Radian Posted December 19, 2022 Share Posted December 19, 2022 10 hours ago, Iceverge said: As the place is being demoed have you considered doing the void under the floor. It would be a tremendous energy saver and suspect would confirm my suspicion that timbers on the warm side of insulation will not rot. What about under concrete block & beam? That could be a game changer for me. 1 Link to comment Share on other sites More sharing options...
Radian Posted December 19, 2022 Share Posted December 19, 2022 So has been sort or discussed before. Going to resurrect that thread. Link to comment Share on other sites More sharing options...
ElliotP Posted January 8, 2023 Author Share Posted January 8, 2023 On 18/12/2022 at 22:59, andyscotland said: @ElliotP brilliant achievement! Would you be happy to share where you sourced the beads - were they just generic "packing" beads or something more specific? Sorry I didn't manage to check in over Christmas. Had a couple of people ask now so I may as well link this (hopefully it's allowed). I used these guys: https://ecclestons.com/shop/?filter=true&product_cat=polystyrene-bean-bag-bead-fill They're in Birmingham. I managed to secure a little discount on a bulk order compared to that price. it was an additional £200 ish delivery for a full LWB transit (35 bags they say they can squeeze in). Would be cheaper obviously if you're closer and/or have your own van. I shopped around a little, but didn't spend too much time on it, possibly cheaper elsewhere. I made sure what I got was fire retardant, although I didn't check in too much detail if it was the right spec. On 18/12/2022 at 22:22, Iceverge said: I commend you on your ingenuity. Bravo. As the place is being demoed have you considered doing the void under the floor. It would be a tremendous energy saver and suspect would confirm my suspicion that timbers on the warm side of insulation will not rot. I did consider it - but the cost of beads would be astronomical I think (relative to the cost I was aiming for at least given this is a temporary job). If it was going to be a permanent or longer term I probably would have done it - it would have been easy enough to fire them in through the vents and/or though some 20mm holes through the floor in places. Would need to research the rot situation first, but at least if the floor fell through you'd have something nice and soft to land on! 1 Link to comment Share on other sites More sharing options...
andyscotland Posted January 8, 2023 Share Posted January 8, 2023 3 hours ago, ElliotP said: Sorry I didn't manage to check in over Christmas. Had a couple of people ask now so I may as well link this (hopefully it's allowed). I used these guys: https://ecclestons.com/shop/?filter=true&product_cat=polystyrene-bean-bag-bead-fill They're in Birmingham. I managed to secure a little discount on a bulk order compared to that price. it was an additional £200 ish delivery for a full LWB transit (35 bags they say they can squeeze in). Would be cheaper obviously if you're closer and/or have your own van. I shopped around a little, but didn't spend too much time on it, possibly cheaper elsewhere. I made sure what I got was fire retardant, although I didn't check in too much detail if it was the right spec. Brilliant, thanks @ElliotP hope you had a nice warm Christmas! 3 hours ago, ElliotP said: Link to comment Share on other sites More sharing options...
Jinglish Posted February 27, 2024 Share Posted February 27, 2024 I was thinking to do this myself and found this post. This is exactly what I need to do now and great to see the details of someone else, so well done and thanks for sharing! I have a double detached garage I'm splitting in half with a dividing wall however the envelope of the garage is 100mm brick then 70mm cavity then 100mm block. The current U-Value is around 1.1W/m2K, it would cost too much to insulate on the inside and lose precious volume so I'm going to fill it this way. I already have a leaf blower, compost bin and 32mm swimming pool flex hose. Luckily for me I can access the entire length of the cavity from the inside without having to drill any holes. I only need to insulate 2 walls as the front garage door is being replaced by glazing and the internal partition will be 75mm Kingspan stud wall so I calculate I need 1.6m3 of polystyrene beads. Building control regs says I need to meet 0.7W/m2K threshold for an "existing" element. I calculate it should be 0.39W/m2K after I finish so when the inspector comes round if he does look at this "existing insulated wall done by the previous owner" he will see it's insulated but more so I don't want to waste energy when we heat the new repurposed space. I'll come back and attach some images of my setup maybe in a few months time if I remember 1 Link to comment Share on other sites More sharing options...
