nod Posted March 21, 2021 Share Posted March 21, 2021 Has anyone used Tub mix delivered Last time I considered it But ended up just hiring a mixer due to the onset of winter Just wondering about the cost differential Link to comment Share on other sites More sharing options...
Oz07 Posted March 21, 2021 Share Posted March 21, 2021 I couldn't get for this place but is definatley the way forward. Think there's a bit more wastage and bit of waiting time but if you have a dumpy of sand and few cement on site for blockwork to avoid dead starts. 1 Link to comment Share on other sites More sharing options...
Mr Punter Posted March 21, 2021 Share Posted March 21, 2021 Yes. They often put a retarder in it so it lasts for at least a couple of days. Link to comment Share on other sites More sharing options...
Oz07 Posted March 21, 2021 Share Posted March 21, 2021 72 or 36 hours the longest retarder. It is easy to plan if the weather plays ball. Mix consistency, colour and strength all spot on. Link to comment Share on other sites More sharing options...
Brickie Posted March 21, 2021 Share Posted March 21, 2021 Haven’t used it for a few years & so you only remember the problems as time passes... With the retarder it can be like soup when delivered so Monday mornings can be a stress as it’s unlikely you have anything usable left from the previous week. Towards the end of its time it can need knocking up a lot (especially in summer) so it’s worth spinning it in the mixer for a bit. No colour variation is an obvious plus & I believe there are firms who’ll deliver as little as one tub,though I imagine you pay over the odds for that amount. Link to comment Share on other sites More sharing options...
Russell griffiths Posted March 21, 2021 Share Posted March 21, 2021 What’s all the problems the mass builders are having with mortar joints all falling out. Was it just a bad batch or are they specifically getting weaker mix to save money. Link to comment Share on other sites More sharing options...
epsilonGreedy Posted March 21, 2021 Share Posted March 21, 2021 3 minutes ago, Russell griffiths said: What’s all the problems the mass builders are having with mortar joints all falling out. Was it just a bad batch or are they specifically getting weaker mix to save money. I read a report on this issue and the problem was blamed on some parts of the construction industry changing to mortars specified to meet performance criteria rather than specified by ingredient ratios. Once something as nebulous as mortar "performance" is used it is simpler to cut corners. Link to comment Share on other sites More sharing options...
PeterW Posted March 21, 2021 Share Posted March 21, 2021 13 minutes ago, Russell griffiths said: What’s all the problems the mass builders are having with mortar joints all falling out. Was it just a bad batch or are they specifically getting weaker mix to save money. They use silo not tub mix. Very different products. 2 hours ago, Oz07 said: Think there's a bit more wastage and bit of waiting time but if you have a dumpy of sand and few cement on site for blockwork to avoid dead starts. Yep below ground could be done using a mixer. Wastage can be managed. Company we use will deliver 3 or 4 empty tubs and we used to order a couple on a Monday and same Wednesday, could sometimes get away with a single and they had no issues with that. Mix consistency and colour was perfect, and wrapped with a plastic bag (how they keep the tubs clean) it lasted 3 days. 1 Link to comment Share on other sites More sharing options...
Critical Path Posted March 21, 2021 Share Posted March 21, 2021 We are using pre mixed mortar here, its expensive V mixing on site but as Peter W says quality is good, on site we have Mondays delivered on Friday so its fit to use and not like soup. If recall its about 10p a brick. Link to comment Share on other sites More sharing options...
Russell griffiths Posted March 21, 2021 Share Posted March 21, 2021 So @PeterW what’s been the problem with the silo stuff. Link to comment Share on other sites More sharing options...
PeterW Posted March 21, 2021 Share Posted March 21, 2021 9 minutes ago, Russell griffiths said: So @PeterW what’s been the problem with the silo stuff. So the silos can be premixed and when it’s blown in the cement can separate from the sand as it’s smaller so you can find the cement drops to the bottom and comes out first. They are supposed to mix it and check the cement content but that never happens. 1 Link to comment Share on other sites More sharing options...
Brickie Posted March 22, 2021 Share Posted March 22, 2021 We once ran a Silo virtually dry & the colour changed considerably darker. The rep told us the opposite-that the last knockings of powder are cement-rich which gave the difference in tone. Link to comment Share on other sites More sharing options...
