What’s the ‘standard’ way to fix a self supporting staircase at the top tread ?
I’ve got a nice rsj there which I assumed the company would be happy to fix too . But they want me to bolt noggins in and ‘pack out ‘ to the face on the steel . This seems pointless to me and not very good - are they really going to hang off some bolted timber when they could ( should ? ) bolt directly to the rsj .
59 minutes ago, TonyT said:
Weld metal plates, drill and tap to suit would be my choice.
This is the type of thing I would have thought . I’ll wait for their drawings . The fact they want me to in fill the steel with timber seems pointless
They can’t be arsed so want the easy option.
some timber wedged in the web of the  beam. Fine for the national housebuilders….
For the cost of the stairs I’ll make bloody sure some kind of metal bracket off the top stair is welded / bolted to the steel by them
Edited by pocster
7 minutes ago, nod said:
That’s exactly what they will do
Fix to your noggs
Yeah but that’s crap ! There’s a bloody rsj there - fix to that !
It is
But they will want the easy option
Here's their plan.
I drill the steel at these points ( presumably 2 holes ). Fix noggins. Timber then horizontal; then pack out with OSB.
What bugs me is a) the work for me and b) the actual top tread fixes at just one point by the blue stairs - so why I need to do the whole lot is pointless.
They fix to the steel any way they want at the top tread end to the steel!
I’d use 15 mil ply
You are right though you shouldn’t be doing any of this
12 minutes ago, nod said:
I’d use 15 mil ply
I won’t be . It’s a 30k staircase so I’ll make sure they do it correctly
Yep and don’t forget to give them directions to the nearest cafe
  • Haha 1
I usually supply the few trades I do have onsite with goodies from the bakery
2 minutes ago, Dave Jones said:
30k! What's it made out of ?
Gold you would think !
Lots of glass and polished steel . Nice ‘box’ wooden steps ; kubos
Look forward to seeing the finished product
On 27/05/2023 at 21:32, pocster said:
Here's their plan.
Drill a hole at the points in yellow and put some horizontal pegs in for them to put their cowboy hats 😉
I’ve sent a nice email ( 4/10 on my pissed off scale ) . We will see what gives .
You want a secure as secure is fixing there. Yes wait for their details but if it were me I'd weld a really thick steel plate between the top and bottom flange and drill and tap into that. If you simply nut and bolt the nut could go loose over time and be inaccessible.
I probably have the correct, large size HSS taps I could send you to borrow. I've M12, 14, 16, 20 up to M24 I think.
  • 2 weeks later...
@Thorfun here are the initial plans!
Edited by pocster
and now I see the image has actually appeared. had trouble with technology did you?
anyway, that is a fantastic looking staircase. is it fixed to the wall or self supporting?
Lol
The first post had the company name in it - I decided to edit that . Contrary to popular belief I don’t want buildhub getting into trouble !
The only fixing ( point of contention at the moment ) is just a fixing to the rsj on the top tread . So not fixed to the wall ( can’t be ! ) and not fixed to the floor ( can’t be ! )
