richo106 Posted August 17, 2021 Share Posted August 17, 2021 Hi We are planning to have an extension in the next 18 - 24 months at our bungalow, where the extension will go there is a large ish tree there at the minute. Obviously this tree will be removed before works starts but my mate made a comment in passing saying that he thought trees needed to be removed 2 years before work starts? Is there any truth in this? Or am I ok just to remove tree prior to work starting? Many Thanks Link to comment Share on other sites More sharing options...
Roundtuit Posted August 17, 2021 Share Posted August 17, 2021 I expect foundation design can mitigate any risk to the extension, but perhaps need to consider damage to existing foundations through heave if the tree is close, depending on soil type and tree size. It may need to be removed over the course of a couple of years; get some expert advice. 2 Link to comment Share on other sites More sharing options...
Jilly Posted August 19, 2021 Share Posted August 19, 2021 Definitely plan and do it now if you can, but get specialist advice in case the ground heaves. Also check to see if you need permission or if you have a TPO on it (and hope not!). 1 Link to comment Share on other sites More sharing options...
markc Posted August 19, 2021 Share Posted August 19, 2021 Sooner rather than later to allow the ground to stabilise… moisture wise. no specific time frame but if you remove the tree now and dig the root bowl out the remaining roots will sort themselves. 2 Link to comment Share on other sites More sharing options...
Temp Posted August 19, 2021 Share Posted August 19, 2021 Depends on the tree and the soil type. Worse case would be something like a willow on a clay that shrinks and expands. 1 Link to comment Share on other sites More sharing options...
Marvin Posted August 19, 2021 Share Posted August 19, 2021 +1 to all four above replies! Link to comment Share on other sites More sharing options...
PeterW Posted August 19, 2021 Share Posted August 19, 2021 Get it done now. It will both let the ground recover and also won’t be an issue for planning and tree surveys etc in the eyes of the planners … Link to comment Share on other sites More sharing options...
saveasteading Posted August 20, 2021 Share Posted August 20, 2021 All above agreed, but also your friend is right but a little cautious for most situations. Some repetition: 1. Don't let anyone see it, so gone asap. Not because it is illegal, simply to avoid explanations and complexities 2. The longer it is out the longer the ground has to recover. As we have had a wet summer, the ground should not have shrunk too much. Then the winter is likely to be enough to get back to stability. But depends on tree size and variety, and ground type. Can you advise? Pine in sand is no problem. Oak in clay might be. 3. I would leave the roots where they are. The loosening of the earth from digging out will exceed the gaps left when the roots rot. By all means remove big surface roots, and the trunk under the surface. Is that what a 'root bowl' is? Link to comment Share on other sites More sharing options...
