Triassic Posted September 8, 2017 Posted September 8, 2017 This might be a daft question, but here goes! We've been looking at wall hung toilets and as we have some hefty friends, two of which must be around 18 to 20 stone, wondered about the safe working load when seated? Had a quick search online but none the wiser!
bassanclan Posted September 8, 2017 Posted September 8, 2017 200kg http://www.drench.co.uk/blog/wall-hung-toilets-what-are-they-how-much-do-they-cost-and-are-they-worth-it/
bassanclan Posted September 8, 2017 Posted September 8, 2017 Go for the concealed cisterns with the metal frame for added piece of mind, or fit a back to the wall toilet with concealed cistern, which gives a very similar look, but is obviously planted on the floor
Onoff Posted September 8, 2017 Posted September 8, 2017 Tell the pair of chubsters they'd best lose a few pounds if they want a crap round your place! 3
Triassic Posted September 8, 2017 Author Posted September 8, 2017 7 minutes ago, bassanclan said: 200kg http://www.drench.co.uk/blog/wall-hung-toilets-what-are-they-how-much-do-they-cost-and-are-they-worth-it/ So around 31.5 stone then! Wow. Will the wall bend?
Russell griffiths Posted September 8, 2017 Posted September 8, 2017 @Onoff mate you took the words out of my mouth.
Nickfromwales Posted September 8, 2017 Posted September 8, 2017 You can park a car on those frames / wall hung pans. They're designed to take impact of you falling over and landing fully on it as you go down, so 3-4 times your body weight. Ive fitted a load of these and I've often hopped up onto the outermost edge with my socks on and literally bounced up and down. That is of course completely dependant upon it being fitted absolute solid, no gaps between the frame and the PB, and a solid bed of cementitious tile adhesive. Last punter was a 21 stone champion power lifter. I fitted 100x50 box section steel floor to ceiling and sat it on 5mm plate atop the 9x3" joists. If there was a nuclear war, that would be the only part of the house left intact
RandAbuild Posted September 9, 2017 Posted September 9, 2017 Geberit frames are supposed to take 61 stone. Bit tough if you're 62
Nickfromwales Posted September 9, 2017 Posted September 9, 2017 1 hour ago, RandAbuild said: Geberit frames are supposed to take 61 stone. Bit tough if you're 62 I read that somewhere too but couldn't remember if it was 60 or 80. No need to ask people to jump on the scales before pooping , but tbh, if your 62 stone then by the time you've bailed out you'll probably be back down to 61 again. Wheres my granola ? 1
Bitpipe Posted September 9, 2017 Posted September 9, 2017 I remember that when our Gebrit frames were delivered we had forgot to order the extra angled brackets to fix them to the frame - had to scramble about to get them in time.
