Hi All
Is anyone obvious missing from the summary of bathroom / shower wall panels below?
I made it this morning but its not quite complete yet.
manufacturer URL guarantee materials
multipanel multipanel.co.uk/ 30 years on Neutrals, Linda Barker, Classic and Heritage
mermaid https://mermaidpanels.co.uk/ 15 years Elite range is a 100% Wood Plastic Composite waterproof core.
Timeless Trade range is a WBP plywood
fibo https://fibo.co.uk/ 25 years plywood
IPSL interiorpanelsystems.co.uk/ 10 years Aquabord Laminate: 10mm Solid w/ Foam Core no Tongue and Groove
Aquabord PVC: 10.5mm Hollow Section Tongue and Groove
Proclad Solid Colour: 2.5mm Solid uPVC no Tongue and Groove
showerwall showerwall.co.uk 10 years HPL range
Laminate on MDF Tongue and Groove
Acrylic
4mm thick no Tongue and Groove
panelstyle panelstyle.co.uk/ 5 years Splashpanel hollowcore 10mm
starline plumbworld.co.uk/ 10 years
I'm interesting in using panels for two new bathrooms in an our renovation because I don't like cleaning grout.
Which panels are good?
Thanks!
Edited by Trillip
typo
Some the retailers hide who the manufacturer is but you can sometimes identify the maker by looking for the most distinctive pattern (e.g. geometric).
I have done 4 bathrooms with the multi panel and I really like it, it goes up really well and is very solid. Not had experience with the others.
primary retailer / maker URL price (£ per sq m) guarantee low visibility jointing materials sources
multipanel multipanel.co.uk   1 year yes economy: 10mm rigid PVC with a decorative face. https://www.multipanel.co.uk
      1 year no The Tile Collection: 3mm solid grade laminate panels https://www.multipanel.co.uk
multipanel multipanel.co.uk   30 years yes Linda Barker, Heritage, Classic, Neutrals: 11mm, laminate face and water resistant hardwood plywood core . https://www.multipanel.co.uk
multipanel multipanel.co.uk   1 year no Reflect Wall Panels: 4mm dual layered acrylic https://www.multipanel.co.uk/
mermaid https:mermaidpanels.co.uk   15 years no Brilliance: 4mm acrylic https://mermaidpanels.co.uk/faqs
mermaid https:mermaidpanels.co.uk   15 years   Elite: 10mm 100% Wood Plastic Composite (WPC) 100% waterproof core https://mermaidpanels.co.uk/faqs
mermaid https:mermaidpanels.co.uk   15 years   Mermaid Classic: 11mm (matches width of the Timeless plywood laminate) https://mermaidpanels.co.uk/faqs
mermaid https:mermaidpanels.co.uk   15 years no Metro Tile: 3mm Composite (?) https://mermaidpanels.co.uk/faqs
mermaid https:mermaidpanels.co.uk   15 years   Timeless Trade: 11mm weather and boil proof (WBP) plywood + laminate https://mermaidpanels.co.uk/faqs
fibo https:fibo.co.uk   25 years   all panels: laminate front, 9mm birch plywood core, "moisture barrier" rear https://fibo.co.uk
IPSL interiorpanelsystems.co.uk   10 years yes Aquabord PVC Aquabord Laminate: 10mm Solid w/ Foam Core
https://www.interiorpanelsystems.co.uk/
showerwall showerwall.co.uk   10 years yes HPL HPL: Laminate on MDF
Acrylic: 4mm thick
panelstyle panelstyle.co.uk   5 years   Splash Panel hollow core 10mm
starline plumbworld.co.uk   10 years   unknown
anacona rearo.co.uk £17.69 1 year yes 10mm PVC (vertical cuboid hollowcore?)
selkie rearo.co.uk £44.36 10 years yes selkie: 11mm laminate Water and Boil Proof (WBP) 9mm Plywood or moisture resistant (MR) MDF https://rearo.co.uk/
versa tile rearo.co.uk £16.99 10 years no versa tile: 3mm, layers of resin dipped of paper fibre https://rearo.co.uk/
nuova rearo.co.uk £61.59 10 years yes nuova: 10mm 100% water impervious foam core https://rearo.co.uk/
Aquatech showerenclosuresuk.com £22.71   no Aquatech: 10mm PVC (vertical cuboid hollowcore?) showerenclosuresuk.com
Aquaglass showerenclosuresuk.com £39.58   yes Aquaglass: 10mm PVC (vertical cuboid hollowcore?) showerenclosuresuk.com
Edited by Trillip
formatting
  • Thanks 2
I'll update more prices later.
I suspect the panels have been more commonly used in commercial settings and are coming across to domestic markets more and more?
Main constructions I can see are as follows:
  • Plywood laminate: 9 mm plywood + 2 mm laminate
  • Fibre Board laminate: 9 mm MDF + 2 mm laminate
  • Plastic hollow core board: 10 mm PVC hollow core / vertical cuboid with decoration facing
  • plastic foam board: 10 mm plastic foam with decoration facing
  • Solid acrylic: 4 mm (with paint on rear face?)
  • Paper Composite: 3 mm paper fibre phenolic resin laminates with decoration facing
sorted by price - I haven't checked for mistakes!
