New member
Hello everyone! Thank you for letting me join this fantastic community! I am currently doing a university project related to passive house. I am responsible for ventilation part. Cheers!
  • Replies 53
  • Views 6.4k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Getting good air tightness is mostly down to attention to detail in the build, taping and sealing everything, and not leaving anything unsealed, no unwanted holes, design out "leaks" like cat flaps an
  • I think MVHR systems are designed to produce a target ACH (building regs use L/S) ignoring any provided by infiltration. On a calm day for example there could be very little. The 0.6 ACH figure is for
  • Hello everyone! Thank you for letting me join this fantastic community! I am currently doing a university project related to passive house. I am responsible for ventilation part. Cheers!
Posted Images
Welcome.
Ventilation is very misunderstood on here, any input would be useful.
Very interesting.  By ventilation do you mean MVHR and/or Airtightness?  I have an interest in peoples wellbeing in a Passive Houses.
A breath of fresh air; always welcome... aye!
Yeah, mainly the design of MVHR system. I still know very little
13 hours ago, irnbru said:
university project
Is this a final year project?
One area that would be interesting is how the overall building airtightness affects the performance of the MVHR.
There seems to be 'rules of thumb' about not worth it if your house has more than 3 ACH@50Pa.
Another area that I would like to know is, how does different mass flow rates affect the energy transfer.
Do you have a Passivhaus to play with at the university?
Edited by SteamyTea
There are many knowledgeable people on here.  Having a read of this book is a good place to start.  Remember Passive House is about a Fabric First approach.
There seems to be 'rules of thumb' about not worth it if your house has less more than 3 ACH@50Pa.
Exactly, final year project. I don't have Passivhaus to play with...unfortunately. When you said "less more than 3ACH@50Pa", you mean less than 3 or more?
Thank you for your recommendation!
Whoops, more than, not too leaky.
Shall go and edit my post.
Edited by SteamyTea
We had a house with an MVHR, with 0.8ACH@50Pa [not quite passivhaus, though the heating was 14.2 sqm/a]. We switched the MVHR off, because it sucked in the local bonfires and coal fires from the neighbours. Never switched it on again. Mind you, there were only 2 of us living in 280 square metres, so there was a big volume of air to share. The house had windows too, so we opened those now and again.
Thank you for sharing! In our uni final project, it's a house with 5 people there. We are still designing the house therefore I don't know the exact size but I think it won't be more than 200 m2. It seems that MVHR is definitely worth it.
It Passive House Open day in a couple of weeks - https://www.passivhaustrust.org.uk/event_detail.php?eId=1016#Participating projects
As I said before, we don't have Passive Houses in the university to play with. Are there ways of predicting the airtightness? Are there softwares?
5 minutes ago, Adrian Walker said:
Airtightness is designed-in and measured.  Are you aware of PHPP - https://passivehouse.com/04_phpp/04_phpp.htm ?
I had no idea! Thank you for sharing. I'm gonna read that. The problem is that right now we are trying to calculate the infiltration losses and we've no idea of the number of air changes per hour
Edited by irnbru
Very low air leakage rates are required by the Passivhaus standard and must be demonstrated for each certified building by means of a “blower door” air tightness test. The air change rate must be less than or equal to 0.6 air changes per hour, under test conditions.  This site will help you - https://passipedia.org/start
Edited by Adrian Walker
Yeah I know it. The problem is that right now there are no ways we can show that our house has an air change rate less or equal to 0.6 changes per hour...
You ca get an air test done on it.
Either ask/beg a company that does tests, or make your own tester with a car radiator fan, manometer and a flow meter.
I think MVHR systems are designed to produce a target ACH (building regs use L/S) ignoring any provided by infiltration. On a calm day for example there could be very little. The 0.6 ACH figure is for Passive House standards. Less than 3.0 is the test when trying to decide if the house is even suitable for MVHR.  I think if you are tasked with designing an MVHR system you will have to assume the house is suitable or ask if its already been tested? Was it done for a previous years project perhaps?
If you need real world leakage rates..
I think measuring the actual ACH due to leaks in varying weather conditions involves using trace gasses. Not sure which trace gasses are used but you could inject one until it reaches a certain concentration, wait a few hours, remeasure the concentration and do the sums to work out how much air has got in to cause the measured dilution.  Caution: Dont just use C02 without taking safety precautions.
I believe its also possible to use humans.. You can measure the volume of a bedroom and estimate the C02 production of the people sleeping in it.  Then by measuring the actual increase in C02 concentration overnight you can estimate the ACH. Ive not done the sums myself but google found ..
https://protonsforbreakfast.wordpress.com/2021/06/06/estimating-rates-of-air-change-in-homes/
Edited by Temp
5 minutes ago, Temp said:
I think MVHR systems are designed to produce a target ACH (building regs use L/S) ignoring any provided by infiltration. On a calm day for example there could be very little. The 0.6 ACH test figure is mainly used as a pass/fail test when trying to decide if the house is even suitable for MVHR.
I thought the 0.6ACH was the requirement to be certified as a passive house?
In Scotland, if your air test comes in a 3 or lower, building control insist you install MVHR.
Ours tested at 1.4 which initially I was disappointed with, but the tester said it was the best one he had yet tested.  That surprised me.
Yeah sorry I think you are right. Its less than 3 for MVHR. Ill edit my post.
