BotusBuild Posted January 5, 2023 Share Posted January 5, 2023 Looking at all the windows etc which we hope to get fitted in the new house this year. The one item that we're not yet settled on is the large 4.5m x 1.3m (approx) flat rooflight we have a little flexibility in those sizes as the opening has yet to be formed. The original architect designed for a 3 piece rooflight (3 × 1.5m long panels), but I'd quite like a single piece of glass. Has anyone had or seen a rooflight of the full dimensions (or something close to it) fitted? If so, and you know the manufacturer please can you let me know Thanks Link to comment Share on other sites More sharing options...
SBMS Posted January 5, 2023 Share Posted January 5, 2023 3 hours ago, BotusBuild said: Looking at all the windows etc which we hope to get fitted in the new house this year. The one item that we're not yet settled on is the large 4.5m x 1.3m (approx) flat rooflight we have a little flexibility in those sizes as the opening has yet to be formed. The original architect designed for a 3 piece rooflight (3 × 1.5m long panels), but I'd quite like a single piece of glass. Has anyone had or seen a rooflight of the full dimensions (or something close to it) fitted? If so, and you know the manufacturer please can you let me know Thanks Wow - 4.5m?? Our glazing manufacturer raised their eyebrows at our oversized 2.2x2m panes for our sliding doors. 4.5m sounds very special order. Especially in a roof orientation where gravity is wanting to pull the centre of the glass span in itself. Maybe speak with a commercial glazing supplier? 1 Link to comment Share on other sites More sharing options...
George Posted January 6, 2023 Share Posted January 6, 2023 The limit is the size of the oven to toughen the glass. It'll be a job for a commercial scale glazier - I'd have thought there's an oven big enough in the UK but phone someone like Pilkington and ask them. If UK facilities are limited there'll be somewhere in Europe that could do it.  As it is likely in the middle of a large roof then a glass lifter may be unsuitable and you'll need a crane (with suction pad attachment). 1 Link to comment Share on other sites More sharing options...
BotusBuild Posted January 6, 2023 Author Share Posted January 6, 2023 OK, it seems my dreams far outweigh my common sense on this one 🙂 Thinking about it further, after a short while, I will stop looking up at it and the joins won't annoy me anymore 🙂 Link to comment Share on other sites More sharing options...
Tosh Posted January 6, 2023 Share Posted January 6, 2023 Have a chat to velux commercial. I've only ever used them once but you may get closer to your dream than you think for not much different money to an off the shelf solution. Worth a try 🤔 1 Link to comment Share on other sites More sharing options...
JohnMo Posted January 6, 2023 Share Posted January 6, 2023 Hope your ready for sweating in summer, there will be quite a bit of solar gain and heat loss in the winter  Try - Roof Maker. 1 Link to comment Share on other sites More sharing options...
SteamyTea Posted January 6, 2023 Share Posted January 6, 2023 22 minutes ago, JohnMo said: Hope your ready for sweating in summer, Especial when close to 50° North.  Thankfully it is usually cloudy down here. 1 Link to comment Share on other sites More sharing options...
PeterW Posted January 6, 2023 Share Posted January 6, 2023 Structurally that will also be a challenge - has it been framed using RSJs as it’s a significant point load on the centre of a roof.  I would look at what is available in the off the shelf in sectional form and work from there because to be honest you’ll stop looking up at it after about a week ..! Also bear in mind that perfectly flat glass pools water and collects bird $hit and other rubbish - you need a 5° or more slope to get it to self clean. Link to comment Share on other sites More sharing options...
SteamyTea Posted January 7, 2023 Share Posted January 7, 2023 Borrow @pocster's tape measure, you may find that the hole and the glazing are different. Â 2 Link to comment Share on other sites More sharing options...
BotusBuild Posted January 7, 2023 Author Share Posted January 7, 2023 On 06/01/2023 at 15:43, SteamyTea said: Especial when close to 50° North.  Thankfully it is usually cloudy down here. Plus a blind when necessary. SWMBO's speciality 🙂 Link to comment Share on other sites More sharing options...
BotusBuild Posted January 7, 2023 Author Share Posted January 7, 2023 On 06/01/2023 at 15:20, JohnMo said: Hope your ready for sweating in summer, there will be quite a bit of solar gain and heat loss in the winter  Try - Roof Maker. Will give them a call Link to comment Share on other sites More sharing options...
BotusBuild Posted January 7, 2023 Author Share Posted January 7, 2023 On 06/01/2023 at 16:43, PeterW said: Structurally that will also be a challenge - has it been framed using RSJs as it’s a significant point load on the centre of a roof. One side concrete, one side glulam beam, two sides 125mm wide webjoists Link to comment Share on other sites More sharing options...
