certain threshold, or another approach would be to have a dedicated inverter for loxone/network (this would avoid 20ms switchover time, but would rely on battery never being empty)
Didn't go for Loxone Touch Pure with CO2?  You using Loxone+KNX in the end?
Both, Solax batteries/EPS inverter connected to solar, and a separate UPS for the network center of the house.
I bought an online UPS, since there will be no switchover whatsoever which is better for the equipment (you effectively always run off battery, whether or not it's being charged is incidental)
I'm not sure I completely follow. Indeed my entire house could run off grid for maybe 8 hours if I take it easy on my antique kettle collection, and once the solar batteries die I am estimating my UPS can carry the torch for minimal brains for a few more hours (obv if I only run the brains off solar I could go for days but that would mean no light/heat etc).
Once the UPS runs low it sends that signal to the brains to power down peacefully.
Yeah I tried to stick with KNX for the bulk of the backbone of the house (lights, sensors, actuators(shutters)) and loxone for mainly brains/interface
