Internet Know How Posted March 24, 2023 Posted March 24, 2023 Hi All, On a property with full floor UFH, would you install towel radiators in the ensuites? Thanks C
Bonner Posted March 24, 2023 Posted March 24, 2023 Have you got them on separate zones from the other rooms? If not you will want some heat in bathrooms when not needed in the rest of the house. As well as comfort, a bit of heat is needed to reduce condensation… and keep towels warm
Bramco Posted March 24, 2023 Posted March 24, 2023 Our UFH is ground floor only, so we put electric UFH and electric towel rails in the upstairs bathrooms. The electric UFH is set to 19 and has only occasionally come on at night during the really cold spells. The towel rails haven't been on at all - so probably and expensive option - but they do look nice.... Simon
Internet Know How Posted March 24, 2023 Author Posted March 24, 2023 On 24/03/2023 at 12:34, Bonner said: Have you got them on separate zones from the other rooms? If not you will want some heat in bathrooms when not needed in the rest of the house. As well as comfort, a bit of heat is needed to reduce condensation… and keep towels warm Expand Yes all rooms will have their own thermostats and this will be zoned so if I want heating on in a bedroom, it would come on in the ensuite too
JohnMo Posted March 24, 2023 Posted March 24, 2023 We have electric only 400W towel rails in all bathrooms in addition to UFH. Great for drying out towels when heating is off.
Mike Posted March 24, 2023 Posted March 24, 2023 No - but I would run ducts so I could easily pull cable through if needed.
ProDave Posted March 24, 2023 Posted March 24, 2023 Our main bathroom and en-suite are the only upstairs rooms with any heating, wet UFH, more so the tiles don't feel cold than because the rooms actually need much heat. But the main bathroom has an electrically heated towel rail. Mainly because daughter wants to be able to pick up nice warm towels off the rail at the end of the shower. Me personally I file that away as "gross waste of energy" but I am outvoted.
Lofty718 Posted March 24, 2023 Posted March 24, 2023 My towel radiators are part of the radiator circuit and are constantly on when the heating is on following the same weather compensation curve I oversized the radiators and it keeps the bathrooms nice and toasty constantly
Temp Posted March 25, 2023 Posted March 25, 2023 On 24/03/2023 at 12:14, Internet Know How said: Hi All, On a property with full floor UFH, would you install towel radiators in the ensuites? Thanks C Expand Our bathrooms are on their own ufh zone and we have towel rads. Not had the towel rads on last few winters and nobody complained. We have mvhr so towels dry fairly quick
PeterW Posted March 25, 2023 Posted March 25, 2023 On 24/03/2023 at 14:04, Internet Know How said: Yes all rooms will have their own thermostats and this will be zoned so if I want heating on in a bedroom, it would come on in the ensuite too Expand I would split bathrooms off - even en-suite ones - as you may not want heating in bedrooms late spring / early autumn but still want to dry out bathroom floors and reduce any condensation. On 24/03/2023 at 13:36, Bramco said: Our UFH is ground floor only, so we put electric UFH and electric towel rails in the upstairs bathrooms. Expand Likewise and works fine although the install is using a time switch and a floor probe set to 28°C to control temperature. With hindsight I would also install either a duct or an encased one wire probe in the bathroom floors in future as NTC thermal probes are fairly poor in comparison.
