revelation Posted October 17, 2022 Posted October 17, 2022 I was looking to put in our balustrade/handrail but didn't want to start the first step. Are there any regulations in terms of what height or what step it needs to begin at?
markc Posted October 17, 2022 Posted October 17, 2022 900-1000mm above the nose of the stair and must prevent a fall of more than 1 step.
revelation Posted October 17, 2022 Author Posted October 17, 2022 So the max it can be is starting at the second step?
Dave Jones Posted October 17, 2022 Posted October 17, 2022 nhbc says it has to follow the pitch line.
markc Posted October 17, 2022 Posted October 17, 2022 44 minutes ago, revelation said: So the max it can be is starting at the second step? Newel posts are usually fitted against the riser of the bottom step so the handrail finished against the newel post pretty much vertically above the first step, but stairs sometimes (more often in larger wider cases) the first step fans out and is unprotected. But some BCO’s can be arsey so better to check beforehand.
Conor Posted October 17, 2022 Posted October 17, 2022 (edited) We did it same as Joe, newel post on the second bottom step. The underside of the handrail is a continuous 900mm above the imaginary string line across the treads. And remember, max of 100mm space between ballusters / spindles. Edited October 17, 2022 by Conor
ETC Posted October 17, 2022 Posted October 17, 2022 2 hours ago, Conor said: And remember, max of 100mm space between ballusters / spindles. Hate to be pedantic but balusters need to be spaced so that a 100mm sphere CANNOT pass between them. Slight difference but less than 100mm. I’d normally suggest 100mm maximum centres. Works for most infill balusters. 1
ETC Posted October 17, 2022 Posted October 17, 2022 13 hours ago, revelation said: I was looking to put in our balustrade/handrail but didn't want to start the first step. Are there any regulations in terms of what height or what step it needs to begin at? Speak to Building Control. They will give you all the information you need.
joe90 Posted October 17, 2022 Posted October 17, 2022 I would recommend “stair box”, who designed and supplied ours (above) in kit form and they know all the regs.
DevilDamo Posted October 18, 2022 Posted October 18, 2022 Guarding is usually required when there is a difference of levels of at least 600mm so that would naturally be 3 steps.
revelation Posted October 20, 2022 Author Posted October 20, 2022 On 18/10/2022 at 08:16, DevilDamo said: Guarding is usually required when there is a difference of levels of at least 600mm so that would naturally be 3 steps. That would be ideal, but it would be nice to have that in black and white, do you know where I could find the reference for that?
