Slates
nod
3 hours ago, Simplysimon said:
looks good, should have gone with hooks though, nice and easy to replace any. bend hook, slide slate out slide new slate in on a slate ripper to catch the top of the batten, bend hook back, job done. try that with double nailed slates.
Repairing a double nailed slate is easy if you know what you're doing. It's a 2 minute job.
Simple
You get a long hacksaw blade and spend half an hour trying to cut the slate nails.
Then carefully bend some old fragile slates out of the way whilst trying to prise the remains of the broken slate out. Despite your best try another 7 slates crack in the process.
Whilst doing this you see the battens are completely rotten so you carefully start to cut out the damaged sections.
Unfortunately this reveals the felt is in bad condition and full of holes. Cursing your luck you decide to decamp to the van to consider your options and avoid the unforecast downpour.
Just then a gust whips yet more slates from the roof and blows one through the back window of a van marked "militant  bat surveys". On que, perhaps disturbed by the din, an endangered " Green hairy bikini bat" emerges from a hole in the felt and lands on the windscreen wipers of said bat surveyors conveyance.
Disheartened and defeated you go to turn the ignition key and retreat further to the pub. B*ollocks the van won't start.  Walking home, you reach your house sometime in the dark only to be greated by the smoking remains of your torched semi-d and a note saying your Mrs has eloped with her yoga teacher.
As the tears and snot drip from your nose you think back to where it all went wrong.
Should have used slate hooks.
Edited by Iceverge
  • Haha 4
that was the best bit.  ! I’d like to see a pallet full of 7newton blocks blow through my batmans car.
2 hours ago, Simplysimon said:
please enlighten me
Ask any qualified roofer.
I am one. It's a simple job.
Two ways. Either the same method here and install a slate hook or simply take one nail from each of the above slates also to allow them to turn. Then double nail the repaired slate and glue the two above back into position.
1 minute ago, Simplysimon said:
so not as installed
and a bodge
It's a repair. it's in the name.
And no glue is not a bodge. If the slate has a fixing already then it can be used. Unless you want to tell architects working on historic Scotland buildings they are wrong.
