joe90 Posted October 22, 2024 Author Posted October 22, 2024 Yes building regs mean it will not fall down (structural ) and planning means it looks acceptable. my slab (advised by our residential SE) was a 9” slab with steel mesh embedded in it. I was lucky that the ground had already been a parking space with tons of compacted stone etc (just had to remove the gravel off the top.) others here will advise on depth etc of hardcore etc. 1
DevilDamo Posted October 22, 2024 Posted October 22, 2024 23 hours ago, joe90 said: No, PD as more than a meter from the boundary and less than 30 sq m and under the height restrictions. The 1m and 30sq.m relates to BR’s, not Planning.
saveasteading Posted October 22, 2024 Posted October 22, 2024 9 hours ago, joe90 said: my slab (advised by our residential SE) was a 9” slab with steel mesh That is warehouse spec. I'd say use that as perimeter as it has the building on it, but can reduce the middle to 6". I'd also like to have the walls overhanging the slab.
joe90 Posted October 22, 2024 Author Posted October 22, 2024 30 minutes ago, saveasteading said: That is warehouse spec. I'd say use that as perimeter as it has the building on it, but can reduce the middle to 6". I'd also like to have the walls overhanging the slab. I agree mate but the SE said otherwise. 🤷♂️ Yes my slab was 100mm bigger on three sides and 400mm (with slope) on the front.
TheMitchells Posted January 5, 2025 Posted January 5, 2025 Are you able to give a rough idea of total cost in building the garage? I think it looks great.
joe90 Posted January 5, 2025 Author Posted January 5, 2025 https://www.quick-garden.co.uk/single-wooden-garage-4m-x-6m-13x20-ft-44-mm.html?_gl=1*17bbme2*_up*MQ..*_ plus concrete slab approx £400 roof shingles £493 clear coat £194 i didn’t want their garage door, I forget how much they deducted to leave it out and I bought this up and over period door from a national door company. 1
Bruce Posted September 21, 2025 Posted September 21, 2025 On 26/08/2023 at 18:09, joe90 said: NO, it’s screwed down to the concrete and screws not accessible Sounds like a plan, just need to wait till it’s dry 👍 Joe, we are finally on our way with the garage. Slab poured yesterday and the garage should be delivered in about 4 weeks. Did the Fixall adhesive solve the water ingress issue for you? I'm looking into what ashesive to put under my plast boards and want to it it right from the start. Sounds like you have no succes the with the PU/foam strips.
SteamyTea Posted September 21, 2025 Posted September 21, 2025 2 minutes ago, Bruce said: Joe, we are finally on our way with the garage Going to be a while to get a reply. Others may know the answer though. 1
