Go around the outside unless absolutely necessary due to required falls and termination levels preventing the extended runs
Ours goes out and around at the back and front. Means a few more ICs but with Clarke drain covers you can have them in your drive or patio and never notice.
Drain rods come in 10m packs so that should be the distance between ICs on the runs.
That isn't the max distance required in building regs it is 22m i think, Table 13 here
https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/442889/BR_PDF_AD_H_2015.pdf
Though if the rods come in 10m packs i would out a max of 18m between inspection chambers so you have 9m + 1m overlap from either inspection chamber
Edited by Moonshine
No that is a poor design.  Maybe get your architect or whoever is doing your Building Regs to add this in because if you don't get it right it can be a real pain.
Fair enough - SE specced ours at 10m  - you're right though, one pack is never quite enough!
Thanks, all.
Was relying on stuff like this:
https://www.nhbc.co.uk/binaries/content/assets/nhbc/tech-zone/nhbc-standards/tech-guidance/5.3/p261---tg-5.3---y-junctions_v1.pdf
Rodding eye at one end, IC at other. One soil vent at east side. Air admittance valves in every bathroom/WC.
Pumping chamber situated 5m from dwelling.
Because discharge from pumping chamber would go under a drive, cast iron 100DN (instead of the black MDPE 90mm suggested earlier).
Might that work, despite the concerns expressed?
@WWilts I think the confusion is your drawing wasn’t clear, it looks like you have just drawn orange lines and not stopped at the walls.
If you mark it up with rodding eyes on the end then that looks like a much better idea.
Has your architect done you drawings with layers that that can be removed, that way you can have a drainage plan without all the other junk clouding peoples view.
Edited by Russell griffiths
5m from house SW corner to pumping chamber
Any obvious flaws?