Jinglish Posted April 11, 2024 Share Posted April 11, 2024 That’s to the OP for the inspiration My setup… >1800W leaf blower >70mm to 45mm silicone hose >45mm pipe >45mm to 32mm silicone hose >Henry hover adaptor >2m of 30mm swimming pool hose >Jubilee clips Hopefully the videos work and says it all. Thanks to this thread I hope my helps others too. IMG_2350 (online-video-cutter.com).mp4 IMG_2349 (online-video-cutter.com).mp4 1 Link to comment Share on other sites More sharing options...
Iceverge Posted April 11, 2024 Share Posted April 11, 2024 Excellent. Can we see the finished cavity? Do you think it would work with celluose? Link to comment Share on other sites More sharing options...
Jinglish Posted April 12, 2024 Share Posted April 12, 2024 (edited) This was just me testing out that my setup works. Sure I'll come back in due course and share the finished result. That wall in the video is going to have a window cut out so I don't want to fill it yet or beads will go everywhere when we do the cut. There are YouTube videos of people in the USA doing the same thing with what appears to be cellulose. Edited April 12, 2024 by Jinglish Missed the cellulose question Link to comment Share on other sites More sharing options...
Andrewb Posted April 13, 2024 Share Posted April 13, 2024 This looks great! I'm also considering recycling polystyrene waste to make beads- some ideas here: https://youtu.be/_DBo9l9YuB0?si=7oH9KW-8xg5DZdOE Link to comment Share on other sites More sharing options...
ADLIan Posted April 13, 2024 Share Posted April 13, 2024 Bear in mind blown in cavity insulation (new build or refurb) is notifiable under the Building Regs. Product should carry 3rd party certification (BBA or similar) and be installed by approved contractor. 1 2 Link to comment Share on other sites More sharing options...
Roger440 Posted April 14, 2024 Share Posted April 14, 2024 On 13/04/2024 at 11:14, ADLIan said: Bear in mind blown in cavity insulation (new build or refurb) is notifiable under the Building Regs. Product should carry 3rd party certification (BBA or similar) and be installed by approved contractor. Not sure what this posts contributes. This is about DIY installation. I for one couldnt be less interested in building regs approval in this scenario. 1 1 Link to comment Share on other sites More sharing options...
Jinglish Posted April 17, 2024 Share Posted April 17, 2024 Romeo Done! IMG_2479 (online-video-cutter.com).mp4 IMG_2487 (online-video-cutter.com).mp4 IMG_2480 (online-video-cutter.com).mp4 1 Link to comment Share on other sites More sharing options...
NandM Posted April 19, 2024 Share Posted April 19, 2024 I've been looking into DIY blown-in cellulose and have had a quote from Markham Sheffield to hire a Turbisol 56/2 for £225ex vat. I've asked about additional accessories...but the price for the machine seems quite good. Link to comment Share on other sites More sharing options...
Jinglish Posted April 19, 2024 Share Posted April 19, 2024 Up to you but my setup will cost you less than £50 and it’s yours forever. Plus think of all the leaves you can suck up afterwards 🙃 Link to comment Share on other sites More sharing options...
Iceverge Posted April 19, 2024 Share Posted April 19, 2024 Thinking about it some more and looking at some you tube videos cellulose is a different beast. It comes in fairly compacted bags and needs the agitation of the blower to fluff it up properly unlike EPS beads. I think the blower hire would be better for this . 1 Link to comment Share on other sites More sharing options...
NandM Posted April 25, 2024 Share Posted April 25, 2024 Agreed - i've seen some simple setups using a compressor and vacuum gun that also works really quickly. I think you could bodge together one of these vacuum guns with a paint spray machine for the pva and have both hooked up into one outlet. Link to comment Share on other sites More sharing options...
