Alwayslearning22 Posted November 24, 2022 Posted November 24, 2022 I’ve had a leak under my boiler for 7 days before Ive noticed it. the water has run under the walls and under the tiles on my floor( coming up through grout) Should I be concerned about mould behind the walls? Will I need to replace skirting boards they are soaked. Any tips on getting the place to dry out? cheers
ProDave Posted November 24, 2022 Posted November 24, 2022 It might be more severe that you think, floor up, dry out properly etc
Alwayslearning22 Posted November 24, 2022 Author Posted November 24, 2022 Oh no not what I was hoping to hear. What would be worst case scenario if I were to just rent a dehumidifier and not bother lifting the tiles? Money is tight at the moment can’t afford to get it relaid.
Mr Punter Posted November 24, 2022 Posted November 24, 2022 Sometimes you can get away with it, sometimes it is a horror show. Can you take up a few tiles to see how extensive the damage is? The dehumidifier doesn't have much to work with if the water is trapped under the tiles.
markc Posted November 24, 2022 Posted November 24, 2022 If skirts are MDF then rip them out, pine or hardwood and they will be ok. if water is coming up through grout then there must be voids under the tiles and it will cause problems with the floor or just start to smell or start mould growing on the grout lines
Alwayslearning22 Posted November 24, 2022 Author Posted November 24, 2022 50 minutes ago, Mr Punter said: Sometimes you can get away with it, sometimes it is a horror show. Can you take up a few tiles to see how extensive the damage is? The dehumidifier doesn't have much to work with if the water is trapped under the tiles. I may have no choice. I might just wait and see what happens.
Alwayslearning22 Posted November 24, 2022 Author Posted November 24, 2022 11 minutes ago, markc said: If skirts are MDF then rip them out, pine or hardwood and they will be ok. if water is coming up through grout then there must be voids under the tiles and it will cause problems with the floor or just start to smell or start mould growing on the grout lines Yeah it’s only some grout lines it’s showing up in. Would the wall be protected with a dpc? One less thing to worry about maybe.
markc Posted November 24, 2022 Posted November 24, 2022 48 minutes ago, Alwayslearning22 said: Yeah it’s only some grout lines it’s showing up in. Would the wall be protected with a dpc? One less thing to worry about maybe. Wall should be fine, plaster shouldn’t go right to floor, neither should plasterboard if it’s a stud wall. 1
Andeh Posted November 24, 2022 Posted November 24, 2022 Ring home insurance, get them to sort everything out. Pay extra £25 per year for next few years.... Worry not. Or just get a couple of demudifiers, turn up the heating and see how it all looks in 2 weeks. 2 1
ProDave Posted November 24, 2022 Posted November 24, 2022 As above. I have worked on 2 "wet" properties. The last one was left empty in winter, a water pipe in loft burst and when it thawed emptied the contents of the water tank into a bedroom. Part of the ceiling came down and the floor was well soaked. The insurance surveyor thought it needed drastic action and the insurance paid to strip the whole property back to a bare shell, dry it for weeks with a dehumidifier then rebuild it. They got a virtually new house. I presume the insurance took the view that if you just repaired the obviously wet bits then in future years you could be looking at more problems lurking? 1
saveasteading Posted November 24, 2022 Posted November 24, 2022 Water finds the easiest route, and under your tiles doesn't sound like it. Have you seen the leak? Where from and how fast? You should advise your insurers immediately, even if trying to resolve it yourself. Then you are covered if it is bad. They may send an inspector or ask you to see how it goes....their decision. 1
Alwayslearning22 Posted November 24, 2022 Author Posted November 24, 2022 I see a fast dripping but I can’t tell where it’s leaking from. It’s a drip every second. Bout a week it’s been going on I’d say. only some of the grout lines are have water seeping out. Maybe a void in those areas? As some of the other posters were saying.
saveasteading Posted November 24, 2022 Posted November 24, 2022 How long do you think would the drip take to fill a mug? Obv you need to stop the leak. Meantimd perhaps you can divert it to drip into a bucket.
Alwayslearning22 Posted November 25, 2022 Author Posted November 25, 2022 (edited) 15 hours ago, saveasteading said: How long do you think would the drip take to fill a mug? Obv you need to stop the leak. Meantimd perhaps you can divert it to drip into a bucket. I’d say about 2 hours to fill a cup. I had a heating engineer out to fix it today. I also bought. Dehumidifiers from screw fix might be too small though? It’s a 12lt one Edited November 25, 2022 by Alwayslearning22
Andeh Posted November 25, 2022 Posted November 25, 2022 A drip for a week is probably within the realms of a DIY dehumidifier & heating on job IMO for a few weeks (dehumidifier for longer). I had over looked the 7 days statement, I have to admit. 1