IPSL interiorpanelsystems.co.uk £33.33 10 years no Proclad Solid Colour: 2.5mm Solid uPVC https://www.interiorpanelsystems.co.uk/
IPSL interiorpanelsystems.co.uk £37.50 10 years no Aquabord Laminate: 10mm Solid w/ Foam Core https://www.interiorpanelsystems.co.uk/
multipanel multipanel.co.uk £38.19 1 year no The Tile Collection: 3mm solid grade laminate panels https://www.multipanel.co.uk
panelstyle panelstyle.co.uk £38.28 5 years   Splash Panel hollow core 10mm
proplas 8mm Cellular PVC
multipanel multipanel.co.uk £39.58 1 year yes economy: 10mm rigid PVC with a decorative face. https://www.multipanel.co.uk
splashwall (wetwall, wilsonart) https://wetwall.co.uk/ £45.14 10 years   11mm (9mm MR MDF Core + laminate) https://www.screwfix.com
mermaid https:mermaidpanels.co.uk £52.08 15 years no Metro Tile: 3mm Composite (?) https://mermaidpanels.co.uk/faqs
mermaid https:mermaidpanels.co.uk £59.03 15 years   Elite: 10mm 100% Wood Plastic Composite (WPC) 100% waterproof core https://mermaidpanels.co.uk/faqs
multipanel multipanel.co.uk £60.76 30 years yes Linda Barker, Heritage, Classic, Neutrals: 11mm, laminate face and water resistant hardwood plywood core . https://www.multipanel.co.uk
IPSL interiorpanelsystems.co.uk £62.50 10 years yes Aquabord PVC: 10.5mm Hollow Section https://www.interiorpanelsystems.co.uk/
showerwall showerwall.co.uk £68.47 10 years yes HPL HPL: Laminate on MDF
Acrylic: 4mm thick
https://www.homesupply.co.uk/category/showerwall-panels
fibo https:fibo.co.uk £72.22 25 years   all panels: laminate front, 9mm birch plywood core, "moisture barrier" rear https://fibo.co.uk
https://www.directbathroomandkitchen.co.uk/
splashwall (unknown) https://wetwall.co.uk/ £86.81 15 years yes Elite: Medium-density fibreboard (MDF) & vinyl https://static1.squarespace.com/static/
https://www.trade-point.co.uk/
mermaid https:mermaidpanels.co.uk £114.08 15 years   Timeless Trade: 11mm weather and boil proof (WBP) plywood + laminate https://mermaidpanels.co.uk/faqs
mermaid https:mermaidpanels.co.uk £118.14 15 years no Brilliance: 4mm acrylic https://mermaidpanels.co.uk/faqs
multipanel multipanel.co.uk £123.71 1 year no Reflect Wall Panels: 4mm dual layered acrylic https://www.multipanel.co.uk/
https://www.upvcbuildingplastics.co.uk
mermaid https:mermaidpanels.co.uk   15 years   Classic: 11mm (matches width of the Timeless plywood laminate?) https://mermaidpanels.co.uk/faqs
If there are any errors, there is an editable copy here
https://docs.google.com/spreadsheets/d/1IkK2uvOXl0zbd-WHifW3As6RtcgJHjy1pn2QS-DO1Xg/edit?usp=sharing
I like the look of these because I think I err of the side of plywood, perhaps unfairly:
primary retailer URL price (£ per sq m) guarantee materials
selkie rearo.co.uk £44.36 10 years 11mm laminate Water and Boil Proof (WBP) 9mm Plywood or moisture resistant (MR) MDF
splashwall (wetwall, wilsonart) wetwall.co.uk £45.14 10 years 11mm (9mm MR MDF Core + laminate)
multipanel multipanel.co.uk/ £60.76 30 years Linda Barker, Heritage, Classic, Neutrals: 11mm, laminate face and water resistant hardwood plywood core
fibo fibo.co.uk £72.22 25 years all panels: laminate front, 9mm birch plywood core, "moisture barrier" rear
17 hours ago, Simon R said:
Another one not to be overlooked.
https://www.recosurfaces.com/
they do a huge range and allow you to provide your own images, which surprisingly reduces the cost.
Thanks!
WOW. Red snakeskin shower anyone?
I really like the variety. They use a backing tape and silicone as a joint system:
https://trade.recosurfaces.com/technical-specifications/installation/
Simon R: have you used them?
Edited by Trillip
formatting
Yes, several, I installed them on top of 11mm moisture resistant MDF which I've found to be very stable even in damp conditions. see:
  • 2 years later...
  • 4 weeks later...
In the end something else!
white quartz gloss, nuance panel by bushboard.
Its a bit "bling" but the gloss finish is easy to wipe.
No trims in the corners. 15 year gaurantee if you follow the rules (use their silicone etc).
It has some sort patented material that is very strong and 100% waterproof. We left a chunk of it submerged in a bucket of water for a few days and it didn't change.
Delivery was annoying. Make sure you check edge of the tongue and groove as they unload. We had a few damaged due to their awful packaging.
quite expensive
https://www.google.com/shopping/product/6132013860646745681/offers?q=white+quartz+nuance+2420mm+1200mm&sca_esv=9c0a2ce53a51d660&hl=en-GB&psb=1&prds=cid:6132013860646745681,cs:1,eto:5863396389283426509_0,pid:8377505064674615891,rsk:PC_3562422885096923569,scoring:tp
Edited by Trillip
On 13/07/2021 at 14:50, Declan52 said:
I used the Linda Barker range for my bathroom. Was very impressed with it.
It cost me £125 for each sheet. Screenshot_2021-07-13-14-49-24-803_com_miui.gallery.thumb.jpg.7f470f18154d95c06bd3328a2bb1c88e.jpg
Didn’t she sing in Bucks Fizz?
