Pocster Posted May 31, 2022 Posted May 31, 2022 31 minutes ago, saveasteading said: Maybe it was you that cost me all that money! I bought 40 cans sometime ago . All used now . Expanding foam and ct1 are all you need .
Russell griffiths Posted May 31, 2022 Posted May 31, 2022 5 hours ago, saveasteading said: I hate it. It gets used to overcome all sorts of issues that have better solutions. It has cost me thousands, when it leaks over metal cladding, doesn't come off again and needs a whole wall replacing. Mt nobody did it but my cleient didnt care who did it. It fills voids with potential damage through damp. It probably shrinks over time. It drips and sticks. So even for my own job with my own control, I would find another way. Probably stuffing the gap with surplus foam packaging, which will be a more reliable and flexible solution. And can be removed if necessary. Your buying the wrong stuff. i changed to the illbruck brand a couple of years ago and haven’t used any of the high expansion air leaky rubbish since. if you buy it in a box of 12 it’s not a lot dearer. get a can, it’s like chalk and cheese.
saveasteading Posted May 31, 2022 Posted May 31, 2022 26 minutes ago, Russell griffiths said: Your buying the wrong stuff. Not me, It is in the back of every bodger's van. What is so good about this Illbruck, as I might look into it.
Russell griffiths Posted May 31, 2022 Posted May 31, 2022 1 minute ago, saveasteading said: Not me, It is in the back of every bodger's van. What is so good about this Illbruck, as I might look into it. It’s a closed cell foam, not open cell. So the resulting dried blob is like a firm rubber ball as opposed to the rice crispy like texture of the cheapo screw fix rubbish.
saveasteading Posted May 31, 2022 Posted May 31, 2022 So totally different chemically. stays flexible long-term? Is the expansion controllable?
Onoff Posted May 31, 2022 Posted May 31, 2022 19 minutes ago, saveasteading said: So totally different chemically. stays flexible long-term? Is the expansion controllable? It's really good. Better than the Soudal Low Expansion I was using. Goes off to like a tough, flexible rubber skin rather than a 'crunchy' mass. I struggled to cut it like "normal" foam.
Simplysimon Posted May 31, 2022 Posted May 31, 2022 28 minutes ago, saveasteading said: Is the expansion controllable? to a fair extent, and it doesn't seem to clog the gun and when it does get too clogged to foam properly the cleaner works a treat.
Pocster Posted June 1, 2022 Posted June 1, 2022 15 hours ago, Onoff said: It's really good. Better than the Soudal Low Expansion I was using. Goes off to like a tough, flexible rubber skin rather than a 'crunchy' mass. I struggled to cut it like "normal" foam. But when you f up after using this rubber foam it’s going to be a bitch to get out . I always assume any ‘fix’ on a f up could be another f up that needs removing at a later date .
MortarThePoint Posted June 13, 2022 Author Posted June 13, 2022 Almost ready to cover up with APR and plasterboard. I used Kilmat as @Nickfromwales suggested to help with any noise. The clips are 40mm clips used on 32mm pipe with foam tape wrapped around to reduce noise transfer. The pipe exits the wall within a 100mm square from the floor and the wall. At the other end you can see the pipe exit at around 500mm from the floor and with H and C written just above where I am going to send the water feeds through. I think those holes are 60mm higher than the waste hole and 80mm apart. The plan is for the feeds to then split inside the room to feed the two basins as that puts fewer fittings in the wall. I'll need to use elbows on the feed pipes as the wall cavity is only 70mm and the bend radius is 120mm/80mm for 15mm/10mm pipe. I could exit the wall at an angle but I think that could look bad. 4
Nickfromwales Posted June 13, 2022 Posted June 13, 2022 4 hours ago, MortarThePoint said: The plan is for the feeds to then split inside the room to feed the two basins as that puts fewer fittings in the wall. I'll need to use elbows on the feed pipes as the wall cavity is only 70mm and the bend radius is 120mm/80mm for 15mm/10mm pipe. Don't panic about the fittings as Hep2o stuff is simply bombproof. 4 hours ago, MortarThePoint said: I could exit the wall at an angle but I think that could look bad. Defo avoid doing that
MortarThePoint Posted June 14, 2022 Author Posted June 14, 2022 On 13/06/2022 at 22:47, Nickfromwales said: Don't panic about the fittings as Hep2o stuff is simply bombproof. Defo avoid doing that Placing the pipes between two layers of 25mm APR. I wanted 15mm pipe sticking out of the wall to attach the basin flexis to so used a 15mm/10mm reducer and 15mm elbow. Where I'm going to box out near the floor I was able to send the 10mm pipe through at a slight angle to allow it to fit in the 70mm cavity. I pushed the Hep2O fittings together really hard, but the In4Sure rumble was very hard to feel except for the reducer. I couldn't rotate the last elbows either as they had to be assembled once already through the wall. I don't want to disassemble it and reassemble in a different order that allows turning. How important is that? 1
MortarThePoint Posted 4 hours ago Author Posted 4 hours ago I'm looking to attach the basin to all this now, so I am looking at trap options. For most situations I'd prefer a P-trap, but am thinking I may prefer a bottle trap here for a slightly odd reason. I'd want the trap to block rather than the pipe in the wall. Remember that the 32mm pipe in the wall has two tight 90 degree elbows so blocking is more likely than normal. Is that logic sound and is a bottle trap the right choice? On 02/05/2022 at 21:50, Nickfromwales said: Trust me, I'm a pipe doctor What's the pipe doctor's prognosis?
Nickfromwales Posted 3 hours ago Posted 3 hours ago 1 hour ago, MortarThePoint said: I'm looking to attach the basin to all this now, so I am looking at trap options. For most situations I'd prefer a P-trap, but am thinking I may prefer a bottle trap here for a slightly odd reason. I'd want the trap to block rather than the pipe in the wall. Remember that the 32mm pipe in the wall has two tight 90 degree elbows so blocking is more likely than normal. Is that logic sound and is a bottle trap the right choice? What's the pipe doctor's prognosis? You worry too much lol. 2 bends for a basin is fine, and I almost always use a bottle trap as 1) they’re more compact, and 2) they’re so simple to unscrew and drop down to service. “Bottle” 👍🤝 1
MortarThePoint Posted 2 hours ago Author Posted 2 hours ago 1 hour ago, Nickfromwales said: You worry too much lol. 2 bends for a basin is fine, and I almost always use a bottle trap as 1) they’re more compact, and 2) they’re so simple to unscrew and drop down to service. “Bottle” 👍🤝 Good The next choice is where to put the bottle since the pipe into the wall is much lower (510mm) than the bottle of the waste (730mm). I guess I have two options, drop the height before the bottle or after:
