joe90 Posted May 25, 2023 Share Posted May 25, 2023 I am going to build a timber (log type) garage 5m x 6m at my new house under permitted development and I need a slab for it, I propose 100mm hardcore or MOT whacked down, sand blinding, dpm membrane then 100mm of concrete with steel mesh embedded. Is this reasonable?, only a kit car and motorbike using it so no real heavy loads. Link to comment Share on other sites More sharing options...
TonyT Posted May 25, 2023 Share Posted May 25, 2023 what kind of logs? sufficient weight in these to have a deeper perimeter foundation? I’ve been using c35 a lot for work foundations for special columns with fibre additives to save climbing down a 1 m hole and placing mesh on chairs Link to comment Share on other sites More sharing options...
joe90 Posted May 25, 2023 Author Share Posted May 25, 2023 (edited) It’s only 44mm log “effect” construction so minimal weight in the garage itself . Edited May 25, 2023 by joe90 Link to comment Share on other sites More sharing options...
TonyT Posted May 25, 2023 Share Posted May 25, 2023 https://nhbc-standards.co.uk/10-external-works/10-1-garages/10-1-4-garage-floors/ Link to comment Share on other sites More sharing options...
TonyT Posted May 25, 2023 Share Posted May 25, 2023 Make sure the concrete is pokered. I can’t find the info, but sure it increases concrete strength significantly. concrete like smooth chocolate or aero bar chocolate I know which I would prefer for strength Link to comment Share on other sites More sharing options...
Chanmenie Posted May 25, 2023 Share Posted May 25, 2023 33 minutes ago, joe90 said: I am going to build a timber (log type) garage 5m x 6m at my new house under permitted development and I need a slab for it, I propose 100mm hardcore or MOT whacked down, sand blinding, dpm membrane then 100mm of concrete with steel mesh embedded. Is this reasonable?, only a kit car and motorbike using it so no real heavy loads. Have you looked at fibre reinforced concrete, it’s cheaper and easier than rebar mesh and very strong. The company that did my slab used the same stuff in their yard at 150mm and they park artics on it, 100mm is ok for fork lifts so should be plenty for your car 1 Link to comment Share on other sites More sharing options...
JohnMo Posted May 26, 2023 Share Posted May 26, 2023 11 hours ago, Chanmenie said: Have you looked at fibre reinforced concrete, it’s cheaper and easier than rebar mesh and very strong. The company that did my slab used the same stuff in their yard at 150mm and they park artics on it, 100mm is ok for fork lifts so should be plenty for your car I've done a couple of garages over the years, each time with fibre reinforced instead of steel. First was about 8 (6x4) years ago, no cracks or issues. Both of ours were 100mm, the current is bigger 6 x 10m. That was pour a year ago, no issues. 1 Link to comment Share on other sites More sharing options...
SteamyTea Posted May 26, 2023 Share Posted May 26, 2023 Why not put a bit of insulation in as well, you know it makes sense. 2 Link to comment Share on other sites More sharing options...
PeterW Posted May 26, 2023 Share Posted May 26, 2023 Dig down 250mm and shutter the edges to the correct size with OSB then put 150mm of EPS in the middle of it up to 250mm from the edges, DPM over the lot and then pour fibre reinforced concrete - you’ve got a pretty well insulated slab along with a ring beam that is never going anywhere ..! Just remember to duct in for the power and water ! 1 Link to comment Share on other sites More sharing options...
joe90 Posted June 7, 2023 Author Share Posted June 7, 2023 (edited) Right, thanks guys for your suggestions, finally found local builder to lay the slab( for a resonable price ), thanks to @Gus Potter for his suggestions (he is an S.E.), steel ordered and boarding for shuttering, hoping to lay in a couple of weeks (I work very slowly now I am ancient 🙄). On another note, i downsized the garage, I was being greedy and left it tight to park my car alongside it so now 6m long by 4m wide, big enough for my toys!., pics to follow. Edited June 7, 2023 by joe90 1 Link to comment Share on other sites More sharing options...
SteamyTea Posted June 7, 2023 Share Posted June 7, 2023 14 minutes ago, joe90 said: 6m long by 4m wide, big enough for my toys!., Almost as big as my house footprint. 1 Link to comment Share on other sites More sharing options...
Big Jimbo Posted June 7, 2023 Share Posted June 7, 2023 Good stuff Joe. Now get it done. 2 Link to comment Share on other sites More sharing options...
Big Jimbo Posted June 7, 2023 Share Posted June 7, 2023 6 x4 will be a nice side for toys. Just don't fill it with junk. (like i would) Link to comment Share on other sites More sharing options...
Pocster Posted June 7, 2023 Share Posted June 7, 2023 I would have dug it down another 3 metres - but that’s me ….. 😎 1 1 Link to comment Share on other sites More sharing options...
joe90 Posted June 7, 2023 Author Share Posted June 7, 2023 1 hour ago, Big Jimbo said: 6 x4 will be a nice side for toys. Just don't fill it with junk. (like i would) I already got rid of my junk when I moved house (but I know what you mean 😱) I gave my old cement mixer away and now had to rent one for a week 🤷♂️. Link to comment Share on other sites More sharing options...
