Jenki Posted February 23, 2022 Posted February 23, 2022 HI all. Would anyone with some knowledge like to give me an opinion on the AHP60 ASHP. Spec attached. its in conjunction with my other post, so run this to heat a 300L UVC for 2 camping pods. the money is good, brand new 3 year warranty. It is cheaper than the Dream units on ebay. and at this cost is sort of a no brainer unless someone see's a big issue. I've taken into account that parts if not local will take an age from China, but the immersions (on the tank) will be my back up. Might be convinced to buy 2 and use for the house as well... AHP60Spec.pdf
Jenki Posted February 23, 2022 Author Posted February 23, 2022 1 hour ago, SteamyTea said: What is the price? £1100 delivered
ProDave Posted February 23, 2022 Posted February 23, 2022 @Jenki could you post more details of this ASHP, brochure, install manual? link to source? At that price it looks good, is this a one off end of line special or a normal offering? Is the guarantee with a recognised supplier / distributor?
Radian Posted February 23, 2022 Posted February 23, 2022 (edited) https://www.ebay.co.uk/itm/Panasonic-Compressor-6KW-Air-Source-Heat-Pump-AHP-60-ASHP-3-years-warranty-/302964624843 Non inverter style, usually marketed for swimming pool heating. Edited February 23, 2022 by Radian
Iceverge Posted February 23, 2022 Posted February 23, 2022 How about an ESHP with a coil. Heating DHW and ventilation in one . You could use the heating coil as a take off to run the UFH. Granted the extract air would be stealing heat from the cabin in winter to heat the cabin, perhaps running it in external air only/partially then would work. Maybe it's a terrible idea?
SteamyTea Posted February 23, 2022 Posted February 23, 2022 28 minutes ago, Jenki said: £1100 delivered At that price it us worth taking a chance. In all reality, there is no real reason, apart from after sales service and performance guarantee, for a hp to cost much more than a posh fridge.
Jenki Posted February 23, 2022 Author Posted February 23, 2022 (edited) 25 minutes ago, Radian said: https://www.ebay.co.uk/itm/Panasonic-Compressor-6KW-Air-Source-Heat-Pump-AHP-60-ASHP-3-years-warranty-/302964624843 Non inverter style, usually marketed for swimming pool heating. Why do you say non invertor style? It says DC invertor? I thought the pool heater had large flow and return in the 2" range? Also will heat water to 55 although the COP will fluctuate - I thought most pool heaters will only get to 40? Edited February 23, 2022 by Jenki added info
Jenki Posted February 23, 2022 Author Posted February 23, 2022 20 minutes ago, ProDave said: @Jenki could you post more details of this ASHP, brochure, install manual? link to source? At that price it looks good, is this a one off end of line special or a normal offering? Is the guarantee with a recognised supplier / distributor? AHP-60 Manual.pdf There's a couple left, maybe more, offered me a little saving if I bought 2. ?
Jenki Posted February 23, 2022 Author Posted February 23, 2022 9 minutes ago, Iceverge said: How about an ESHP with a coil. Heating DHW and ventilation in one . You could use the heating coil as a take off to run the UFH. Granted the extract air would be stealing heat from the cabin in winter to heat the cabin, perhaps running it in external air only/partially then would work. Maybe it's a terrible idea? I've got two cabins to supply, so the tank will be in an amenity / service block, so just need to heat 300L of water and keep it warm to keep people happy.
Jenki Posted February 23, 2022 Author Posted February 23, 2022 9 minutes ago, SteamyTea said: At that price it us worth taking a chance. In all reality, there is no real reason, apart from after sales service and performance guarantee, for a hp to cost much more than a posh fridge. That's my thought... just want to make sure I'm not missing something..
Radian Posted February 23, 2022 Posted February 23, 2022 I had looked at these a while ago from Orion Air sales. As there wasn't any good data there, I gave them a ring and they said it had no inverter. But the Chinese can never make the same thing twice so maybe it's got one now? I'm having some difficulty understanding the manual you uploaded. e.g. " Not have this now " does the crossing out mean it has now ?
Jenki Posted February 23, 2022 Author Posted February 23, 2022 2 minutes ago, Radian said: I had looked at these a while ago from Orion Air sales. As there wasn't any good data there, I gave them a ring and they said it had no inverter. But the Chinese can never make the same thing twice so maybe it's got one now? I'm having some difficulty understanding the manual you uploaded. e.g. " Not have this now " does the crossing out mean it has now ? I assumed and this is always a problem, that it was a standard controller and those parameters did nothing to the ASHP unit.? there is a note at the bottom "Note: some parameter is not effective for the unit, so the have a “---------------- ”
SteamyTea Posted February 23, 2022 Posted February 23, 2022 35 minutes ago, Radian said: https://www.ebay.co.uk/itm/Panasonic-Compressor-6KW-Air-Source-Heat-Pump-AHP-60-ASHP-3-years-warranty-/302964624843 Non inverter style, usually marketed for swimming pool heating. Often wondered about these pool heating ones, we used to sell them, but that was over 30 years ago and I took no interest in that side of the business. Swimming pool sales people only come out when it is sunny. If one bought a very cheap one, swapped the fan motor for a variable speed one, cobbled up some kind of feedback circuit, I wonder how good they would be. Not as good as an all sing, all dancing unit, but probably good enough to warm a small house (like mine).
