Porthole Posted November 1, 2021 Posted November 1, 2021 Hi Just wondered if someone could advise on whether or not you would notice the difference if you had triple as opposed to double glazing. In 2 rooms on our rennovation, we have a window which is 2m wide by 1.45m high. It will be a fixed aluminium pane. The U value for double glazing is 1.6 on the entire unit and 1.4 for triple glazing. Can someone tell me if having triple glazing would be noticeably warmer/save on fuel bills. The incremental cost is around £600. Thanks Kind regards Sui
ProDave Posted November 1, 2021 Posted November 1, 2021 You should be getting down to or even below 1 for 3G
Porthole Posted November 1, 2021 Author Posted November 1, 2021 8 minutes ago, ProDave said: You should be getting down to or even below 1 for 3G So do you think it isn't really worth triple if only 1.4?
craig Posted November 1, 2021 Posted November 1, 2021 (edited) 13 minutes ago, Porthole said: So do you think it isn't really worth triple if only 1.4? Not with the supplier your using. To get 1.4 with that system is shocking. It means the frame profile is rank rotten and not worth the money. A decent double glazed unit will give you 1.2. Edited November 1, 2021 by craig 1
tonyshouse Posted November 1, 2021 Posted November 1, 2021 It will be a lot quieter and you will save energy too
Conor Posted November 2, 2021 Posted November 2, 2021 Those U values don't sound right. For that size unit you'd expect to be around 0.8 for 3g.
Dudda Posted November 2, 2021 Posted November 2, 2021 My guess is the window supplier to fitting triple glazing into a poor quality cheap frame designed for double glazing which is common among cowboys. If you've a frame designed for double glazing with say 8mm glass, 16mm cavity and 8mm glass that's at total of 32mm thick glazing. They could be putting 6mm glass, 8mm cavity, 4mm glass, 8mm cavity and 6mm glass which is also 32mm thick in total. You'll only get a minor improvement as the cavity's are small and the frame the same however as it's now triple glazed he can charge a lot more and you think it's a lot better. A real triple glazed window in a frame designed for triple glazing will get you a u-value of around 1 or lower as other above have said.
ToughButterCup Posted November 2, 2021 Posted November 2, 2021 I think the message is ... save your £600.
Thorfun Posted November 2, 2021 Posted November 2, 2021 2 hours ago, ToughButterCup said: I think the message is ... save your £600. or go to a different company where 3g will make a difference?
