ProDave Posted September 2, 2021 Posted September 2, 2021 The cardboard would be correct for an inside view showing you how to connect the cables. Since it gives the stripping details of the cable that is probably it's intended use. EDIT: it even says "Inside view" on it, 1
markc Posted September 2, 2021 Posted September 2, 2021 As Prodave said, what’s supposed to be wrong with it?
ProDave Posted September 2, 2021 Posted September 2, 2021 Yes but the cardboard says "INSIDE VIEW". Take the top off, turn the plug over as if you are about to connect a flex to it, and then compare the inside terminal markings to those on the cardboard and report back. EDIT: Time was you did not need instructions to put a flex into a plug. At a very young age as a boy, my MOTHER showed me how to put a plug onto a flex. I bet it is not even taught in school now. 1 1
markc Posted September 2, 2021 Posted September 2, 2021 We were taught how to wire a plug and repair a wired fuse at school
joe90 Posted September 2, 2021 Posted September 2, 2021 (edited) 1 hour ago, markc said: and repair a wired fuse what’s that? (Only joking, showing your age ?) Edited September 2, 2021 by joe90 1
Lorenz Posted September 2, 2021 Posted September 2, 2021 It was an intelligence test at school, left over from the days when they had taught it, bit pointless when nobody was! How many people have round pins these days?
joe90 Posted September 2, 2021 Posted September 2, 2021 1 minute ago, Lorenz said: How many people have round pins these days? Please sir, I do!!, they are 5 amp lighting plugs and sockets for standard lamps etc, socket wired into lighting ring and controlled by wall switch. 1
Lorenz Posted September 2, 2021 Posted September 2, 2021 Last I remember seeing any was in my Grans house a long time ago, other than that I think I have seen them with the retro wiring system we were looking at a few years back.
joe90 Posted September 2, 2021 Posted September 2, 2021 https://www.screwfix.com/p/schneider-electric-ultimate-slimline-5a-unfused-round-pin-plug-white/8216j 1
ToughButterCup Posted September 2, 2021 Posted September 2, 2021 Just finished wiring in the last 5 Amp socket switched - at @ProDave 's suggestion - from the bank of switches next to the front door. It means that when SWMBO comes home and feels a bit 'jangled' she can switch all the 5Amp lights on at once (and she can switch them all off on the way out of the house). Thanks Dave.
joe90 Posted September 2, 2021 Posted September 2, 2021 7 minutes ago, ToughButterCup said: she can switch all the 5Amp lights on at once yes I remember (when quite young) seeing an American film where wall switches activated standard lamps and table lamps around a room, I asked an electrician how this was done and he explained and I have wired my lounge in the last four of my houses this way, it always gets a comment and frankly very easy to do. 1
Alexphd1 Posted September 2, 2021 Posted September 2, 2021 We have a few round pin plugs in new build aswell for lamps.
ProDave Posted September 2, 2021 Posted September 2, 2021 39 minutes ago, Lorenz said: It was an intelligence test at school, left over from the days when they had taught it, bit pointless when nobody was! How many people have round pins these days? The same principle applies to fitting a flex into a square pin plug. 1