ProDave Posted February 23, 2022 Posted February 23, 2022 21 minutes ago, Jenki said: AHP-60 Manual.pdf 1.9 MB · 3 downloads There's a couple left, maybe more, offered me a little saving if I bought 2. ? It says no delivery to Lowlands, let alone Highlands. Your negotiating should be to just to get delivery to the far north included. Someone like Palletways would do that for about £100 per pallet. 2 might go onto one pallet for one delivery charge. The advert clearly says it has an inverter, so if it turns out not to have, you have a good case for a refund. hint, pay by credit card.
Iceverge Posted February 23, 2022 Posted February 23, 2022 Have you priced an immersion in a coiled cylinder to get you started. For DHW your COP might only be about 2.5. On E7 it might be decades payback depending on your usage.
Jenki Posted February 23, 2022 Author Posted February 23, 2022 1 minute ago, ProDave said: It says no delivery to Lowlands, let alone Highlands. Your negotiating should be to just to get delivery to the far north included. Someone like Palletways would do that for about £100 per pallet. 2 might go onto one pallet for one delivery charge. was going to get them delivered to me in Preston and take them with me. on one of my trips.. hopefully got some storage sorted in Wick.
Iceverge Posted February 23, 2022 Posted February 23, 2022 I'm thinking an all in one ESHP like @Thedreamer has might be an ideal fit. You can buy Chinese ones for about €1500, European ones more like €2000.
JohnMo Posted February 23, 2022 Posted February 23, 2022 Same thing being advertised here. https://www.airconditioningcentre.com/product/ahp-60/ Say Panasonic compressor, no mention of swimming pools
Jenki Posted February 23, 2022 Author Posted February 23, 2022 4 minutes ago, Iceverge said: I'm thinking an all in one ESHP like @Thedreamer has might be an ideal fit. You can buy Chinese ones for about €1500, European ones more like €2000. but I'd need two, one for each pod so that's £3K - I've got a 300L (£200) UVC with Immersion as backup. My rough calcs. as I'm not sure how to calculate re-heat cost etc. but 300L raise temp of 40deg is around 15KW/H so @ 0.25p /KWH that's about £3.75 so lets call that a £5 a day with re heat. with a COP of 2.0 it would be £2.5 saving so 1000/2.5 = 400 days? I'm sure I've got that wrong with some big assumptions but a year or 2 its worth it.. 5 minutes ago, JohnMo said: Same thing being advertised here. https://www.airconditioningcentre.com/product/ahp-60/ Say Panasonic compressor, no mention of swimming pools Same company. - I do think it might not be an invertor even though it says it in the headline - the spec says Rotary-
SteamyTea Posted February 23, 2022 Posted February 23, 2022 7 minutes ago, JohnMo said: Same thing being advertised here. Might be worth giving them a call to see if it is really an inverter model, rather than 'super inverter', which may just mean it is build upside down.
ProDave Posted February 23, 2022 Posted February 23, 2022 31 minutes ago, Jenki said: 54 minutes ago, Iceverge said: but I'd need two, one for each pod so that's £3K - I've got a 300L (£200) UVC with Immersion as backup. I don't recall the size of your pods, but can you not make them close enough together that they share a "plant pod" and both run off the same ASHP and HW tank in the plant pod? I assumed buying 2 was one for the pods and one for the house?
Jenki Posted February 23, 2022 Author Posted February 23, 2022 2 minutes ago, ProDave said: I don't recall the size of your pods, but can you not make them close enough together that they share a "plant pod" and both run off the same ASHP and HW tank in the plant pod? I assumed buying 2 was one for the pods and one for the house? You are correct, 1 for both pods 1 for the house. Pods are around 20M2. The above was referring to ESHP idea, I thought these were smaller units and not enough capacity (DHW) for the two combined hence needing 2? My idea is the plant room with 300L UVC and this ASHP, with backup Immersions. Another topic will be how to divert heat to these immersions from excess solar PV 60M away......?
Radian Posted February 23, 2022 Posted February 23, 2022 1 hour ago, Jenki said: I do think it might not be an invertor even though it says it in the headline - the spec says Rotary- From the Chinesium table on page 22 of the PDF you uploaded: malfuction (sic) code FA : DC fan motor protection (honestly, you couldn't make this stuff up and be any funnier ?) So it looks to me like the fan is DC powered, possibly with a variable speed controller that they choose to call a 'super inverter'. I may well be wrong, but you'd obviously be looking for an inverter controlled compressor (the real power guzzler that could properly modulate the hot water output temperature).
SteamyTea Posted February 23, 2022 Posted February 23, 2022 3 minutes ago, Radian said: the real power guzzler that could properly modulate the hot water output temperature While I agree that having modulation on the compressor is a good thing, for basic heating, for most of the time, how much of a difference will it make. Fitting an oversize buffer tank would allow for storage of higher than optimum temperature water, while still limiting the number of cycles.
