Pocster Posted May 27, 2023 Posted May 27, 2023 What’s the ‘standard’ way to fix a self supporting staircase at the top tread ? I’ve got a nice rsj there which I assumed the company would be happy to fix too . But they want me to bolt noggins in and ‘pack out ‘ to the face on the steel . This seems pointless to me and not very good - are they really going to hang off some bolted timber when they could ( should ? ) bolt directly to the rsj .
TonyT Posted May 27, 2023 Posted May 27, 2023 Weld metal plates, drill and tap to suit would be my choice. Â Â 1
Pocster Posted May 27, 2023 Author Posted May 27, 2023 59 minutes ago, TonyT said: Weld metal plates, drill and tap to suit would be my choice.   This is the type of thing I would have thought . I’ll wait for their drawings . The fact they want me to in fill the steel with timber seems pointlessÂ
TonyT Posted May 27, 2023 Posted May 27, 2023 7 minutes ago, pocster said: This is the type of thing I would have thought . I’ll wait for their drawings . The fact they want me to in fill the steel with timber seems pointless They can’t be arsed so want the easy option.  some timber wedged in the web of the  beam. Fine for the national housebuilders…. 1
Pocster Posted May 27, 2023 Author Posted May 27, 2023 (edited) 2 minutes ago, TonyT said: They can’t be arsed so want the easy option.  some timber wedged in the web of the  beam. Fine for the national housebuilders…. For the cost of the stairs I’ll make bloody sure some kind of metal bracket off the top stair is welded / bolted to the steel by them Edited May 27, 2023 by pocster
Pocster Posted May 27, 2023 Author Posted May 27, 2023 7 minutes ago, nod said: That’s exactly what they will do Fix to your noggs Yeah but that’s crap ! There’s a bloody rsj there - fix to that !Â
nod Posted May 27, 2023 Posted May 27, 2023 Just now, pocster said: Yeah but that’s crap ! There’s a bloody rsj there - fix to that ! It is But they will want the easy option 1
Pocster Posted May 27, 2023 Author Posted May 27, 2023 Here's their plan. Â I drill the steel at these points ( presumably 2 holes ). Fix noggins. Timber then horizontal; then pack out with OSB. What bugs me is a) the work for me and b) the actual top tread fixes at just one point by the blue stairs - so why I need to do the whole lot is pointless. They fix to the steel any way they want at the top tread end to the steel!
nod Posted May 27, 2023 Posted May 27, 2023 I’d use 15 mil ply You are right though you shouldn’t be doing any of this Â
Pocster Posted May 27, 2023 Author Posted May 27, 2023 12 minutes ago, nod said: I’d use 15 mil ply You are right though you shouldn’t be doing any of this  I won’t be . It’s a 30k staircase so I’ll make sure they do it correctlyÂ
nod Posted May 27, 2023 Posted May 27, 2023 1 hour ago, pocster said: I won’t be . It’s a 30k staircase so I’ll make sure they do it correctly Yep and don’t forget to give them directions to the nearest cafe  1
Pocster Posted May 28, 2023 Author Posted May 28, 2023 8 hours ago, nod said: Yep and don’t forget to give them directions to the nearest cafe  I usually supply the few trades I do have onsite with goodies from the bakeryÂ
Dave Jones Posted May 28, 2023 Posted May 28, 2023 11 hours ago, pocster said: I won’t be . It’s a 30k staircase so I’ll make sure they do it correctly  30k! What's it made out of ? 1 1
Pocster Posted May 28, 2023 Author Posted May 28, 2023 2 minutes ago, Dave Jones said:  30k! What's it made out of ? Gold you would think ! Lots of glass and polished steel . Nice ‘box’ wooden steps ; kubos 1
Thorfun Posted May 29, 2023 Posted May 29, 2023 22 hours ago, pocster said: Gold you would think ! Lots of glass and polished steel . Nice ‘box’ wooden steps ; kubos Look forward to seeing the finished productÂ
Pocster Posted May 29, 2023 Author Posted May 29, 2023 4 minutes ago, Thorfun said: Look forward to seeing the finished product The stairs yeah ? ; not the house ! 😳 1
Onoff Posted May 29, 2023 Posted May 29, 2023 On 27/05/2023 at 21:32, pocster said: Here's their plan.  I drill the steel at these points ( presumably 2 holes ). Fix noggins. Timber then horizontal; then pack out with OSB. What bugs me is a) the work for me and b) the actual top tread fixes at just one point by the blue stairs - so why I need to do the whole lot is pointless. They fix to the steel any way they want at the top tread end to the steel!  Drill a hole at the points in yellow and put some horizontal pegs in for them to put their cowboy hats 😉  Â
Pocster Posted May 29, 2023 Author Posted May 29, 2023 3 minutes ago, Onoff said:  Drill a hole at the points in yellow and put some horizontal pegs in for them to put their cowboy hats 😉   I’ve sent a nice email ( 4/10 on my pissed off scale ) . We will see what gives .
Onoff Posted May 29, 2023 Posted May 29, 2023 You want a secure as secure is fixing there. Yes wait for their details but if it were me I'd weld a really thick steel plate between the top and bottom flange and drill and tap into that. If you simply nut and bolt the nut could go loose over time and be inaccessible.  I probably have the correct, large size HSS taps I could send you to borrow. I've M12, 14, 16, 20 up to M24 I think. 1
Pocster Posted June 8, 2023 Author Posted June 8, 2023 (edited) On 29/05/2023 at 08:16, Thorfun said: Look forward to seeing the finished product @Thorfun here are the initial plans!   Edited June 8, 2023 by pocster
Thorfun Posted June 8, 2023 Posted June 8, 2023 1 minute ago, pocster said: @Thorfun here are the initial plans!   looks amazing! 🤣 1
Pocster Posted June 8, 2023 Author Posted June 8, 2023 1 minute ago, Thorfun said: looks amazing! 🤣 It cost more than 25 quidÂ
Thorfun Posted June 8, 2023 Posted June 8, 2023 5 minutes ago, pocster said: @Thorfun here are the initial plans! Â Â and now I see the image has actually appeared. had trouble with technology did you? Â anyway, that is a fantastic looking staircase. is it fixed to the wall or self supporting? 1
Pocster Posted June 8, 2023 Author Posted June 8, 2023 4 minutes ago, Thorfun said: and now I see the image has actually appeared. had trouble with technology did you?  anyway, that is a fantastic looking staircase. is it fixed to the wall or self supporting? Lol The first post had the company name in it - I decided to edit that . Contrary to popular belief I don’t want buildhub getting into trouble ! The only fixing ( point of contention at the moment ) is just a fixing to the rsj on the top tread . So not fixed to the wall ( can’t be ! ) and not fixed to the floor ( can’t be ! )Â
