Can anyone recommend a structural engineer they have used for a passive house basement? Ideally in the south east London / Kent area.
We're currently designing a passive house and the planners are pushing us towards a basement as they want a limited structure above ground.
Thanks.
We used TSD for our basement. They’re based in Ireland (we’re not) but that didn’t bother them or us.
@Bitpipe used a UK based SE for their basement but I found them a bit pricey.
have an extensive read of the basement sub forum as there’s lots of info on there
Edited by Thorfun
Added bit about sub forum
Thanks. I've had a read through some threads and saw recommendations for TSD but they weren't specific to Passive House and looking at their website they didn't mention that as an area covered, but I will get in touch with them.
You don't need a passive house engineer. There's very little relationship between calculating the loadings of a building and insualtion. It's your architect that needs to be on the ball with things like efficient form, cold bridging etc.
The arithmetic and science, once reduced to the SI system is very similar.
They all tend to use kg, metres, seconds and temperature.
If anything it is likely to be over-insulated. Earth 2m down is generally a constant temperature (is it 16°C?) and most earth is a poor conductor,  but I haven't seen an insulation brochure that mentions that.
Someone here will know if Passivhaus mention it.
Passivhaus should be advising against basements because of the extra material and earth removal required.  Perhaps this is a more holistic sustainability issue than their energy model, but I would be interested to know.
Design a basement structurally, in parallel design how to keep it dry, then insulate the inside. And start saving.
46 minutes ago, Thorfun said:
we insulated outside ours
Far better option AFAIC and saves on precious GIA.
I thought closer to 13o? I would not want the entirety of the basement concrete to be at exactly that temp and then to have to try to mitigate retrospectively / internally. Seems a no-brainer to dig a bit wider and drop 200/300mm of EPS around / underneath.
At depths of 2m and more, the ground temperature does not deviate very much from the average summer/winter surface temperatures (around 8° to 12°C [46ºF to 54ºF] in the UK depending on location). At this depth, there is an enormous store of heat that can be usefully tapped for heating in the winter.
Edited by Nickfromwales
Snippet from the 'net added
A good point about building a very expensive basement then using up floorspace.
That will work especially if you like plain walled brutalism.
  • 1 month later...
Why so?
Digging a half storey hole to get your foundations below the frost line, allow entry of your water services etc that are buried two meters deep in cold parts of the world, building a basement in it, and levelling the spoil around the house to raise the ground floor up out of the summer mosquito altitude, is a great idea in many parts of the world!
2 hours ago, markocosic said:
Why so?
Because the earth needs to be transported away and disposed of. Lots of diesel. Then it fills a valuable space in landfill, or goes on a farmers field, (probably under the radar) making it unproductive.
Then a basement is a heavy structure using much more material than an above ground floor.
So it is a commercial decision to get more housing on expensive land  but not sustainable...hence should be contrary to passive house principles.
If you're disposing of the earth.
Reread the description and I'm describing what folks do here in the cold flatlands.
Digging out a half storey; building from below the frostline (which they'd need to do anyway); then banking the excavated earth up against the house so that ground floor ends up half a storey above the surrounding land.
Free of mosquitoes. With a view. Free of water on the ground floor etc.
In the cities there's also an argument for it. Half basements for the cars, pushbikes, strollers, electric wheelchairs etc. In the space that you've had to dig down to for footings. Aartments above them. Density the city without losing amenity. Does involve muckaway though. But meh if that building is still there in 100+ years.
Also meh if it's that basement that saves you a  from Russian invasion etc. Check out Finland for planning policies that consider legitimate military interests. They've got some of the world's most over specified underground parking/gyms/bats etc all in the name of good effing luck if you make it past the swamps sunshine.
PassivHaus principles do not relate to the carbon "foot-print", sustainability, waste, pollution or really any aspect of construction method. It's a building performance standard that relates to the completed building, with comfort at its core.
Probably why it has succeeded where the Code for Sustainable Homes which tried to cover everything from construction through to end of life fell by the wayside as it was far too complicated.
 I thought maybe i've not been paying attention. So I've checked their website. Aplogies for the grey background.
This reads to me  as carbon, especially energy, first and comfort second, but perhaps comfort sells more buildings.
As an estimate, I'd say that a basement construction creates 5 x the carbon,  than the average.
I'm not against most of the passivhaus principles.
THe Bedzed project  (similar principles) was a serious inspiration to me.
Check out the monetary cost of a basement too, in some detail, before committing.
Buildings are a significant culprit of carbon emissions – accountable for 35% of total global energy consumption. Backed with over 30 years of international evidence, Passivhaus is a tried & tested solution that gives us a range of proven approaches to deliver net-zero-ready new and existing buildings optimised for a decarbonised grid and augmented for occupant health and wellbeing.
Yes, but for the completed building in day to day use. Not the construction of the building.
Edited by IanR
Edited 9 hours ago by IanR
Interesting. Any idea Why not? They either care about carbon or don't.
could it be that the carbon usage of a poorly built house over it's lifetime pales in to comparison to the carbon usage of a passivhouse regardless of it's construction?
(please note I have no data to back up that theory)
That's harsh.
Carbon foot-print for construction versus building performance are two entirely different processes that are not compatible for being captured within a single control system. Yes, the PH Institute could run a separate "Standard" for construction, but so could anyone else. It's generally better for companies to focus on their expertise though than attempt to be all things to all (wo)men.
I'd also say that if they were too prescriptive with regards construction method there would be a lot less buildings constructed under PH principles. Not everyone wants to build sustainably sourced timber-frame houses using only natural insulation.
I'd say that's also why PH targets are based on area/volume rather than occupancy. ie. to not dictating that the home owner should only allow xm² per occupant.
Very interesting, the Romans invented concrete which is energy/carbon intensive and some of their stuff is still standing, so not bad in the scheme of things. With my own Passive esk building I used concrete and PIR for slab and insulation but Rockwall insulation elsewhere as I wanted to limit my “plastic” use as much as I could. The building uses very little energy to heat and keep comfortable so overall better for the environment long term 🤷‍♂️
And there are many 500 year old timber frame buildings still standing, but that's not the norm.
Most of the caves people lived in are still around as well.
Why, it is a fantastic material. Polypropylene can last centuries, is dirt cheap, so cheap that it is not worth recycling, it is one of the easiest to recycle as well.
It is not really the material that is the problem, it is how it is applied.
Well no one “built” those.
Disadvantages of polypropylene:
  • It has a high thermal expansion coefficient which limits its high temperature applications.
  • It is susceptible to UV degradation • It has poor resistance to chlorinated solvents and aromatics.
  • It is known to be difficult to paint as it has poor bonding properties.
  • It has a high flammability.
no 4 is probably why it’s not good as house insulation (rockwall is a very fire resistant material).
https://www.ineos.com/globalassets/ineos-group/businesses/ineos-olefins-and-polymers-usa/products/technical-information--patents/ineos-engineering-properties-of-pp.pdf
Auto-ignition Temperature
340°C
Energy Required for Ignition 2500 k/m2
Ignition Temperature 420°C
Minimum Radiant Flux for Ignition 20 kW/m2
Smoke Specific Extension Area 380-610 m2.kg
Soot Yield 0.06-0.09 kg soot/kg
So a little better than pine which auto ignites around 300°C
https://www.engineeringtoolbox.com/fuels-ignition-temperatures-d_171.html
But pine forms a charred layer which then protects the core.
