Jilly Posted December 19, 2021 Posted December 19, 2021 We had the screed laid onto the UFH pipes last week and it went well (I'd been a bit nervous about it all!). I had hoped to tile under the kitchen and bathroom furniture but have realised that leaving the correct time for the screed to dry will seriously delay things, so one solution is to put the units in and the floor can still dry underneath if we leave the plinth off (assume the screed can dry under the little legs?). What do people usually do? Any other suggestions?
nod Posted December 19, 2021 Posted December 19, 2021 You can either do that Or give it Ten days and tile under the units and bath There’s very little chance of problems in areas that arnt walked on The majority of commercial jobs that I tile have not been down long enough to fully dry Its very rarely practical 1 1
Russell griffiths Posted December 20, 2021 Posted December 20, 2021 Don’t fit any kitchen doors or end panels the moisture in the building drying will bugger it all up.
Nickfromwales Posted December 20, 2021 Posted December 20, 2021 And put a couple of small desk fans in there, running 24/7 and oscillating, to keep the air from stagnating under the units. 1 1
nod Posted December 20, 2021 Posted December 20, 2021 18 minutes ago, Nickfromwales said: And put a couple of small desk fans in there, running 24/7 and oscillating, to keep the air from stagnating under the units. Exactly Its so important to keep the air moving No heat
Mr Punter Posted December 20, 2021 Posted December 20, 2021 I would not fancy tiling once the units are in. This is the second one of these kitchen onto damp screed topics this month. I think it is best to delay the kitchen install. Get the floor tiled and grouted first. 1
Jilly Posted January 30, 2022 Author Posted January 30, 2022 The screed seems dry now (it was onto an old uneven concrete floor so ranges from 40mm to 75mm in places. It probably needs a bit longer. I am thinking about chancing it and not using a decoupling membrane and tiling the bathroom floor as I feel comfortable with the risk of cracking there as it's small and we can get on with the bathroom installation. which will really move things on. However, if it's a wet messy business and we use flexible waterproof adhesive and grout, will the floor now not be able to dry out? Will this happen whatever?
Mr Punter Posted January 30, 2022 Posted January 30, 2022 7 minutes ago, Dave Jones said: the screed is 35mm out ? No, the original old uneven concrete you div!
Jilly Posted January 30, 2022 Author Posted January 30, 2022 So does it matter that damp is trapped in the screed forever more...
Temp Posted January 31, 2022 Posted January 31, 2022 Normal recommendation is to allow about 1 day per mm thickness. Think you are at about 45 days? How thick is it in the bathroom and can you remember if the screed was very wet when it went down?
Jilly Posted January 31, 2022 Author Posted January 31, 2022 It was quite a dry mix, not at all sloppy. It was probably thinnest in the bathroom, about 40mm
Temp Posted January 31, 2022 Posted January 31, 2022 1 hour ago, Jilly said: It was quite a dry mix, not at all sloppy. It was probably thinnest in the bathroom, about 40mm I reckon it will be OK. 1
